05-22-2024, 03:25 PM | #1 |
Rep 73
Drives: 440i XDrive
440i F32 big brakes
So I'm starting a bunch of upgrades now and currently want to get bigger brakes, mainly because my current stock non m sport ones are rusted everywhere.
Also going to be increasing power to stage 2 eventually so seems like big brakes is the best option. My euro shop is looking for M sport blue caliper ones used but so far no luck. My question is are there any other alternatives that perform as well for same size brakes? |
05-25-2024, 01:38 PM | #3 |
Rep 157
For M-Sport brakes:
https://f30.bimmerpost.com/forums/sh....php?t=1747129 For the even larger M-series brakes: https://www.1addicts.com/forums/show....php?t=1905900 Both of these use the same calipers. If you can find them used at a reasonable price and rebuild them, that's the way to go. If you can't, the M-Performance kit is probably the best path, but blue calipers aren't available (same caliper but different colors).
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
Grassimo13.50 |
05-25-2024, 04:12 PM | #4 | |
Rep 73
Drives: 440i XDrive
05-25-2024, 08:26 PM | #6 |
Rep 157
The front blue calipers are available in both 340MM and 370/380MM. The base front brakes on a 440i would have been 340MM. Please check the casting information on the back of the caliper to see which size they're for.
Grassimo13.50 |
05-25-2024, 08:42 PM | #7 | |
Rep 73
Drives: 440i XDrive
They are selling me Zimmerman disks and akibono pads iirc |
05-25-2024, 09:27 PM | #8 | ||
Rep 4,514
because the 370mm diameter has more mass, it is better for managing heat while circuit tracking, however if you aren't doing that 340mm is plenty for spirited w/ocnl dig race, as it's using the same pads. however if you like the 370mm aggressive appearance behind the spokes, i understand. Quote:
Grassimo13.50 |
05-25-2024, 09:35 PM | #9 | |
Rep 73
Drives: 440i XDrive
And yeah I really want the bigger disks for look as well, I prefer when the wheel is filled fully or close too. Also my current ones have rust all over in the back and they said they can't powercoat those because they're open calipers or something? I much prefer them for looks anyways as well as getting a bit better performance so I'm ok with that. Hawk streets are the best pads? |
05-25-2024, 10:03 PM | #10 | ||
Rep 4,514
05-25-2024, 10:06 PM | #11 | |
Rep 73
Drives: 440i XDrive
I'll look into the pads in that case, but what other option would you recommend for disks? |
05-25-2024, 10:19 PM | #12 | |
Rep 4,514
some other rotor options are bmw genuine plain 370mm or M-performance dimpled+slotted. they are lighter and cost a lot more than zimmerman, though. if you go on ECS tunings site and insert your car, you can see other rotors available. also you'll need to see what calipers you have. if your shop got them from a 340/345 setup you'll need different caliper brackets to run the 370mm rotor. the brackets essentially move the caliper radially outward 15mm to accomodate the 370mm diameter. |
Grassimo13.50 |
05-25-2024, 10:28 PM | #13 | |
Rep 73
Drives: 440i XDrive
And I'll be adding springs and bilstein coilovers eventually, will that help with the higher weighted zimmerman disks? Thanks a bunch for all the info btw man, super helpful! |
05-25-2024, 10:46 PM | #14 | |
Rep 4,514
i believe slots are slightly noisier and may wear your pads faster, but it may afford better performance from a cleaner pad face and less chance of grooving from trapped contaminants. a cross drilled only 370 would be the best, but i don't think it exists. a stiffer suspension will help offset weight but lighter is better, regardless. i'm a weight fanatic so don't worry about my opinion on weight. enjoy your bbk and post pics after install. |
Grassimo13.50 |
05-25-2024, 10:49 PM | #15 | |
Rep 73
Drives: 440i XDrive
I havent posted any pics cause of all the rust on the brakes before but after upgrades I definitely will haha. Have a good one man! |
alohasurftoad3318.00 |
05-25-2024, 11:17 PM | #16 | |
Rep 157
There are two different castings (actually, 2 right and 2 left) for the front 4-piston calipers. One casting is used for 340MM rotors and has "340" cast into the back. This caliper is available in blue and grey. The grey caliper is the base caliper on the 335i, 340i, 435i and 440i cars. The blue caliper is the M-Sport caliper on 320i, 330i and a few others. The other casting is used for 370MM rotors on non-M cars and 380MM rotors on M cars, and has "370/380" cast in the back. The blue caliper is the M-Sport caliper on the 335i, 340i, 435i and 440i cars, and is used on the M3/4 cars. It's also available in red and yellow as part of the M-Performance kit. The knuckle on the M cars moves the caliper mount 5MM away from the hub, allowing the larger rotor. There's an aftermarket adapter bracket that can be purchased for non-M cars to allow the 380MM rotors to be used. I don't know what the M2 cars use for calipers/rotors.
alohasurftoad3318.00 danb19792316.50 |
05-25-2024, 11:33 PM | #17 |
Rep 4,514
Ah...thx for the info. So the 370/380 calipers are larger. I was informed the 340 and 370 use the same pads. Is this still true?
. Last edited by alohasurftoad; 05-25-2024 at 11:39 PM.. |
05-26-2024, 12:05 AM | #18 |
Rep 157
The difference is that the mounting ears on the caliper for the 370/380 rotors are longer than on the calipers for the 340 rotors. They all use the same pistons, pads and related parts.
05-26-2024, 12:16 AM | #19 |
Rep 4,514
thanks for clarifying SD. important to divulge accurate info to those inquiring in the future.
05-26-2024, 01:30 PM | #20 |
2317
Rep 2,497
IMO if you can get the 370/345 brake set up it's worth going for.. I run this (factory fitted) on my F31 with OEM M Performance discs (slotted / dimpled) with OEM pads and have found the braking to be superb...
Yes there's a slight noise when braking hard but it's hardly there and there's a bit more dust. But ceramic coated wheels aid a lot towards that as they need a simple rinse to be clean again... But the same discs or blanks with more aggressive pads (ie Ferodo DS2500s as an example) with braided lines and a decent fluid flush and refill will soon have you're brakes working superbly... Personally I'd avoid anything EBC pads wise. They're crap and I've never had any good experience with their pads over the years. Pagid RSL29s are meant to be superb. I've never run them but a lot of folk I know who do track days in their road cars swear by them (with OEM discs or the likes of Zimmerman, ATE etc)
alohasurftoad3318.00 Grassimo13.50 |
