09-20-2020, 12:53 PM | #199 | |
Rep 495
The better quality fuel will go much further to lifting all OCI/UOAs across the board, and could eventually put the US on the path to running extended drain intervals of 2yrs as in Central Europe. |
09-20-2020, 01:19 PM | #200 |
Rep 16,054
ULSD has been used in the continental US since 2006, in Alaska since 2010. After 2010, EPA’s diesel standards required that all highway diesel fuel supplied to the market be ULSD, and all highway diesel vehicles must use ULSD.
BMW had pretty much nothing to do with that, nor any other car make, as the vast majority of diesel usage in the US is in trucks and buses. |
09-20-2020, 01:23 PM | #201 | |
Rep 10,346
"Drive more, worry less. "
09-20-2020, 03:00 PM | #203 | |
Rep 495
At any rate, lower sulphur fuel should ease peoples concerns about 10k-15k intervals full stop. |
10-11-2020, 08:30 PM | #204 | |
Rep 1
Liqui Moly
10-12-2020, 07:41 AM | #205 | ||
Rep 10,346
The changes had been in the works for years if not decades.
11-09-2020, 05:10 PM | #207 |
Rep 14
11-10-2020, 08:21 AM | #209 |
Rep 9
11-10-2020, 10:12 AM | #210 |
Rep 495
11-10-2020, 10:07 PM | #211 |
Rep 1,425
Okay. So I suffer paralysis by analysis on most issues, but I think this oil business is taking it to a new level for me. I've been reading way too much on here and BITOG, and need to wrap this up. This thread is busy, so I thought I'd join in (vs starting a new one).
Vehicle: B46 at 25,000 miles Daily driver, planning to keep long-term (~1000 miles/month) Oil changes every 5000 Bolt-ons and tune (spirited driving, but not tracking) Milder midwest winters BMW recommends 0W-20 (now LL-17 FE+). As discussed, this seems too thin and aimed for emissions/MPG. Especially with some modifications and aggressive driving. With winter approaching, I'm leaning toward 5W-30. I've narrowed it down to Liqui Moly or RedLine. FCP lists Special Tec LM products at that weight for my engine. I know I'm overthinking this. Just need input or a push. Much appreciated.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
11-11-2020, 09:39 AM | #212 | |
Rep 495
Specification is everything, as oil these days is just a conveyance for additives, detergents, and stabilizers. Liqui Moly 0w-20 TT6600 is what I'd use in your case: 20 weight is nice and thin for winter, reaches lube points faster, and is compatible with start/stop. If you're getting hit with oil temp lights because you're driving a bit too aggressively on public roads, then you should consider thicker oil. |
11-11-2020, 06:24 PM | #213 |
Rep 1,425
Thanks for the response and feedback. I caught that, and do agree to an extent. However, I'm still not too confident 0W-20 is an ideal long-term option for the best protection.
2017 X5M - Current
sspade2464.50 |
11-12-2020, 09:07 AM | #214 |
Rep 495
11-12-2020, 09:46 AM | #215 |
Rep 16,054
With winter approaching you should be thinking of 0W-20. 5W-30 is a summer weight oil, assuming you change the oil more than once a year. I only do a yearly change, and 90% of my driving isn't in winter, so I run 5W-30.
11-12-2020, 05:19 PM | #216 |
Rep 1,425
BMW vacillates on these matters, even on this vehicle. The now recommended oil wasn't even in the physical manual (2017). They list alternative weights that are acceptable.
Thanks Bill. I agree with your thoughts. Since my post, however, I pulled the trigger on 5W-30. I'm going to do a Blackstone analysis when changing, and will check again in 5,000 miles.
2017 X5M - Current
sspade2464.50 |
12-05-2020, 12:38 PM | #217 |
Rep 172
Drives: 2015 328i
Next summer I'm out of Italy, going to Germany. Have an oil change coming up in 3000km. Wondering if I should switch from the current LL-04 5W-30 I use due to colder weather. Then I could just get the LL-12 FE 0W30 or LL-14 FE+ 0W20. Thoughts from people in cold weather (note LL-12 in gas engines is OK in Europe).
02-09-2021, 11:44 PM | #218 |
Rep 22
Been reading through this thread because I'm trying to figure out what oil to run in my N20. I'm not particular, but I'm having a hard time actually find LL-01 oil anywhere local (nor have I seen LL-17 FE+). I've read plenty of forum posts that seem to indicate Pennzoil has a product, but the only one I can currently find is LL-04, which the nice Liqi Moly gentleman a few pages back said shouldn't be run in the US. I ended up getting the Molygen online but even that doesn't actually say it's LL-01 approved, it says that it's recommended for vehicles with LL-01 requirements (among others). Maybe that's just a translation issue, but to my lawyer's eye it reads like it's not actually approved. Are the days of being able to pick up an LL-01 oil at WalMart over? I can't even find one at Autozone or O'Reilly. So what are actual current oils sold that are LL-01 approved?
02-10-2021, 12:46 AM | #219 | |
Rep 7,591
02-10-2021, 01:44 AM | #220 |
Rep 4,314
