11-19-2019, 09:29 AM | #67 |
Rep 8,942
Will post a detailed write-up at some point but I worked with Technic and it is now possible to upgrade your amp and keep the OEM stock amp connected as well for CAN bus, in case the dealer ever needs to update the SW in your car. My F31 now has three amps:
1. Bimmertech for audio 2. JL for subwoofer 3. Stock HiFi for CAN bus only They are all installed all the time, so there is no need to swap anything out for trips to dealer. Install was pretty straight forward, we added some wires to the Bimmertech connector. If you are using Technic harness instead for another type of amp, you may be able to get everything in one harness - but he can chime in there.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
IK6SPEED4488.00 |
11-19-2019, 11:19 PM | #68 | |
Rep 10,473
11-20-2019, 12:06 AM | #69 |
Rep 5
I have weird voice comes out the speakers but not all the time and not with all the songs , like the song is playing good and the bass is perfect but there is something comes out like a whistle! Anybody know what is that ?
11-20-2019, 01:35 AM | #70 |
Rep 10,473
11-26-2019, 03:30 PM | #71 | |
Loc2000
Rep 10
question
thanks in advance |
11-26-2019, 04:44 PM | #73 |
Loc2000
Rep 10
So I assume that focals crossover for midrange should be set on full range once signal is already high passed?
11-27-2019, 02:33 AM | #75 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
It won’t matter, pretty sure the high pass on those is at a much lower frequency than the OEM 175hz highpass, and probably only 6-12db. At worst and at best, you will have Steeper rolloff once you get down to the aftermarket crossover point. But you are unlikely to have enough volume at that point to hear the difference.
Me, I’d run them full range and fuhgettaboudit. |
11-27-2019, 02:41 AM | #76 | |
Loc2000
Rep 10
Is that not gonna affect sound quality? |
11-27-2019, 02:44 AM | #77 | |
Loc2000
Rep 10
11-27-2019, 03:01 AM | #78 |
Great Teacher
1086
Rep 1,305
It won’t.
I used to double stack the amp crossovers with the speakers crossovers all the time back in my serious days. Mostly because amps didn’t have very aggressive crossovers back then, maybe 12db/octave, and an extra 6 in the speaker crossover was great for protecting them from a bunch of 20-30 hz sine waves in bass mechanics test sections... and Tocatta in D. There is some minor phase shift that occurs when running a passive xover in the configurations speaker crossovers you are talking about use, but there’s a bunch more phase shift when reflected off glass too.. and no one puts curtains on their windscreen and drives around. The thing is that now xovers are often 24db/octave or more... & you jsut don’t need a steeper slope. That’s why I suggested full range. |
11-27-2019, 03:12 AM | #79 |
Great Teacher
1086
Rep 1,305
To answer your question to bill above,
If the high pass were 6 dB/octave at 100hz, you get 1/4 volume at 50hz and 1/16th volume at 25hz. Just give some really terrible explanation. It’s not a filter, it’s a volume decrease. |
11-27-2019, 07:57 AM | #80 | |||
Rep 16,080
11-27-2019, 08:18 AM | #81 | ||||
Loc2000
Rep 10
Thanks for your time |
11-27-2019, 11:32 AM | #82 |
Rep 16,080
One thing you haven't mentioned is the knee frequency of the high pass. I wouldn't want it higher than 125Hz. There's no problem testing it because the door panel doesn't have to be in place to do that.
11-27-2019, 03:49 PM | #83 |
Great Teacher
1086
Rep 1,305
Apologies that I misread he was not using the factory amp, when he is. In that case turn the xovers on.
12-15-2019, 01:16 PM | #84 | |
Loc2000
Rep 10
I have installed them focals. Ive set passive crossovers which comes with speakers on 0db for tweeters and they sound fine. For midrange I set it on highPass (hiPass/fullRange switch on crossovers) and I tested em on various frequencies. I have noticed that whilst I play test tones of around 300hz and bellow volume decrease is significant (250hz I can clearly hear rear stock speakers more than front focals). That indicates that crossover point of factory amp is lower than passive focal crossovers . Shall I switch passive focal crossovers on full range in this case and let factory amp to attenuate midranges at lower point than passive do ? Or its just a matter of taste? Thanks |
12-15-2019, 04:32 PM | #85 |
Rep 16,080
If you're losing output below 250Hz then you're going to have a response hole between where the under seats are working and the mids are working. That wouldn't suit my taste. Try them full range, see what happens.
12-16-2019, 12:07 PM | #86 | |
Rep 13
Thanks |
12-16-2019, 01:09 PM | #87 |
Rep 16,080
I don't know if it's high passed but it is EQ'd, which amounts to more or less the same thing. Measured nearfield my under seat woofers peak at 60Hz with a curve that looks like band pass, with a low frequency roll off below 60Hz steeper than the acoustic roll off of the speaker alone would explain. The only way to get a full band width signal to a sub amp is to capture it before it's processed by the stock amp. I don't know if the Technic harness does that. I'm not interested in a separate sub, it's not worth the bother with the classic rock I listen to, so I've never investigated the Technic beyond what I've seen posted here. If it is taking the signal post processing then it would have to be compensated for in the sub amp if it has that capability, or by a separate EQ placed before the sub amp input.
Johnny Chuttz9.00 |
12-17-2019, 11:39 AM | #88 | |
Rep 13
