11-07-2021, 08:16 PM | #23 | |
Rep 705
i don't plan to go beyond that mod. thanks. |
11-07-2021, 09:14 PM | #24 | |
Rep 5,390
5" Performance 6.5" Competition 6.0" Race Trying to understand each of their designs and the pros/cons if used with my configuration of N55 with stock N55 EWG turbo but with the fuel system upgraded to FlexFuel to run up to E85 fuel. I need an IC that will properly cool without added turbo lag. |
11-07-2021, 11:47 PM | #25 | ||||
Rep 7,591
11-08-2021, 07:07 AM | #26 | ||
Rep 5,390
I suspect maybe it has something to do with the chargepipe shape maybe being different in RWD vs XDrive? (I would assume that the TIC pipe is the same but I haven't verified that.) I gather from reading that the EVO3 uses larger IC openings and provides larger piping that maybe doesn't adapt to the XDrive chargepipe? Do you know if the XDrive incompatibility is more that a chargepipe issue? Maybe there is a work around to fit the EVO3 to an XDrive? |
11-08-2021, 07:26 AM | #27 | |
Rep 3,695
11-08-2021, 08:40 AM | #28 | |
Rep 4,130
@mike@x-ph.com
Mods: Yes.
mike@x-ph.com24071.50 |
11-08-2021, 08:43 AM | #29 | |
Rep 4,130
Mods: Yes.
11-08-2021, 08:53 AM | #30 | |
Rep 3,695
If don't have your pipes yet, and track and want something solidly mounted to the crash bumper, Evo3. |
11-08-2021, 08:59 AM | #31 | ||
Rep 5,390
At this point I'm collecting as many FMIC recommendations and as much data as I can. My methodology has always been to be all inclusive at first to find out every possibility, and then rank parts technically as to how they fit my requirements. Price is a factor that I usually consider at the end. In the past sometimes the technical or other benefits convince me that the price may be worth it. (That happened with the Fabspeed HJS catted downpipe.) Or sometimes I'd never pay the price even if a part is technically the best, but I get lucky and someone is selling that item used for a great price. I've got at least a couple of weeks so we'll see what happens. |
11-08-2021, 09:01 AM | #32 | |
Rep 190,597
Lots of really good options are now available, it's a matter of budget and what the customer's end goal is.
If you plan on tracking the car on regular basis, invest in the Wagner EVO III. If it's a street car, the cheaper options are a better value. Quote:
The tag does not work I remember someone showing me how to tag a vendor correctly but i forgot how it's done.
11-08-2021, 10:51 AM | #33 | |
Rep 4,130
I know I've tagged a vendor before but no idea how I did it. An attempt was made.
Mods: Yes.
11-08-2021, 10:55 AM | #34 | |
Rep 190,597
I have a MAD 7" in stock, I can get all the specs.
AmuroRay2264.50 |
11-08-2021, 10:56 AM | #35 |
Rep 705
ok, i will buy the competition 6.5" VRSF, just curious, if somewhat in the future, if i upgrade stock turbo (a BIG if), would the competition 6.5" capable of handling the increase turbo?
11-08-2021, 11:01 AM | #36 | |
Rep 4,130
Mods: Yes.
11-08-2021, 11:15 AM | #37 |
Rep 7,591
Measurements of all dimensions of the MAD 7'' would be helpful (including both steps and fin density), AFAIK no one on the forums has purchased it yet. I have measurements of VRSF race i can post for comparison purposes. I saw the 30% off, and its no doubt a good price point, but someone has to be the guinea pig to collect real world data on it.
11-08-2021, 11:24 AM | #38 | |
Rep 190,597
11-08-2021, 11:43 AM | #39 | |
Rep 1,055
From tuning and logging pulls from last week. Pulls are from around 4-5 PM or so Back to back so it's not cold evening air. Maybe 20-25 second between each pull due to a slight turn in the road. 86-96F, then 88-96F. It's pretty consistent. https://www.bootmod3.net/log?id=6184...729b695b071b0c https://www.bootmod3.net/log?id=6184...0b430f4af98e3f I'm making around 365 whp on 93 oct. Will dyno it soon to confirm but now temps are 15-20 degrees cooler than normal for Miami weather. Not sure if the 6.5" comp will lag on an n20, then again there are people running the ER raceworks/mishimoto IC as well however haven't chimed in onto how much power or if lag is present.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
11-08-2021, 12:38 PM | #40 |
Rep 190,597
AmuroRay2264.50 |
11-08-2021, 01:30 PM | #41 | ||
Rep 5,390
I'm wondering if a sleeve might connect the EVO3 pipe to the throttle body half of an ER XDrive charge pipe? |
11-08-2021, 02:43 PM | #42 | |
Rep 4,130
Mods: Yes.
11-08-2021, 03:58 PM | #44 | |
Rep 5,390
https://bootmod3.com/collections/boo...13-n20-n26-n55 |
