12-24-2020, 01:52 PM | #375 |
Rep 30
sorry can someone give me a hand? i replaced the komby with the 6wb but i can't put the code on salapa .. does anyone have a fa to inject the codes on an f26? thanks
12-24-2020, 05:32 PM | #376 | |
Rep 2,302
You hit the button to take over the changes? Otherwise you can also edit the FA with a text editor in windows. Open the saved FA file in C:/Data/FA and change from 6WA to 6WB and then load the changed FA in E-Sys. |
12-25-2020, 05:36 AM | #380 |
Rep 2,302
Choose one CAFD you like or the bottom one or the one with the largest numbers.
If you hit the button "detect caf for swe" all CAFD are right. Some are just older and some are younger. |
12-25-2020, 07:01 AM | #382 | |
Rep 2,302
First you are telling about problems with the FA. Then you are telling about the CAFD. Is the problem with the FA solved? Now you're telling about the rev counter, HUD and KAFAS. Could you insert the CAFD? |
WajahatM22.50 |
12-25-2020, 07:07 AM | #384 |
Rep 30
summary so I try to make you understand .. I changed the 6wa with 6wd and I realized that without modifying ago I found the dkombi in the list but in white and without coding, the odometer marks me the total km, but it gives me errors on the kafas and other errors.
hud doesn't work for me anymore ... I think I've made a bit of confusion ... |
12-25-2020, 07:51 AM | #385 |
Rep 2,302
OK, i think all the problems come from the 6WB DKombi which isn't coded correctly.
I'm not sure what you already did, but you have to add or change the FA with 6WB and after that you have to assign a new CAFD for the DKombi and then hit the button "Code". |
12-25-2020, 03:08 PM | #390 |
Rep 2,302
12-25-2020, 03:46 PM | #394 |
Rep 2,302
So you have connected 2 plugs at the 6WB?
