02-06-2022, 03:27 AM | #507 |
Rep 3,877
No, you cannot.
You can however configure Sport mode to be less sporty and Comfort-alike through its settings.
02-06-2022, 11:43 PM | #508 |
Rep 33
Months ago, i saw a video on YouTube (i cant find it now) with Red bar that show you when you need to change gear and it was cool. Anyone knows how can we enable it?
02-07-2022, 01:52 AM | #509 |
Rep 3,877
It is enabled from factory on certain model-years. Only shows in Sport /Sport+.
02-12-2022, 02:16 PM | #511 |
Rep 5
6WB retrofit to 2018 F30. Can't set date/time on instrument cluster
Just installed 6WB to my F30. It has not been virginalised since it was removed from a car that had lower mileage than mine. It shows correct mileage, after some coding everything works fine except the date/time is not set on the 6WB, (it is set on NBT, but not on the instrument cluster). Also after installation, all the service reminder notifications pop up every time I turn ignition on (oil service, check service etc.). I wasn't able to clear these notifications with ProTool, it says to check my ignition.
Does anyone know how to set date/time on 6WB and is it going to let clear all these service reminders. Any thoughts would be appreciated. |
02-14-2022, 03:00 AM | #512 | |
Rep 228
Drives: 2022 G20 330E
to be able to set time you need to code your HU and set "kombi_cic" to kombi_high.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
02-16-2022, 03:42 AM | #513 | |
Rep 384
here's mine, previously not enable, but now show the shift ligt my friend help me coded it https://www.instagram.com/reel/CTuVC...dium=copy_link
Instagram: nightfall.f30
02-16-2022, 11:18 AM | #514 | |
Rep 33
02-21-2022, 02:03 AM | #516 | |
Rep 14
Do the turn by turn instructions from CarPlay show in your instrument cluster? Last edited by Davey78; 02-21-2022 at 02:10 AM.. |
02-21-2022, 06:27 AM | #517 |
Rep 228
no, it only shows OEM navigation guidance.
02-22-2022, 12:12 AM | #519 |
Rep 14
02-22-2022, 05:44 PM | #520 |
Rep 384
i also had the carplay, and it wont show turn by turn in the middle of 6wb, i wish it could then would be perfect
02-27-2022, 04:37 AM | #521 |
Rep 37
Hi guys just wondering if anyone finally solved this mystery. it seems to be a resolution issue on HUD (images are to big). Again any help would be appreciated.
02-28-2022, 02:02 AM | #522 |
Rep 33
Guys what happens to the service info when you do this upgrade.
Like the brake service in 10kkm and oil service in 2000km, when you switch clusters do you loose that info? Or can you code that info back in? |
02-28-2022, 04:37 PM | #523 |
Rep 37
You don't lose anything. That information comes from the NBT unit and is simply displayed on 6WA or 6WB cluster
03-21-2022, 07:45 PM | #524 |
Rep 16
I have just installed a 6WB in my 2014 F31. I paid to have the cluster virginized and programmed (well, basic programming). I had to code navigation and the clock after realizing they weren't working. I am now wondering why I don't have an "Instrument Cluster" option on my NBT. I tried coding "LOUPE_TACHO_KOMBI" and the other items listed in this thread, nothing changes.
I am still pretty green when it comes to overall understanding/working e-sys, I can only do basic coding. I have not checked my I-step version, but I am sure it's VERY VERY old. My 6WB was a donor from a 2018 MY vehicle. I am also in the midst of acquiring all the items I need to retrofit the HUD. I think I made a mistake by buying a MY 2013 HUD unit after reading all of your responses. Anyone have any advice on what to do next in regards to the NBT issue, or what else I need to account for if continuing to pursue the HUD? I did buy a 6WB with HUD connector. Thanks! |
03-24-2022, 03:22 PM | #525 |
Rep 3
Hi
I retrofitted 6WB in my 07/12 F30 with CIC head unit. VO coded 6WB and CIC and fdl coded kombi_cic -> kombi_high and everything works good except no 6WB specific code available on my CIC. Such as: LOUPE_TACHO_KOMBI or KOMBI_AUFLOESUNG ... Am I missing anything? my car I-step level is 03/20 |
03-24-2022, 03:25 PM | #526 | |
Rep 3
03-30-2022, 06:26 PM | #527 |
Rep 33
