10-26-2018, 09:56 PM | #1 |
Rep 39
Buying 2015 4 grand coupe
I知 getting ready to buy a used f36 428 x grand coupe. I love the style and trying to just get my head on straight. I知 trying to just lower it for a good stance that痴 an everyday driver and rims to compliment. I致e been away from bmw for a while and really need some help with direction. Pics and suggestions would be much appreciated.
10-27-2018, 06:02 AM | #2 |
Rep 10,251
What year is the vehicle?
The Suspension forum has many threads discussing three main options: - Lowering springs with stock shocks - Lowering springs with aftermarket shocks - Coilovers What's your budget for the suspension upgrade? |
10-27-2018, 09:57 AM | #4 |
Rep 247
My suggestion is coilovers. You're going to spend 8-900 on a spring/shock setup that wasn't designed for eachother and the drop my not look like you wanted it to or ride extremely harsh. Get a set of KW's and don't look back.
10-27-2018, 11:05 AM | #5 |
Rep 3,468
If it has active suspension, you can buy ACS springs for it and get the Dinan shockware. If not, you are kinda screwed because you'll be over-powering your dampers with lowering springs. The issue here is that BMW never made an "aggressive suspension" X-drive, in fact, the X-drive is "lifted" compared to the non-x-drive models. I also added dinan sway-bars to help with the excessive body-roll. With good tires, I really liked how my mods turned out, but it was sad that it was the way the car should have came from the factory. Your other realistic option is coil-overs, because you can match the damping rate to the springs. There weren't a lot of aftermarket suspension parts made for the 4-series x-drive GC, so I had to wait and wait for some of these parts to become available. Maybe there are more now. I'd only buy the lowering springs from Dinan and ACS, the other companies offering them don't seem to tune them to your cars exact configuration (engine, x-drive, etc.) which means you may encounter bottoming and damage issues from something that is a "one-size-fits-all" product.
Since you haven't bought it yet, I'd heavily consider the above. I spent a lot of money making the suspension do what I felt it should have done out of the factory, that means maybe you'd be better off buying something else, maybe a new 430 non-x-drive GC or 340, Jag equivalent, or other. Since you live in Ohio, some winter tires would do you just as well as any x-drive model.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
10-27-2018, 05:55 PM | #6 | |
Rep 39
10-28-2018, 01:26 PM | #8 |
Rep 10,251
If you are still exploring xDrive equipped vehicle, KW offers KW Street Comfort coilovers.
https://www.kwsuspensions.com/produc...coilovers.html I had these coilovers on 2013 BMW 335i xDrive sedan. Highly recommended. |
10-28-2018, 08:59 PM | #9 |
Rep 39
So yes I pulled the trigger. I知 very happy with it. Trying to figure out how to put pictures up. Says files are to big need to dial down resolution. But it痴 white 328 I xdrive. Not fully loaded or anything. But I知 happy with the purchase. Got it with 32k+ on the odometer for 25k out the door. Wish it had the cameras but the car is small enough that I can live without. The heated steering wheel is what I知 really happy with.
10-28-2018, 11:11 PM | #10 |
Rep 3,468
Right? Those are so nice.
11-15-2018, 11:11 AM | #11 |
Rep 39
[QUOTE=JamesNoBrakes;23908833]If it has active suspension, you can buy ACS springs for it and get the Dinan shockware. If not, you are kinda screwed because you'll be over-powering your dampers with lowering springs. The issue here is that BMW never made an "aggressive suspension" X-drive, in fact, the X-drive is "lifted" compared to the non-x-drive models. I also added dinan sway-bars to help with the excessive body-roll. With good tires, I really liked how my mods turned out, but it was sad that it was the way the car should have came from the factory. Your other realistic option is coil-overs, because you can match the damping rate to the springs. There weren't a lot of aftermarket suspension parts made for the 4-series x-drive GC, so I had to wait and wait for some of these parts to become available. Maybe there are more now. I'd only buy the lowering springs from Dinan and ACS, the other companies offering them don't seem to tune them to your cars exact configuration (engine, x-drive, etc.) which means you may encounter bottoming and damage issues from something that is a "one-size-fits-all" product.
Since you haven't bought it yet, I'd heavily consider the above. I spent a lot of money making the suspension do what I felt it should have done out of the factory, that means maybe you'd be better off buying something else, maybe a new 430 non-x-drive GC or 340, Jag equivalent, or other. Since you live in Ohio, some winter tires would do you just as well as any x I would like it to look even all the way around and sit just above the tire. Suggestions on how much of a drop I知 looking for front and rears |
11-15-2018, 11:17 PM | #12 | |
Rep 3,468
[QUOTE=rkcruiser;23994591]
11-18-2018, 05:47 PM | #13 | |
Rep 39
[QUOTE=JamesNoBrakes;23997650]
11-19-2018, 11:44 PM | #14 | |
Rep 3,468
11-20-2018, 12:30 AM | #15 |
Rep 190,687
Congrats
