06-22-2019, 10:16 AM | #23 |
Rep 4,876
I'd reiterate what BorneATeste said. I found the 1.6 maps a bit more binary (harsh on/off) at light throttle cruise. This just flows power smooth like stock and pulls hard.
It still locks up the seatbelt pretensioners giving you a sh*t eating grin. |
06-22-2019, 10:28 AM | #24 |
Rep 124
Drives: 2017 340i M-Sport
Flashed and took for a quick drive, agree with all above about the smooth power delivery.
3rd gear Log: http://www.bootmod3.net/log?id=5d0e43abc090c611aedbd0e8 |
06-22-2019, 11:19 PM | #25 |
Rep 345
06-23-2019, 02:27 PM | #26 | |
Rep 13
06-23-2019, 02:43 PM | #27 | |
Rep 345
e30 is a blend of e85 (corn fuel; 100+ octane) and 91 or 93 octane gas. you mix the blend until it's about 30% ethanol, and then you can run the e30 tune. http://www.georgebelton.com/E85Calculator.php for a 16 gallon tank on 91 octane; it's 4.25-4.5 gallons of e85 and 11.5 gal 91 octane |
06-23-2019, 03:02 PM | #28 | ||
Rep 13
07-26-2019, 01:58 PM | #29 |
Rep 50
Does anyone know if version 2.0 is still the latest or is there another update? I have a 2018 340i manual and I would say 1/4 throttle was full boost in v1.6 and in v2.0 it's now 1/3 throttle, so it's an improvement, but still very abrupt if you're anywhere between 2500rpm and 4000rpm. Even with the throttle cracked, the boost will just hit once you get close to 2500rpm. I also have a very slight lag after shifting and the hanging rev problem everyone seems to have where it continues to throttle a split second after letting off and pushing in the clutch.
07-27-2019, 04:25 PM | #30 |
Rep 4,876
You need revs for it to build boost (around 2500-3000RPM with part throttle from what I see is where it starts to pull). If it's hot outside and you are doing a lot of stop/go, high IAT temps well increase bottom end lag, which you'll feel as that dead spot to a sharp power transition.
BM3 just increases the power so it amplifies the stock effect of this. |
08-04-2019, 04:56 AM | #31 |
Rep 75
I have a 440 rwd, bootmod3 stage 2 version 1.6. I do 100-200 in 9.6 seconds. I see that much slower than other colleagues. (I have automatic change) how can i improve it? Do I try version 2.0?
08-05-2019, 11:51 AM | #32 |
Cheapskate
4447
Rep 4,993
Yes it's faster. You also may have other problems. Post logs and we can see if something's wrong.
11-13-2019, 08:21 PM | #34 |
Rep 115
