09-07-2020, 09:17 AM | #1 |
Rep 12
Coding Replacement Injectors
I have a 2012 f30 335i. I was looking to replace the injectors.
Is there any software that I may need to code the new injectors to the car? |
09-11-2020, 12:51 AM | #2 | |
Rep 3,947
I did this DIY at about 110k miles after one of my injectors failed in a stuck open position at an HPDE. I did code the injectors, however, I don't believe the coding was any different than what the car was already programmed with. The values printed on the replacement injectors were the same as the old injectors that I had removed. |
09-11-2020, 07:08 AM | #3 |
Rep 16,081
If the DDE control unit or an injector has been replaced it will also be necessary to carry out injection quantity compensation. The adjustment value for the injection quantity compensation is printed on each injector. The adjustment value must be read off before installation. Full diagnostic/repair software is required. https://www.newtis.info/tisv2/a/en/f...alves/ITkr1aNI
09-12-2020, 07:29 PM | #4 | |
Rep 3,947
09-30-2020, 01:00 PM | #5 | ||
Sustinendum Victoriam
80
Rep 349
10-02-2020, 01:18 AM | #6 |
Rep 3,947
Broadsword79.50 |
