BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > UK - Off Topic > Discussion - Dead battery prevention
proTUNING Freaks
      04-06-2020, 07:52 AM   #45
Harryg
Drives: BMW 4series Grand Coupe
Originally Posted by NISFAN View Post
Not exactly.
Lithium is a different technology, that doesn't mean it is better in all circumstances. It's main party piece is high output for a given weight, I.e energy density, which means a smaller battery for a given energy requirement = weight saving for a performance car. They weigh less than half that of a lead acid unit.
Actually, I'd be more worried about a Lithium battery. If voltage drops below a particular value, the battery is destroyed. Lithium batteries often have a condition checker which will cut off any drain when it gets to a certain safe battery level to stop further drain, but who knows if BMW lithium's have this feature?
If I had an M car with lithium battery, I'd definitely get a Lithium C-Tek charger for it. It must be the Lithium version. Or drive the long route to the supermarket.
Sound advice
      04-06-2020, 08:06 AM   #46
NISFAN
NISFAN's Avatar
Drives: BMW M2
Originally Posted by isleaiw1 View Post
Thanks, I may just do that - although as said earlier I cant get the car in the garage so will it be ok connected up outside?
Running a cable into an otherwise locked car is not easy on modern vehicles. I'm not a fan of shutting the boot on the cable(battery in boot). But provided you can do this, no harm in charging outside with a closed car. There are no gasses discharged when charging lithium.
There should also be a positive post under the bonnet you might find easier to access. Of course the whole chassis is negative ground for neg connection.
      04-06-2020, 08:10 AM   #47
Watsey
Drives: F31 330D sDrive M Sport
Buying a dedicated charger will probably be cheaper than the cost of the fuel that the M5 would drink on it's extended run to the shops
mcoops1757.00
      04-06-2020, 08:12 AM   #48
isleaiw1
Drives: iPace / Mini
I filled up at 111.9 at the weekend (whilst on my necessary trip to the supermarket) so suddenly the fuel consumption doesnt seem an issue - especially as it is barely moving....
Now a grand for a battery has got me worried (must do more homework before buying a car in future!)
      04-06-2020, 10:34 AM   #49
KTE
Drives: A slow car
Two 'value for money' candidates that run well in tandem with AGM batteries:
NOCO G3500 3.5A - £50 or cheaper on eBay
NOCO Genius 5A(newer version) - £65 @ Halfords/eBay.
Think it's just the charge rate between them, few mentions on M3/4 owner forums for the G3500 so may settle with that my self.
Will read into it a bit further, car survived well last summer over 46 days when in LA so probably could ride this out, but @ £50-£65 for peace of mind and avoidance of a battery replacement/coding worries will just grab one.
      04-06-2020, 10:39 AM   #50
Hooded
England
1669
Drives: F30 330d M-Sport
If you only keep the car around 3 years hopefully you won’t need to replace it
During lockdown just follow your mechanics advice .. long way round to supermarket
isleaiw18741.00
      04-06-2020, 10:57 AM   #51
MashinBenzin
MashinBenzin's Avatar
8443
Drives: Eiger D5
Will read into it a bit further, car survived well last summer over 46 days weeks when in LA so probably could ride this out, but @ £50-£65 for peace of mind and avoidance of a battery replacement/coding worries will just grab one.
Yep, I bought the Genius 5 last week. It restored the Auris battery from sub 25% in a matter of hours and had been maintaining it since (it wakes up once a day to check/charge iirc) and has the oomph to deal with the Disco battery too. Simple little thing that seems to have all the features of the marginally more expensive ctek.
Drives - 2020 LR Discovery HSE-L
Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE
      04-06-2020, 11:37 AM   #52
EvilDrPorkChop
EvilDrPorkChop's Avatar
Drives: Porsche Cayman
Neighbours G20 330e was playing up today, reckon it's cause she's just been running about on sole electric and not charging the 12v battery - it started shutting down systems etc. Maybe Tengocity can shed some light on this? Same happened to you yet?
