09-05-2023, 01:17 PM | #2 |
Rep 7,622
This is pretty much a no-go on a OBD2 car, especially in California. You can't just pay under the table to pass sniffer like a pre-OBD2 car. Swap the OEM DP back on, flash to stock, relock DME, and complete a drivecycle.
09-07-2023, 10:16 PM | #3 |
Rep 110
Have you gotten your car smogged yet? From what I remember, you had a Fabspeed or something similar that doesn't give CEL. Wondering if that's the route I want to go, since I don't really like catless (smells too bad)
09-08-2023, 08:45 AM | #4 |
Rep 4,173
Sure thing mr. not_a_cop
Mods: Yes.
09-08-2023, 11:53 AM | #5 |
Rep 7,622
Yes, i run fabspeed. No CEL and no issues.
SpoolinAddict25.00 |
09-08-2023, 03:36 PM | #6 |
Rep 110
09-08-2023, 08:01 PM | #7 | |
Rep 7,622
I went to a new shop this year and they did specifically look at the DP from the top and didnt say anything. They did call out my turbo inlet (silicone MST v2). Surprisingly didnt say anything about my CP that is heat-wrapped in gold and probably the most visible mod of all. What i have found is that if you are able to pass the OBD2 checks, which are quite extensive now (for both monitors and tunes, etc), then the visual things like an intake, inlet, CP, or IC usually wont be a problem. If you have a pre-OBD2 car is a entirely different ballgame. When i brought in my 3000gt they used mirrors and whatnot to read the labels on the cat and put it into the CARB database. Not to mention all the functional tests. There are some engraved letters i believe on the BMW DP, but i think they generally just rely on the OBD2 tests to confirm everything is "legit" for the newer cars, instead of inspecting parts in detail. YMMV |
09-08-2023, 08:36 PM | #8 | |
Rep 110
03-16-2024, 12:42 PM | #9 |
Rep 8
Hey, were you able to find one? I知 also in the bay area, and I知 unsure if my MSL thermostat will affect my smog passing capability, I知 also running an MHD tune aswell.
03-16-2024, 05:43 PM | #10 |
1297
Rep 3,536
You have to remove mhd to pass now
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
03-18-2024, 12:54 PM | #13 |
Rep 7,622
You shouldn't have to remove it to pass functional tests, no. But in theory i guess it could fail the visual... doubt that will be an issue though. just go back to stock tune, get all your monitors ready, and go in.
03-18-2024, 02:28 PM | #14 |
Rep 8
Hello, just went to the smog and didnt have to remove my aluminum shiny cp and msl thermostat and passed
