08-16-2020, 06:07 AM | #4225 |
Rep 108
08-16-2020, 07:24 AM | #4226 | |
Rep 84
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
08-16-2020, 12:17 PM | #4227 |
Rep 2,591
The double tilt with the iDrive knob works pretty well. Just be mindful of the speed of the double tilt, if you're too slow it'll just shift over to the right/left window instead of skipping tracks.
Music is great. I'm fairly certain these MMI units don't have a DAC and use the car's built in DAC.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 08-16-2020 at 12:29 PM.. |
08-16-2020, 01:29 PM | #4228 |
Rep 108
Where did all of you put the mmi guys ?
Mine is under glovebox in F30 but on my next filter change bmw gonna see it so.... Thinking to move it under steering wheel |
08-16-2020, 06:19 PM | #4229 | |
newbie
Rep 25
08-17-2020, 04:54 AM | #4230 |
Rep 52
Working well so far, still having the same issue for day/night switch but other than that all is good, Wireless AA worked great with my pixel 4. Only thing is I have to manually connect it to the MMI wifi for AA to launch. Just remember to flash the firmware update first then the MCU.
GEDDES1.50 |
08-17-2020, 09:59 AM | #4231 | |
Rep 9
Hello It s working well with the mod version (2.0.B0.mod) (next / previous music with knob is ok ) It s More Clean now Last edited by skalli07; 08-17-2020 at 10:10 AM.. |
Firefly1337846.00 GEDDES1.50 |
08-17-2020, 12:23 PM | #4232 |
Rep 280
New update
New version v9.2.8.yl.b for Carlinkit NBT available on the 1st page (thx cossie1).
Changelog unknown. There's now also a custom version of the already known MCU 20.06.02 available that can be flashed on the latest custom firmware v2.0.*.mod (thx dkeruza). This is only relevant if you are running the latest mod version but not the latest MCU. Previously you needed to flash back to the stock firmware in order to flash it. Other than that there are no changes. |
08-17-2020, 12:50 PM | #4233 | |
Rep 128
I am using very often the Spotify just through the BT on my iPhone, in most through USB-BT, and i am hearing the voices from Waze or other navigation apps from background in car speakers. |
08-17-2020, 02:11 PM | #4234 | |
Rep 52
08-17-2020, 03:08 PM | #4235 |
Rep 1,217
Someone posted a couple of weeks ago that you can flash Custom v2 onto the new Andream B units by changing the file name to GEMINI_PACK.BIN, but that by doing so you would never again be able to flash back to the stock firmware for that unit.
08-17-2020, 03:39 PM | #4236 | ||
Rep 108
And do you have pics when you are in reverse mode ? Thank you very much ! |
08-17-2020, 04:14 PM | #4237 | |
Rep 128
I am just connecting iphone via usb and bluetooth (bmw is enabling something called bluetooth via usb). I can also pick for example Spotify by bmw connected apps. In both cases, when i pick external USB or Spotify, i can hear all sounds from iphone mixed (spotify, waze in background or other navigation software) But, there are multiple application where you can enforce the output, i am curious what options will be avaiable in that case. |
08-17-2020, 04:25 PM | #4238 |
Rep 43
white screen
08-17-2020, 05:13 PM | #4239 | |
Rep 37
Any difference between Bimmertech MCU 10.6.18.21 and MCU 20.06.02 custom (only flashable on v2.0.*.mod)? |
08-17-2020, 05:39 PM | #4240 | |
Rep 108
Kyokushin48.50 |
08-17-2020, 06:52 PM | #4241 |
Rep 12
I just got the andream version, and I finally got it all connected (had an incident with the display cable bending pins, but all fixed now) - I can see the BMW menu and everything like a factory system, but how do I access the MMI?
08-17-2020, 07:37 PM | #4242 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Hold the menu button on iDrive controller
Freude am Fahren.
08-17-2020, 10:04 PM | #4243 |
Rep 5
Hi all! I appreciate all of your responses to everyone here. There is a LOT to go through and it would be cool if there was some sort of FAQ since there's 192 pages. A few questions!
1. I have entrynav on an F48 X1. I'd like to get an 8 or 10" touchscreen for this, does the touchscreen work with carplay? (Seems no based on reading) 2. Is there any lag in the interface? 3. Someone said carplay starts up automatically, is that true? 4. I believe I read carplay doesn't switch between light/dark automatically, is this the case? Is this a default setting? My main concern is google maps here. 5. If I take a call, does it go through the OEM bluetooth/microphone setup? 6. Are there any issues using the idrive controller with it? Is the touch idrive controller better/same? 7. Do I need the external mic for anything or does the OEM mic work? I'm considering the NBT EVO retrofit but it's a bit more expensive and I don't want to lose connected services so I've been looking more into this lately. Last edited by makowb; 08-18-2020 at 04:18 AM.. |
08-17-2020, 11:30 PM | #4244 | |
Rep 92
By the way it feels like in New version v9.2.8.yl.b for Carlinkit NBT they have fixed phone calls quality, maybe someone can check it (if there is still a person like me who don't use MOD))). |
08-18-2020, 12:51 AM | #4245 |
Rep 41
so a couple niggles i have seen with the custom software.
when using google assistant it seems to use the phones microphone not the cars. also the voice command button is not working for google assistant for me. |
08-18-2020, 04:18 AM | #4246 |
Rep 37
I guess google assistant is using phones microphone as I tested it and I needed to talk very loud to get a response from Google Assistant when I looked for an address in Maps.
andream, android, android auto, apple, carplay, mmi, retrofit |
