04-12-2021, 02:09 PM | #573 |
Rep 532
04-18-2021, 01:34 AM | #575 |
Rep 532
Nice time
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
04-18-2021, 10:09 AM | #576 | |
Rep 415
Where are you getting your Ethanol from in the UK? Seems like supply is pretty low just now. |
04-19-2021, 06:36 PM | #579 |
Rep 420
30l 100Ron + 20l E85 + WMI
M140IX. Turbo Pure 800 Cast.
04-21-2021, 12:30 AM | #580 |
Rep 255
04-21-2021, 05:55 AM | #581 |
Rep 532
8.5 sec 100-200 with pure turbo 800 and E40... something must be wrong , at least with the right map you should easy get a low 7
04-21-2021, 12:49 PM | #582 | |
Rep 255
This run was also on D sports plus just sending it. Maybe S mode manual mode might give me better times. |
04-21-2021, 12:54 PM | #583 | |
Rep 532
04-21-2021, 01:16 PM | #584 | ||
Rep 255
04-21-2021, 01:24 PM | #585 |
Rep 532
that explains i think , Pure turbo 800 needs at least the Dorch stage 1 pump and if running with more then E40 meth Dorch stage 2. what map you are running now ( make a log if possible, it should show a lot )
04-21-2021, 01:59 PM | #586 |
Rep 3,832
I'm reading here and reading... and wondering - when does the B58 break!? I mean how much boost and fuel and, and, and does it take and how are you not worried it will just burst in flames with all those mods..... 😄
I've seen impressive times from engines.... which are achievable only once or twice, before the Big Bang ... but what's the point? I'm sure I can fly..... but only once....
WrxToBeamerGuy490.00 |
04-21-2021, 03:47 PM | #587 | |
Rep 255
https://datazap.me/u/alfanzo2/pure-8...&data=3-20 Log above is my last revision. First pull spun sideways so had to stop but 2nd pull should be a full 3rd. I also have full 4th gear pulls near the end as well. Tuner says I'm maxed out for my fuel right now on this revision. |
04-21-2021, 07:06 PM | #588 | |
Rep 420
04-22-2021, 01:19 AM | #589 | |
Rep 532
04-22-2021, 10:01 PM | #590 | ||
Rep 255
As for the HFP option, I do not see any option to add that to the logging and I am on the most updated MHD version. |
04-23-2021, 01:32 PM | #591 |
Rep 1,367
He said 8.5 60-130 mph, not 8.5 100-200 kph. So his 100-200 likely is in the 7.2x range.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
04-23-2021, 02:53 PM | #592 |
Rep 532
yep you.re right, my mistake
04-24-2021, 01:18 AM | #593 |
Rep 49
Interesting that 2+ power drops off so similarly to stock. Anyone know why that might be? Is it fueling due to the bare minimum hpfp? Turbo limitation, maybe?
2018 340i
04-24-2021, 03:23 AM | #594 |
Rep 3,832
According to a fellow forum member, it is the stock turbo which gets to its limit at higher rpms....
https://f30.bimmerpost.com/forums/sh....php?t=1819572
