07-22-2019, 08:02 AM | #2377 | |
Rep 1,499
I'm on v76 and no problems flashing on my end. I"m using a homemade WiFi agent and iPhone X.
Anyway, I'm just looking for some feedback here. I was wondering if you guys could take a look at a few logs with me for comparison. This is on my F30 N55 EWG. I've been testing the Stage 2 E30 v6.4 map so took a log over the weekend. I think it looks pretty good but did notice a knock event, similar to the knock event I saw on the 93 octane v6.4 map. For comparison, I took a log of the 93 octane stage 2 v6.3, and I didn't see a knock event. Just wondering if the single knock event on the v6.4 maps is something to be concerned about. The logs are titled so you know which is which. Stage 2 v6.4 93 octane http://www.bootmod3.net/log?id=5d077e0dae729b541fbd391c Stage 2 v6.3 93 octane http://www.bootmod3.net/log?id=5d0cca0eae729b66bd2152d0 Stage 2 v6.3 E30 http://www.bootmod3.net/log?id=5d337b7dc090c63991f042dd Quote:
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 07-22-2019 at 08:07 AM.. |
07-22-2019, 09:05 AM | #2378 |
Rep 151
I was able to install the following on my EWG 535i 8AT. Cross posting here since not much traction in the F10 forums.
GPlus FMIC VRSF Downpipe NGK 97506 gapped at .020" BM3 stage 2 91 octane v6.4 92 Octane Shell gasoline The ambient temp was in the 90's. I beat on the car quite a bit and into 4th the temps were rising even with the FMIC. In 3rd the temps dropped slightly. I am still learning how to read these logs. It appears no knocks, iat was a bit high. Timing appeared to be all over the place. Can someone help me analyze these and explain if they are OK or not? What else should I be looking out for? http://www.bootmod3.net/log?id=5d34f37dae729b2135acc98a http://www.bootmod3.net/log?id=5d34f2d7ae729b2135acc986
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
07-22-2019, 08:58 PM | #2379 | |
Rep 1,375
-Nick |
07-22-2019, 09:35 PM | #2380 | |
Rep 2,357
(A Dane in China) |
07-22-2019, 09:57 PM | #2381 | ||
Rep 151
I'm currently flashed stage 2 though. I do see the knock on the flash now at 4600. Any other insight? Car still adapting? Only have driven it about 10 miles since flash.
07-23-2019, 06:56 AM | #2382 |
Rep 1,499
Yeah everything looks good except for that one knock event. I wonder if that's just a phantom knock. This log was run with 3.25gal of E85 and 12.75gal of 93oct, which calculates out to an E25 mix and 95.4octane which seems to be a sweet spot for me. Going up to 4.25gal E85 and 11.75gal 93oct only gains me 0.8 octane points (96.2octane) and my HPFP has had issues keeping up with that much ethanol in the past. I might try 3.75gals of E85 and log to see how the HPFP does.
07-23-2019, 07:01 AM | #2383 | |
Rep 1,499
Looks good for 91octane. I would configure your logging parameters and add ambient temp. This will let you know how well you FMIC is performing. The good news is your IATs drop throughout the pull so that's good.
07-23-2019, 08:17 AM | #2384 | |
Rep 1,375
07-23-2019, 11:01 AM | #2385 | |
Rep 221
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
07-23-2019, 11:17 AM | #2386 | ||
Rep 151
What makes this log look ok for 91? Trying to gain some more knowledge as I log regularly in the future and if I'm okay to start opening her up for an autox later this month. Timing does not look smooth like other people's logs that I've seen and the throttle closure concerns me!
07-23-2019, 03:08 PM | #2387 | |
Rep 151
Gas in the Seattle area is consistently 92 octane at the pump. Somewhat shocking that it's not OK to run a 91 tune. Trying a different gas station today, but still concerned that I have to go to a specific gas station every fill-up. Any others in the Seattle area have this issue? |
07-23-2019, 04:04 PM | #2388 | |
Rep 1,499
Well learned something there. PTF is probably concerned that your timing is all over the place and tying that back to your octane. They have a 91 AC (Arizona, California) map which is a bit less agressive that your could try.
07-23-2019, 04:37 PM | #2389 | |
Rep 151
Hoping it was just the gas station I used, but I thought I could feel comfortable with Shell. Really wish we had some e85 or better gas in my area. There is one gas station that sells 100 octane, but its $11 a gallon. |
07-23-2019, 04:48 PM | #2390 | |
Rep 1,375
07-23-2019, 06:06 PM | #2391 |
Rep 151
07-23-2019, 06:54 PM | #2392 |
Rep 100
Did a third gear pull after going stage 2 91 octane. The graph shows that I'm not hitting my boost target by a quite a bit 11.5 vs 15 psi. Can anyone provide some insight as to why this would happen? Im at 42k miles with IC, DP, CP, Intake, 8AT. The timing looks a little wonky too.
I hope I cropped it down to the the 3rd gear pull and removed the rest of the drive: http://www.bootmod3.net/log?id=5d31d151ae729b5e34066692 |
07-24-2019, 08:20 AM | #2393 | |
Rep 470
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
07-24-2019, 08:31 AM | #2394 | |
Rep 1,499
Log a 3rd gear pull from 2500 RPM to redline. Your 3rd gear pull starts just over 4800RPM.
Yes you are correct in that you are not hitting your boost target by quite a bit. You may have a boost leak. You can perform a pressure test on the charged air plumbing to see if you hold pressure. You may be able to identify a leak if its big enough just by listening for an air leak. If not, you may need to perform a smoke test to locate the leak. Quote:
DeeM5527.50 |
07-24-2019, 09:07 AM | #2395 | |
Rep 1
07-24-2019, 09:15 AM | #2396 | |
Rep 151
There are two pulls within this log. This is with Chevron 92 instead of Shell. First pull looks a ton better. Second pull later in the log doesn't look as clean. Ambient temp didn't show up for some reason, it was about 65° this time. Need some good feedback from PTF and others and would rather give up 10hp for consistent and always reliable tune. (If that is the case or is this going to be reliable?)
07-24-2019, 12:30 PM | #2397 | |
Rep 100
07-24-2019, 01:11 PM | #2398 | |
Rep 1,499
Make sure the IAT channel is toggled to on in the configuration settings whcih is found under the datalogs tab. Just having IAT on your dashboard doesn't mean it will captured in the log.
