BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Lower RPM Shudder/Stumble (PWG + BM3 Stg2/91)
      10-20-2020, 02:35 AM   #23
Wiz992
Oman
Drives: F33/15
Originally Posted by akgambino View Post
Oh sorry I assumed you were pwg since this thread is regarding an issue on pwg.
I know man, I joined because it's the only thread found that discusses the same exact issue that i have. Gave it a try. maybe some points might come up
      10-20-2020, 02:48 AM   #24
Wiz992
Oman
Drives: F33/15
Originally Posted by harkes View Post
Have you gapped your plugs? Try run stock gap
The installed plugs are Stock and ungapped (New). I found that when driving on comfort mode/manual (sport transmission map) , the car accelerates smoothly even on low throttle. I concluded from this test drive is that, vibration occurs only below 2000 RPM - low throttle.
      10-20-2020, 03:51 AM   #25
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Worn engine/transmission mount?
(A Dane in China)
      10-20-2020, 11:28 AM   #26
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Did you try running some techron/fuel system cleaner through it? In the other threads, people who had similar issues or rough idle/cold start, etc, had good success with running up to 4 bottles of techron through (one per tank for 4 tanks in a row). If you have some small deposits or 'dirty' injectors it usually affects the light throttle/low fuel flow situations first. Just a thought.
      10-20-2020, 12:48 PM   #27
Wiz992
Oman
Drives: F33/15
Much appreciated for your support Harkes. All main hardware has been checked and they're are in good condition and tight. The car has a mileage of 40,000 miles. DP and CP are fine. No boost leak. Pumped the car with 91 and 93 octane and still no improvement.
      10-20-2020, 12:50 PM   #28
Wiz992
Oman
Drives: F33/15
Thanks for the input thejeremyman9, I'll definitely give it a try.
      10-20-2020, 01:02 PM   #29
Wiz992
Oman
Drives: F33/15
Logs comparison between Stage 1/91 (V6.4),(V7.1),(ACN91-V7.1) and New OTS map
So guys, here are some of the logs taken for the mentioned map versions. Actually, i couldn't find a major issue that could be related to the high vibration/stumbling during low throttle. Maybe some of you could point out something
Stage 1/91 (V6.4, V7.1 & ACN91-V7.1):
https://datazap.me/u/wiz992/bm3n55-e...1?log=2&data=6
Stage 1/91 - New OTS map:
https://datazap.me/u/wiz992/bm3ewg-n...p?log=0&data=6
      10-20-2020, 01:38 PM   #30
thejeremyman9
4364
These dont even start below 2000 rpm and i thought that's where the issue occured?
I glanced through and the main thing i noticed is that the ACN log overboosts almost the entire pull whereas the others do not, but i doubt thats related to your issue.
      10-20-2020, 03:53 PM   #31
Wiz992
Oman
Drives: F33/15
These are old logs. I'll start logging tomorrow below 2K and see if something comes up.
True, I've noticed too. In (V6.2) which runs smooth there was something about (Acceleration at low RPM issue fix) i don't know if it's related to this.
https://ibb.co/YPnFxQS
