03-21-2021, 01:06 PM | #421 |
Rep 2,302
03-21-2021, 01:09 PM | #422 |
Rep 3
hi yes I understand that, but what coding do I have to change in the hu for dkombi to show up on my list
03-21-2021, 01:28 PM | #423 | |
Rep 2,302
If the DKombi doesn't appear after that there is another problem. |
03-21-2021, 02:11 PM | #424 | ||
Rep 3
03-23-2021, 03:13 AM | #426 |
Rep 37
Hi guys, Ive installed 6wb in 2014 f30 and all is working fine except for the cut images in HUD for navigation . I managed to get the kombi nav images working fine. The HUD nav images are enlarged and cut in one corner it seems.
Any help would be appreciated. |
03-23-2021, 08:48 AM | #427 |
Rep 525
See post 178 from @atzebmw
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
03-23-2021, 10:21 AM | #428 |
Rep 198
Hello,
I have had 6WB installed for a while and it works great. Only issue I have had is that occasionally on start up I will get a "cruise control malfunction" error on the cluster. However, the cruise control works completely fine. I'd say it pops up 1 out of every 3 or 4 start-ups. Has anyone had this issue before? |
05-03-2021, 02:37 PM | #430 |
Rep 4
Hi all!
I'm very excited to see that some of you have managed to get the 6WB working with a HU_ENTRYNAV2, as I'm hoping to do the same without having to retrofit an nbt_evo. I'm not sure if I have the MOST port though. I've searched the forum and online, but can't find where you're getting the hwel info from! Is someone able to check if my unit is compatible with it? HWEL is 000036CC.002.001.004 Thanks! |
05-30-2021, 12:58 PM | #431 |
Rep 11
Thank you. Will try this
///M Sport F36 435ix Gran Coupe - Mineral Grey (MHD Stage 2+, xHP Stage 2)
Performance Upgrades: M Performance Exhaust | HJS Downpipe | Wagner Evo 2 Competition FMIC | do88 Charge pipe | Eibach Pro Kit Springs | M Performance Brakes Styling Upgrades: Carbon M Sport Diffuser | M4 Black Kidneys | DM Spoiler | M Performance Side Skirt Extensions |
06-22-2021, 05:21 PM | #432 | |
Rep 1
06-30-2021, 01:09 PM | #433 | ||
Rep 198
| 2020 X3M | 2015 335 | IG & YT: @straight6kris | 335 Build Thread: https://f30.bimmerpost.com/forums/sh...4#post27268174 |
06-30-2021, 07:59 PM | #434 |
Rep 692
Has anyone with a 6WB coded gotten the 4G upgrade yet from bmw? Did it mess up your 6WB?
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
07-24-2021, 05:07 PM | #436 | |
Rep 2,302
07-29-2021, 07:05 AM | #437 |
Rep 12
Hello,
I retrofited 6WB, but initially the SW was too old and Kompass Graph Enable wasnt available in CAFD. I updated the SW on Cluster and now i have the coding, i set it to active, but nothing show up in cluster. Do I have to wait for a sleep cycle? |
07-29-2021, 07:43 AM | #438 |
Rep 2,302
Did you also press the button on the turn signal lever to get to the menu item?
07-29-2021, 12:31 PM | #440 |
Rep 3,877
