BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > The $89 BMW performance spoiler on my EBII M sport
      03-30-2016, 10:08 AM   #551
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
Originally Posted by RSnic View Post
WDeerfield,
Had the same problem, but I saw a post that showed how to adjust. Unfortunately, can't find post now. As I recall, it entailed, carefully removing covering from left side of trunk (as you face it), which exposed a spring connected to trunk lid and body; by moving that spring in one hole, was able to increase tension. This fixed it for me and my trunk "pops up" with comfort access.
Sorry can't find the post -- it may even be on this thread about a year ago??
Hope that helps!
That does help! thank you. glad to see someone found a solution. this forum is great.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      03-30-2016, 05:19 PM   #552
John in VA
Drives: 2015 228i M Sport
Here it is:
http://f30.bimmerpost.com/forums/sho...7&postcount=22
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      03-30-2016, 05:54 PM   #553
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Originally Posted by John in VA View Post
John in VA,
That's it.
Thanks for the assist!
Al
Retired: 2014 328i
BMW CCA
      04-06-2016, 07:18 PM   #554
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
add one more happy customer for the ebay lip spoiler
naked
spoiled
next up is the selma front splitter .. however their ebay listing says out of stock right now
Production date - 2008-04-22
      04-25-2016, 01:23 PM   #555
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
and the front splitter
      05-23-2016, 03:14 AM   #556
HitmanHearns
Drives: 14' Infiniti Q50 / 16' Audi A4
Anybody successfully order an alpine white spoiler that actually matches the car?
      06-22-2016, 11:25 AM   #557
TURBO4DR
Drives: 2012 BMW 335i
I want to order the CF one, anyone with fitment problems on the CF?
      06-23-2016, 05:30 PM   #558
lukeiswright
Luke Wright
lukeiswright's Avatar
Drives: 2012 6mt 328i
Cool
I purchased mine in matte black from emotors and then brought it to macco to color match it for around $80. Turned out great. Also, the gap in the corners is only present if you don't line up your tape to the edges completely.
      07-09-2017, 05:25 PM   #559
Dinan_Rated
DINAN SELLER
Dinan_Rated's Avatar
167
Drives: BMW X3MC X3M40i, DINAN M5 V10
anyone every order and install the carbon fiber version?
      09-21-2017, 02:54 PM   #560
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
Hey! Where did you order the front splitter? How's the fitment? How much did it cost? Thanks!
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport
      09-21-2017, 07:09 PM   #561
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
Selma on ebay
      12-17-2017, 01:10 PM   #562
Ashhong
Drives: 2014 335i
Sorry for the bump but thought people might want to know there's an eBay coupon for 15 off 75. Just got my spoiler from emotors for 73$.
Pshopapp15 must use eBay app
Also fyi they sell the f80 style lip spoiler too. Took me way too long to decide between the two
Might as well edit my post: it fits pretty well but I'm a little sad that the tape is so thick that you can see it when looking at it from the side. Pretty sure the OEM one is designed so you don't see the tape
      01-02-2018, 01:36 PM   #563
Ashhong
Drives: 2014 335i
Bump..I'm not sure how I feel about the fitment. Is everyone's spoiler sitting flush on the trunk or can you see the tape at all? Maybe I shouldn't have put the tape on the edges, and instead put it more in the middle where it is slightly indented?
      01-02-2018, 02:46 PM   #564
RSnic
RSnic's Avatar
Ashhong ,
Gotta' tell you this thread helped me a bunch -- first, when I ordered my spolier and later when I installed!
My spoiler came with tape already on the underside and a little tube of adhesive enhancer. I as I said in my previous posts, I washed the car and let it dry before I installed; then, after making with masking tape the placement of the spoiler on the trunk, I used rubbing alcohol on the trunk. Suggest you look at my earlier posts: #455 12 Jul 14 (used the bottom picture's placement); and #474 5 Aug 14.
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      01-02-2018, 04:05 PM   #565
Ashhong
Drives: 2014 335i
Ashhong ,
Hope that helps
@RSnic
Thanks for the advice, but that isn't my issue. I've placed the spoiler just fine and it sits on the trunk fine as well. My issue is that if you look at the spoiler from an angle you can see the tape that it was mounted with. This is because I put the tape on the very edge of the spoiler I think.
Do you remember where the tape was on yours when you got it? Was it along the edge of the spoiler or more towards the middle?
      01-02-2018, 08:48 PM   #566
RSnic
RSnic's Avatar
@RSnic
Ashhong ,
If I recall correctly, the tape, already on the spoiler, was offset from the edge a little (probably about 1/2-1") -- but it has been some time ago
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      01-03-2018, 08:43 PM   #567
Teefard
Drives: 2016 BMW 428i
Anyone have a link to this spoiler still? Can't find it on the f30 from emotors2000 anymore for some reason.. i told myself i would only do some simple tunes(which I got way more than expected) and no exterior mods. Well I plastidipped my grille, looking for painted reflectors and clear corner signal bulbs and now must have this. It won't stop
      01-03-2018, 10:08 PM   #568
John in VA
Is it not here?
https://www.ebay.com/sch/m.html?_odk...oiler&_sacat=0
      01-03-2018, 10:48 PM   #569
Teefard
Oh awesome, I dunno why I couldn't find it. Do you know if there is a difference between the 75 dollar one and the 88 dollar one? I'm now torn on a black one or mineral grey one
      01-04-2018, 11:44 AM   #570
RSnic
RSnic's Avatar
Teefard ,
I see that John in VA has also replied, but just in case, here's the URL for eMotors2000 eBay store: http://stores.ebay.com/emotors2000
When I ordered mine, I dealt with Kelly, who was very helpful
Good luck -- hope that helps!
Al
Retired: 2014 328i
BMW CCA
      01-04-2018, 12:55 PM   #571
Teefard
Teefard ,
Thanks. I ordered from them yesterday. Pretty excited. Went with the mineral grey to match
      01-04-2018, 12:58 PM   #572
Ashhong
Drives: 2014 335i
Looks like you found it and already purchased, but the 75$ is the new M3 style which is more like a little lip on the top of the trunk. The 88$ one is the M Performance style which sits on top and also over the side of the trunk. It's quite a bit larger
