11-03-2019, 04:28 AM | #1 |
Rep 255
Drives: F36 430d GC, XKR, Clio 172
What parts to retrofit Msport blue brakes
I might have an opportunity to strip a set of blue Msport brakes from a 320d F30.
I have a 330d F31. Other than the obvious parts, callipers, carriers, disks, stone guards etc.... what else will I need? Was the brake servo and master cylinder the same between the standard brakes and Msport brakes? Will I need to code the car? Thanks in advance.
Midnight Black Jaguar XKR Convertible | Saphire Black BMW F36 430d Gran Coupe | Iceberg Silver 2002 Renault Clio 172 Track Car
11-03-2019, 10:32 AM | #2 | |
sucka for a longroof
29
Rep 70
11-03-2019, 05:34 PM | #4 |
Rep 255
can you elaborate on this please?
What needs coding?
11-04-2019, 10:15 AM | #5 |
Not stock
474
Rep 614
What brake setup do you currently have on the car? Are they the single piston units all around?
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
11-04-2019, 12:16 PM | #6 | |
Rep 255
Standard brakes - single piston, unpainted. 340mm front Msport brakes - 4 bot, painted blue, 370mm front for 330d or 340mm front for lower models
11-04-2019, 01:24 PM | #7 |
Not stock
474
Rep 614
Right - so given that you have standard brakes you will need to code for S2NHA or "SPBR" in E-SYS. If you just install 4 piston front and 2 piston rear calipers on your car without having SPBR coded, the brake pedal nearly goes to the floor.
johnung4528.00 |
11-04-2019, 01:59 PM | #8 | |
Rep 5,392
A friend of mine in Europe went through a similar brake upgrade. There can be a compatibility issue with the rear parking brakes. The rear parking brakes are a drum brake design. The "drum" is actually the inside of the rotor hat of the rear brake rotor. The F30 models actually use two parking brake sizes. Most use 185mm diameter parking brakes which is what the M Sport 345mm x 24mm rear rotors have. But some of the lower F30 models use smaller 160mm diameter parking brakes. It's a very subtle difference to the eye because the rotor hats themselves are just 25mm less in diameter. If you happen to have the smaller 160mm parking brake there is a solution. Don't even think about swapping rear hubs and parking brake components. It's way too expensive and labor intensive. But there are available aftermarket rotors in 345mm x 24mm with the smaller rotor hats to contain a 160mm parking brake. If you run into that problem let me know and I can try to get you a source and part number from my friend. Hope this helps! |
11-04-2019, 02:11 PM | #9 |
Rep 255
Thanks for the info. Can you code this with the bimmercode app?
11-04-2019, 02:13 PM | #10 | |
Rep 255
Starting to sound like a pain of an upgrade. I've already decided to take a miss on the 320d brakes as they will only be 340mm. But now it sounds like I will have the wrong parking brake set up as well as mine just has the small brakes as standard. How would I check which parking brake set up I have? Oh but at least I already have the 19" wheels. I think all Msport models in the UK came with 18" minimum size
11-04-2019, 02:30 PM | #11 | |
Not stock
474
Rep 614
That, and some cars have a small rear rotor shield that won't fit over the 345mm rear rotors in the M perf/M sport kit. Its not as bad as it sounds. Easy to sort out once you know the caveats.
11-04-2019, 03:15 PM | #12 | ||
Rep 5,392
Odds are that you have the larger parking brake. I just wanted you to know what the issues were if you ran into it. See the attached photo. With your VIN you can quickly look up which of the two brake shoe sizes your car has. Definitely upgrade to stainless steel brake lines at the same time. StopTech set is only $106. Much better brake pedal feel. |
11-04-2019, 03:33 PM | #13 |
Rep 255
Ok it says mine is 185mm. So that's one less thing to worry about at least.
11-04-2019, 06:46 PM | #14 |
Not stock
474
Rep 614
yep and even if it was the smaller size there is a BMW rear dimple slotted rotor for that. I was sent it by mistake. either way though it's not horrible. no, it can't be coded via Bimmercode unfortunately.
11-04-2019, 07:00 PM | #15 |
29
Rep 70
I was under the impression only the 370mm upgrade needed coding - there's even a coding option for the 340mm upgrade from standard brakes?
11-05-2019, 03:40 AM | #16 | |
Rep 255
Whats the other program I need then please?
11-06-2019, 09:25 AM | #17 | |
Rep 5,392
The only difference is in the length of the casting since the bolt holes in the 370 calipers are 15mm further out from center to fit the rotors than are 15mm greater radius (30mm greater diameter. You would have to have a great eye to spot the difference. But if you flip the front caliper over the 340 has a raised "340" on it. The 370 front caliper has a raised "370/380" on it. (The same caliper mounts on an M car and fits a 380mm rotor, and NO you can't fit a 380mm rotor on an F30!) See attached photos. |
10-07-2020, 07:32 PM | #18 | |
Rep 74
Then i checked about rear discs, Ate and Zimmerman(150.2921.20) rear 345mm discs described as internal drum’s diameter —> 161mm. Is this the “problem” which you described? And if they say internal 161mm, does it mean that these rear discs are suitable for my 160mm drums ? Thanks for your help.. |
10-07-2020, 09:15 PM | #19 | ||
Rep 5,392
You say that you have an F20 which is a 1-Series. It sounds like from your statements and questions that the F30 and F20 may use some of the same parts. You said that you are going to upgrade to blue M Sport Brakes. BMW throws around the "M Sport" marketing label so it means different things on different F3x models. I don't really know what "M Sport" means on whatever F20 model that you have. Sorry, I have experience with F3x brakes but I don't know much about F20 brakes. |
10-08-2020, 12:21 PM | #20 |
Rep 74
Hi, it’s exactly same brakes on F20 and F30 that’s why i asked you.
The blue brakes “M sport” will be front with 340mm discs and rear with 345mm discs. Blue calipers are as mentioned four piston front ones and 2 pistons rear ones. So My only question is about the “problem” you said for rear ones where i can confirm that I have 160mm drums as real oem says.. So the solution is to fit the above discs as i explained or is anything else that i need ? |
10-08-2020, 01:26 PM | #21 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
Jeasus christ, just buy the M Performance BBK and you'll have all the hardware except rear rotors. Piecing together a kit is tedious. Coding needs to be done, it changes how fluid travels to the two piston caliper in the rears as opposed to the singles you have now.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
10-08-2020, 02:47 PM | #22 |
Rep 74
I didn’t ask about coding, I know that it needs coding.
M performance needs 18” wheels at least, I want to use 17” wheels and there is no need for me to spend the amount M performance BBK costs!! If you have any help about my question it would be helpful, otherwise your comment is completely off topic! |
Logicoeur991.00 |
