02-04-2024, 09:51 PM | #1 |
Rep 7
F30 N55 6sp new clutch, now trans issue
Hey all,
(Context 2015 3351x drive) I just went through replacing my clutch with a spec stage 3+ and new steel SMFW. I got it back and the synchros in all gears were slow to let me into gear. I thought maybe this was a break in deal and it would get better…nope. I’m a little over 1000 miles into it and returned it to the shop that did the work. They have been a great shop with a solid reputation for working on performance BMWs. I have no idea why the transmission would act like this because I had zero issues before the clutch change (will be upgrading turbo soon). Anyone have any idea? I read that the clutch could have been dragging, but the synchros stayed the same and initially the delay was the same in all gears, now it seems like 5/6 are almost normal possibly because lower rpm when syncing?? but putting it in first from a stop takes the longest to sync. All gears are affected. I don’t know a lot about this so trying to figure it out before I consider a new transmission and have that not be the problem. I did change the fluid back to redline (what I was using before the clutch swap) with no improvement (about 400 miles). |
02-06-2024, 10:38 PM | #4 |
Rep 7
I read about this also, the car is back at the shop now and they are working with Spec to try and figure it out. I am really lost on how all synchros would start acting this way, been trying to learn enough so I can think through it all. Thanks for the info.
02-14-2024, 05:16 PM | #5 |
Rep 77
Part of the issue is fundamental to changing over to a SMFW setup with a clutch disc that has a spring hub versus the stock one that didn’t. Your synchros are working to slow down the mass of the clutch disc (they act as a brake to match speed of the next gear to allow it to mesh). Your new disc is heavier than your stock disc and is a reason you are experiencing this.
kbstuff270.00 |
02-16-2024, 10:11 PM | #7 | |
Rep 7
