06-11-2021, 11:57 AM | #45 |
Dr Drei
71
Rep 245
While I love my BlueDriver, I wouldn't refer to it as an "advanced code scanner." There are many things it's unable to do. In its place, and for the BMW, definitely get BimmerLink and BimmerCode apps along with an OBDII wireless interface (my cheap VeePeak device works great).
That will give you advanced functions, not quite like a professional tool which you can use to flush transmission, reset adaptations, prime fuel system and the like, but close enough for a DIY mechanic. You'll need security torx bit to remove the EGR valve, and plenty of wiggling to get it loose enough to barely lift out. You don't need to completely disconnect it from everything, just the sensor wire. That way you don't mess with the coolant hoses. It can be cleaned with a soft brush, a shop towel and some brake parts cleaner. The piston and mechanism is under the black plastic cap which you can remove carefully with a bit of tapping on it to loosen. Clean that mechanism well, maneuvering it through its entire range of motion, then add some high-temp grease to it. Once you clean it, the car should "relearn" its full range and you should have power back. How long the effects last? Not sure anyone can say. Some have had issues come back within days/weeks, others have none for a year or more. I would log the miles post-cleaning until the next hiccup.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
06-11-2021, 12:30 PM | #46 | |
Rep 73
It seems to be intermittent. I do have ISTA+ installed and configured and a OBD ENT cable so I should be able to reset adaptations and clear these codes with that. I did end up getting some T##H torx bits because in order to access the transmission fill plug I had to remove the bellypan bracket (that part where you rotate the belly pan to unlatch it). I'm finishing the transfer case today and will remove the EGR valve for cleaning following closely to what you mentioned here. Again, thank you for the quick reply and the helpful tips!
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
08-09-2022, 10:14 PM | #48 | |
Rep 3,540
https://f30.bimmerpost.com/forums/sh...ghlight=gasket
Tags |
diesel engine, egr malfunction, intake manifold, loss of power |