      04-06-2020, 11:46 AM   #53
Scoobyd
Scoobyd's Avatar
1950
Drives: E46 330ci Sport / Macan GTS
Agree. Mine's connected outside currently. Have it connected to the positive charge nut under the bonnet with a sponge on top of the cable to stop the weight of the bonnet cutting through it!
      04-06-2020, 12:09 PM   #54
NISFAN
NISFAN's Avatar
Drives: BMW M2
This you isleaiw
      04-06-2020, 12:31 PM   #55
isleaiw1
This you isleaiw
Nope - but I do head on that stretch of M1 very often!
Groceries are definitely cheaper up north...
      04-06-2020, 12:57 PM   #56
Tengocity
Tengocity's Avatar
Scotland
8566
I'm not sure that makes any sense to me. The 12v battery on BMW hybrids is topped up from the high voltage system, so it should always be fully charged. I expect to avoid this exact type of situation.
They have designed them to be fine if engine isn't used for a long time, for example the petrol tank is pressurised to stop the fuel going off if not used for along time.
      04-06-2020, 01:02 PM   #57
EvilDrPorkChop
It did all point to a flat 12v battery (Windows wouldn't go down, mirrors wouldn't fold out) maybe it was just a blip. But after a run with the petrol engine all appears fine now.
Don't think it's been run on petrol for 3 week.
      04-06-2020, 01:04 PM   #58
Tengocity
Tengocity's Avatar
Scotland
8566
Very odd. I don't think our one has used it's engine in almost 4 weeks now, and no problems thus far.
      04-14-2020, 02:34 PM   #59
MashinBenzin
8443
Drives: Eiger D5
This is Land Rover's official advice in an email I received today
To build up sufficient charge in the battery, it is recommended that you turn on your vehicle once every seven days. In the first instance, start your car for a 30-minute period, with the heat in the cabin set to 22 degrees. Repeat this process for 15 minutes, once every seven days in the weeks thereafter, to ensure the battery is maintained.
      04-14-2020, 02:43 PM   #60
isleaiw1
Does the heater go up to 22 degrees?? Or is that JLR speak to stop it overheating....
      04-14-2020, 06:31 PM   #61
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
It's been my experience that a car's electrical system is not spinning fast enough to charge the battery at idle. The RPM's have to be higher to allow the alternator to generate properly. Ever notice how your headlights brighten up when you blip the throttle? That's telling you your battery is low and the alternator can't produce enough at idle to run the car and charge the battery at the same time.
A trickle charger is the way to go if the car is to be stored.
I'm not completely useless, I can be used as a bad example.
      04-15-2020, 07:28 AM   #62
TodmordenLad
Drives: Audi A4 Avant
That's interesting advice from LR, MB, and not what I would have expected to hear, tbh. I always remember a bloke from the AA telling me years ago never to idle the car as it just puts a strain on the battery starting it in the first place and then not driving it doesn't do the engine a lot of good either.
I think the consensus on here is that a smart battery charger is the answer - which you've got anyway, I believe?
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
      04-15-2020, 07:37 AM   #63
MashinBenzin
8443
Drives: Eiger D5
I thought it was odd advice too, counter to everything I understood. I guess they know that this works though, and something in the specific temperature setting makes a difference.
I will be sticking to the smart charger! Must get the disco connected up at some point.
      04-21-2020, 08:28 PM   #64
Hooded
England
1669
Here you go Gents ..Scotty will help you look after your cars during lockdown ..
      04-22-2020, 07:07 AM   #65
Abzynthe
Abzynthe's Avatar
Drives: BMW 440i Gran Coupe LCI
I have a charger that says up to a 2 litre, but I have a 3 litre. Will it be ok to use?
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3)
      04-22-2020, 09:22 AM   #66
Watsey
Charger, or jump starter ?
I'm not aware that chargers are sold on the basis of engine size. Battery capacity and type (i.e. AGM), yes, but not engine size.
battery, batteryagm
