12-16-2023, 01:20 AM | #1 |
Rep 9
Midrange options and setups
What are people using for midranges in the factory location and how do they image/sound. Not really interested in drop in speakers (bav, alphaone, etc.) SQ is the goal and I'm trying to be more budget conscious with this build so $200+ drivers are probably not in the mix unless I can find some used.
Whatever option I choose will be amplified via match up 7/similar or separate amp&dsp with at least 50W/channel. Options I'm considering Dayton RS100P Scanspeak 10F/4424G SB acoustics SB12CACS25 |
12-16-2023, 08:15 AM | #3 |
Rep 16,678
Before doing any speaker swapping install the MatchUp and tune the DSP. The lack of a good DSP is by far the main shortcoming of the OEM setup. If I was to make a change of the midranges this would be my choice: https://www.madisoundspeakerstore.co...-woofer-4-ohm/
12-16-2023, 05:56 PM | #4 | |
Rep 9
12-16-2023, 07:41 PM | #5 |
Rep 726
BTW those SBs look a quite deep, not sure you'd be able to space them out enough unless going to modify door card and remove oem grill and spacer behind. Would need 20mm plus spacers to have door glass clearance.
12-16-2023, 09:26 PM | #6 |
Rep 16,678
I haven't listened to them. When you have sufficient data, and know what it means, it's not necessary. Their sensitivity isn't lower than average, and the off axis response is better than most. It doesn't look so good above 5kHz, but that's moot since the tweeters handle that. The dispersion, high xmax and reasonable price are why I'd use those if I was inclined to make a change. BTW, the Scanspeak and SB Acoustics Qts is way too low for use in doors.
12-17-2023, 01:10 PM | #7 | |
Rep 9
Talking in generalities, low qts isn't great for door installations bc of the massive enclosure size/pseudo IB setup. That being said the tradeoff is usually in output (db) as the drivers will reach their physical xmax/distort quite early. My experience is almost exclusively with larger drivers (6.5"+) and it was my belief that if you crossed the driver over very high above it's fs, eg. multiple octaves, it isn't as much an issue? Also, since these are midranges not playing very low I didn't think it would be a huge issue but that's why I seek advice. Thanks |
12-17-2023, 01:39 PM | #8 |
Rep 16,678
Low Qts works well in ported or horn loaded enclosures, higher Qts works better in sealed. For the most part you don't want to cross over more than one octave above Fs, as that means the Mms is higher than it needs to be, resulting in a loss of sensitivity.
12-17-2023, 06:24 PM | #9 | |
Rep 9
I appreciate the input. Those drivers seem interesting. Anyone know what the cutout diameter for door card is? I think these will need a spacer for them to fit, I haven't measured them yet. |
01-22-2024, 01:43 PM | #11 |
Rep 9
Checked out the door dimensions. The 4.5" aluminum driver will need to be cut out or filed ever so slightly to fit, and the 3.5" paper version will need a small adapter ring or plate.
The power handling is low, but I think it will get close to as loud as I like turn it up. I also prefer the off FR and off-axis characteristics of the 3.5" better than the 4.5" but that driver doesn't go very low. Might not be an issue but I'm new to this vehicle. What are people setting the crossovers at? I just got a PP86DSP amp so I have some flexibility setting some of the crossover points. I still haven't decided if it's worth it to rewire everything for active on my daily. Either way I think I'll eventually put one of these two variants in |
01-23-2024, 03:41 AM | #13 |
Rep 726
For 3.5s did you look at the SI M3 carbon ?
If you can wait for the next batch they are pre ordered at a lower price at the moment. Would obviously need spacing out. I’ve read that somewhere that 40 mm beyond the door opening will hit glass, but didn’t confirm mounting depth with cailpiers. 12mm spacer would do it. Could possibly cross these over 200 -220 https://stereointegrity.com/product/m3-carbon-midrange/ |
01-23-2024, 02:35 PM | #15 | |
Rep 726
Compared to Morel Elite or Focal Utopia mids , BRAX etc I don’t think there are at the absurd spectrum of car audio options. |
01-29-2024, 01:15 AM | #16 |
Rep 9
The only place I can seem to source those 4.5" drivers is overseas. I think the 3.5"s could work but obviously at a much higher crossover point. For now I'm undecided. I see a lot of posts running where individuals are running the midbasses all the way up around 200hz but that's a little high to me. I imagine the imaging would suffer.
01-29-2024, 01:34 AM | #17 | |
Rep 726
LuciasD0.00 |
