01-14-2019, 10:48 PM | #1 |
Rep 46
Drives: 2017 BMW 340i xDrive
Aftermarket Brake Pads for 340i?
Does anyone know if the 335i brake pads are the same as the 340i brake pads? I was on ECS tuning and most of the brake pads that fit the 335i says that it does not fit the 340i...
I've looked through the forums and couldn't really find the answer I was looking for. Is there any recommendations for aftermarket brake pads for the 340i (blue m-sport brakes)? I don't track my car and only occasionally drive spiritedly. Looking for something that doesnt squeel as hard as the OEM ones, and preferably less brake dust. Thanks! Last edited by bmwzen621; 01-14-2019 at 10:54 PM.. |
01-14-2019, 11:42 PM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
Hawk and EBC are good aftermarket options.
To compare part numbers between the 335 and 340 use www.realoem.com
01-14-2019, 11:57 PM | #3 |
Rep 10,249
My 2017 BMW 440i GC has M Sport brakes. After 17K miles, no squealing sounds.
Akebono Ceramic brake pads are worth exploring. Brake pads and rotors do not like to coexist. Brake pad with a harder compound will eat the rotor faster. Softer pad will generate more brake dust while increasing rotor life. |
01-16-2019, 10:46 AM | #4 | |
Masterchief
354
Rep 1,003
Akebono euro ceramic 1880 should fit the brembo fronts, I'm not sure about the rears since I have the single piston rear. I got a set for 90$ on rock auto
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-16-2019, 12:36 PM | #5 | ||
Rep 10,249
Will be worthwhile to pay closer attention to rotor erosion with ceramic pads now 'coexisting' with rotors. |
01-16-2019, 01:13 PM | #6 | |
Masterchief
354
Rep 1,003
i put on r1concepts geomet slotted and drilled rotors. you should always be checking your rotors and pads for wear
01-17-2019, 10:56 PM | #7 |
Rep 1,934
All the four piston brembo, regardless of color or rotor size, are exactly the same caliper and pads. It's still an F30. They're actually the same set of brakes on the F80 and M4, and M2.
01-21-2019, 06:37 PM | #8 |
Rep 46
Thinking about the Hawk HPS 5.0.
My rotors currently only have 30,000KM on them (18,000 miles). Do you guys think they might require replacing? I would say I do 90% city and 10% highway. |
