BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > bmw f32/f30 6wa extended cluster retrofit
      03-30-2020, 04:18 PM   #1
mickyle1995
Drives: bmw 4 series f32 420d
hi everyone ive got the basic cluster on my f32 (as pictured below) and it want to upgrade to the 6wa cluster as i dont justify 1k on a 6wb my question is do i need to make any adjustments to fit this in or is it a case of just plugging in the existing wires (i know the unit has to be virginzed and coded to the car)
      03-30-2020, 04:33 PM   #2
mickyle1995
Originally Posted by RuleNormaliai View Post
you have to see if you have MOST connector in your Head unit, if yes you will need MOST cable and that's it, no other modifications. you can PM me if you want i will give you more info.
thanks i just pm'd you
      03-30-2020, 05:35 PM   #3
mickyle1995
[IMG]undefined[/IMG]
      04-03-2020, 09:30 PM   #4
Jortiz218
Drives: 2015 BMW 435i
I'm interested in doing this as well. Any update?
      04-04-2020, 03:32 PM   #5
mickyle1995
yeah ive been speaking via pm all you'll need is the cluster itself and a most cable (optical cable) the cluster will need to be virginised then coded to your car from there everything should work
      04-05-2020, 06:41 AM   #6
omorzo
Always on track!
omorzo's Avatar
Italy
Drives: 328i
Sorry, i'm not understand. If you buy a cluster, you don't need to verginise? Make it itself?
      04-06-2020, 08:27 PM   #7
mickyle1995
sorry, the cluter gast to be virginised then coded to the car
      04-10-2020, 02:05 PM   #8
mickyle1995
yes thats correct
