11-17-2018, 11:08 AM | #23 |
Rep 596
Do yourself a big favor and get a square set of Nokian Hakkapelita R2 or R3 winter tires online here:
https://www.tiresbyweb.com/m-108-nokian-tires.aspx Up to 6 months a year of snow and ice; we don't #%* around.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option Last edited by dkreidel; 11-17-2018 at 11:18 AM.. |
Machinebuilder278.50 |
11-17-2018, 01:29 PM | #24 | |
GasCompressor
333
Rep 564
I digress, the Nokian tires are excellent however they are only R (106 MPH) or T (118 MPH) speed rated. I have the Pirelli Sottozero for the BMW as they have the right speed ratings and they are run-flats, not too many choices for run-flats, Pirelli is top rated performance with run flat tires at Tirerack.
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) Last edited by kpgray; 11-17-2018 at 01:36 PM.. |
11-17-2018, 02:07 PM | #25 | |
Rep 596
Here's a winter tire test from Car and Driver, and they don't sell tires Nokian was first, but no such thing as a free lunch; they're the most expensive https://www.caranddriver.com/feature...mpared-feature
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option Last edited by dkreidel; 11-17-2018 at 02:14 PM.. |
11-17-2018, 04:25 PM | #26 | |
Rep 4,876
17" should work fine with regular brake calipers, but 18" or larger required for m-sport brakes (some 18" rim still won't clear, you need to verify). |
11-17-2018, 10:49 PM | #27 |
Rep 8
+1 for getting a set of 18x8" square with winter tires. You'll have better snow tires, and you'll save money in the long run. I've taken my RWD 328 over 11,000' passes through snow to get to the slopes, without a hitch (on 225 Blizzaks).
11-18-2018, 11:17 AM | #28 | |
GasCompressor
333
Rep 564
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
11-18-2018, 11:34 AM | #29 | |
Rep 126
11-18-2018, 11:29 PM | #30 |
Rep 499
I've had BOTH the Bizzaks and the Xi3.
Blizzaks wear hella fast and were the most "winter tire" feeling. Xi3 was better in every way, IMO -- AND -- actually have a treadwear warranty, if I remember right. They are also the #1 studless tire recommended by Consumer Reports -- and I think they have better rolling resistance (and better gas mileage) too. Honestly though, my favorite so far, is the Pirelli Sottozero 3. I was worried about not having a runflat, but I drove the car through a massive pothole at 40mph and bottomed the suspension out -- and they were fine. These babies are STRONG. I keep them at least at 36psi (cold) -- the ride, noise levels, comfort, etc is excellent. No tram-lining whatsoever. Wear seems really good too. They plowed through a good 7 inches of snow when the city was closed and take me up to the mountain every year. I went with 225/45 18 inch. |
Solidjake945.00 |
11-23-2018, 06:58 PM | #31 | |
Rep 126
Snow Tires
11-23-2018, 09:45 PM | #32 |
2006 TIME Person Of The Year
9720
Rep 6,445
I swap my summer tires for Ultra High Performance All Season category tires in the winter. They're way better in the dry, and capable enough in the snow. If it snows that much I'm not taking the rwd F30 out anyway.
My suggestion is to be honest with yourself regarding how capable you need your F30 to be.
11-24-2018, 06:11 PM | #33 | |
GasCompressor
333
Rep 564
In a nutshell, only a couple days a year max the F30 does not have the clearance to drive for conditions in SE Michigan.
11-24-2018, 08:34 PM | #34 | ||
Rep 16,081
11-24-2018, 08:55 PM | #35 | |
Rep 3,947
An AWD sedan with snow tires will still get stuck in snow due to its low ground clearance. The best solution for deep snow is to have an AWD/4WD SUV/pickup with studless snow tires. Not much beats a heavier vehicle with ground clearance + studless snow tires in deep snow and ice. If you're driving at highway speeds for a long distance commute 40+ miles on hard packed (not deep) snow, then I would prefer a low center of gravity AWD sedan + studless snow tires. It's easier to control at the limit. |
11-24-2018, 09:02 PM | #36 |
GasCompressor
333
Rep 564
The dealer is not the only one who does this, our local major retailers here are the same. It's the liability factor, if you drive your car faster than the tires rated speed, and the tires fail during one of these spirited drives, the liability lawyers will go after the tire manufacture who will locate the installer for their lack of due diligence! Yes, it's BS, that's why next time I would go to the small independent shop.
11-24-2018, 09:16 PM | #37 |
Rep 16,081
The minimum winter tire speed rating you can buy is Q, 99 MPH. That is well over the speed limit. You are being hosed. Do they pull that same nonsense on minivan owners? Kia Rio owners? How about Toyota Yaris? Or do they just do it based on the cut of your jib?
11-25-2018, 02:28 PM | #38 |
GasCompressor
333
Rep 564
I understand what you are saying, I am just telling you my situation. I bought from the dealer as I wanted the BMW rims and they gave me the tires under Tirerack advertised price. The three places I went to all performed some due diligence, the dealer knew the speed rating of the car, second place pulled the vehicle up on their computer and said they would not sell me the lower rated tire and the third looked at my existing tires and said they would only replace with same rated or higher. That is why I said I would go to an independent shop next set. I can also tell you the speed limit in Michigan away from the cities is now 75 MPH and people are always 10-15 over. I frequently get passed going 85+.
11-25-2018, 05:40 PM | #39 |
Rep 16,081
I hear what you're saying too, and it's still BS. How many cars are not capable of 100 MPH? None of those shysters would have been rewarded with my business. I had a tire chain pull one on me when I wanted to buy just two snows for my in town car. They said they wouldn't sell me only two snows, they'd only sell me four. I replied that they weren't going to sell me any and went down the street to the next guy. He, rightfully, explained why I should consider getting four snows, I explained why I only wanted two, he agreed and he got my business, not just that time, but for all time.
