05-18-2020, 08:22 PM | #1739 |
Rep 31
Help
Hey guys,
I picked up a set of new wheels. The rears are 19x11 +25 and I'm currently lowered on coilovers. I did test fit and slight pull on the rear fenders. I plan on running 255/35/19 tires, do you guys think it'll rub? I maxed out the stock camber arms to -2.61. I also order a set of Megan rear arms but I have to wait 2 weeks for them to come in. |
05-19-2020, 08:09 AM | #1740 | |
Cheapskate
4445
Rep 4,993
05-19-2020, 03:07 PM | #1741 | |
Rep 60
05-20-2020, 05:51 PM | #1742 |
Rep 295
Seeing more bbs rsii on here
MISY2K11.50 DThr33634.00 HondaGoneRogue432.50 Sedan_Clan24977.50 TBMNYS12.00 BMW BRAD202.50 WordOnRoad313.00 |
05-23-2020, 01:43 PM | #1743 |
Rep 11
View post on imgur.com HRE FF04 19x9 et44 squared — 15mm spacer front, 12mm spacer rear (so et29 and et32, respectively) Nitto Motivo 245/35 BC Racing Coilovers About -1.8 - 2.2 camber all around. Definitely has 3-5mm of clearance to the fender. Front is maybe 5mm from the strut. |
05-23-2020, 01:48 PM | #1744 |
Rep 7,591
05-23-2020, 04:26 PM | #1745 |
Rep 295
05-24-2020, 05:45 PM | #1746 |
Rep 117
05-24-2020, 06:57 PM | #1747 | |
Rep 295
[QUOTE=LaNcE01;26219892]
My handle is a discount code And yessir |
SteveInfante604.00 |
05-29-2020, 05:38 PM | #1748 |
Rep 22
2013 335i
-BC Coilovers -ESR CS15 19x9.5 +22 / 19x10.5 +22 -NANKANG NS25 235/35/19 & 255/35/19 -Megan camber and toe adjustable arms Fronts came out to -2.2 (iirc) Rears are -4.7 Last edited by Marlon671; 05-29-2020 at 05:57 PM.. |
06-20-2020, 01:53 AM | #1749 |
Rep 505
Vossen Hf5 gunmetal. 20x9 & 20x10. 275/30/20 & 245/35/20
KW Street Comfort Coilovers Last edited by vortechvr6; 06-20-2020 at 02:04 AM.. |
Amarphoolka144.00 TBMNYS12.00 |
06-26-2020, 03:49 PM | #1751 |
Rep 10
07-05-2020, 10:13 PM | #1752 | |
Rep 22
07-08-2020, 02:05 PM | #1753 |
Cheapskate
4445
Rep 4,993
07-10-2020, 07:08 PM | #1754 |
Rep 11
I've had air lift for over a year now, I finally got around to buying wheels. No crazy specs, this car is my DD.
Fronts: 19x8.5 et30 225/40 Rear: 19x9.5 et42 255/35 I will probably be adding spacers to get better fitment after I get an alignment, then some better pics. |
kern4174445.00 |
07-11-2020, 09:57 AM | #1755 |
Rep 463
Hey fellas, stupid question - for those of you running Volks - I assume the stock lug bolts work/fit just like they do for pretty much all other 5x120 wheels out there? Seems like the most aftermarket wheels work the conical 60 degree BMW bolts. I have a set of OG CE28n's I am trying to pick up and I don't really want to mess with doing a stud conversion.
4ffc36f91f25b465d4f1b46281b47925 by theezv, on Flickr Last edited by theEZV; 07-11-2020 at 11:24 AM.. |
07-11-2020, 02:05 PM | #1756 | |
Rep 2,152
07-11-2020, 03:42 PM | #1757 |
Rep 463
Interesting... so the stock lug bolts are 25mm wide overall. I just looked at my other set of aftermarket wheels and the lug hole is 30mm wide, and is able to clear my lug nut socket by a hair. I'll see if I can have the seller measure the hole size on the CE28s.
07-23-2020, 11:18 AM | #1758 |
Rep 29
Been a minute but figured I'd check back in
kern4174445.00 ThatF30Kid3.00 Alpine-F80200.50 justanthony14.50 iron_mike_6.00 Stlthnmrdrd156.50 Kevin_Trxn603.50 BMW BRAD202.50 mpellicer72.00 |
07-23-2020, 01:34 PM | #1759 |
Cheapskate
4445
Rep 4,993
Finally found a gas station with decent lighting
DThr33634.00 iron_mike_6.00 |
07-30-2020, 08:03 PM | #1760 |
Rep 12
Fitment finally dialed in. Apex arc-8s with KW V2
F32 435XI- Apex Arc-8, KW V2, VRSF CP/FMIC/DP, GFB DV+, 335is/550i clutch kit, N20 TMAP, 22psi custom tune
kern4174445.00 Amarphoolka144.00 TBMNYS12.00 F30_SixSpeed1170.50 Expert@ApexWheels3511.00 aps335.50 philip_pino9.00 Alpine-F80200.50 KendrickOak358.50 5w20280.50 obzen188.00 WordOnRoad313.00 pluo6166.00 |
aggressive, f30, low, slammed, stance |
