11-09-2019, 02:18 PM | #23 |
Cheapskate
4445
Rep 4,993
A proper big turbo kit will always be better than hybrids. I just wish I saw them offered with Garret or BW turbos.
11-11-2019, 06:23 AM | #26 | |
Cheapskate
4445
Rep 4,993
No |
11-11-2019, 04:22 PM | #27 |
Rep 676
11-11-2019, 06:29 PM | #28 |
Rep 177
11-12-2019, 06:36 AM | #29 |
Cheapskate
4445
Rep 4,993
Why is this a question? What are you trying to ask? Boost pressure isn't the only thing that determines horsepower/torque. Why pick 21 psi?
11-13-2019, 01:17 AM | #31 |
Rep 177
I've read around that for the N26/N20, people with tunes or piggybacks, usually mention that 21PSI is the boost limit that they run otherwise engine problems could happen (bending rods and cracking pistons) with higher boost limits on stock internals. I assumed it translated to upgraded turbos.
11-13-2019, 06:17 AM | #32 | |
Cheapskate
4445
Rep 4,993
I haven't seen anyone run over 22psi. I think it makes sense since there's no reason to give us a 3bar sensor when stock boost is only 10-14psi on B58s. |
Cpatel39.50 |
11-13-2019, 07:34 AM | #33 |
Rep 585
N54 stock sensors are 1.5 bar = 21.7 PSI
B58 stock sensors are 2.5 bar = 36.2 PSI Edit: B58 stock TMAP sensor is part number 13-62-7-804-742 is combined pressure and IAT with a 4 bar/400 kPa/58 PSI
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 11-13-2019 at 06:43 PM.. Reason: Incorrect sensor info |
11-13-2019, 08:03 AM | #34 |
Cheapskate
4445
Rep 4,993
The 2.5 bar value includes ambient. So it always measures 1 bar, and then you can measure 1.5 bar on top from forced induction pressure.
11-13-2019, 01:58 PM | #35 |
Rep 177
Ok so what I'm getting is that if I get a upgraded turbo while running stage 2, I'll be safe as long as I keep HP around or below 350?
If I'm using BM3, I'll need to get a custom tune and ask the tuner to keep the HP at that threshold? I've only used OTS maps so I have no idea how custom maps work. |
11-13-2019, 02:07 PM | #36 | |
Cheapskate
4445
Rep 4,993
11-13-2019, 06:45 PM | #37 |
Rep 585
Corrected error in above post. B48 and B58 stock TMAP sensor part number is 13-62-7-804-742 reads up to 4 bar and is combined IAT sensor
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
11-14-2019, 01:21 AM | #39 |
Rep 501
yes and in the intake manifold MAP sensor is 2.55bar absolute, same like in S55. But S55 works good with this combination (3.5bar sensor before throttle and 2.5bar after) until ~1.9bar then interesting things begin to happen, so in B58 case no need to change any sensors, as ~1.5 bar should be enough with upgraded turbo.
Nugget649.50 |
11-14-2019, 06:05 AM | #40 | |
Cheapskate
4445
Rep 4,993
11-14-2019, 06:34 AM | #41 |
Rep 501
it's always good to know what actual pressure you have after throttle in the intake manifold. N54 used some formulas to calculate air in the intake manifold from boost pressure before throttle and throttle position, but it's always better to know actual than calculate.
11-14-2019, 09:23 AM | #42 | |
Cheapskate
4445
Rep 4,993
11-14-2019, 09:13 PM | #43 |
Rep 41
So seems like I'm reading mixed reviews of Pure Turbos here. Keen on getting a Pure St 2 but I saw some experienced broken/bent turbo blades with Pure St 2, and this reliability issue worries me despite the customer support cos I live outside the US and claiming warranty et al might not be easy for me...
Any take on Vargas or Steam? Also I heard Big Boost is making turbos that are on par with Pure St 2 if you dont wish to go beyond 600whp like me...I drive an N55 and not keen on upgrading internals, so a power figure of 500whp is perfect for me... |
11-14-2019, 09:21 PM | #44 |
Rep 458
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
