07-02-2018, 09:27 PM | #1 |
Rep 32
Drives: 2014 BMW 328i
Will this Fit (First time buying aftermarket wheels/tires)
First time buying aftermarket wheels for a vehicle and I have done a solid amount of research on the forums to see what wheel setup is right for my car. The car that is getting new wheels is a 2014 328i x drive so I am planning on running a square setup. The wheel specs are 19x8.5 et35 wrapped in 255/35/19. Right now I'm on stock suspension (non m-sport) but I do plan to put the car on coilovers about a year down the road. Just want to make sure I wont experience any rubbing with this wheel setup.
07-02-2018, 09:41 PM | #2 |
Rep 4,322
it will fit without issue, even after lowering. here what it'll look like on different wheels and probably a bit lower since x-drives are higher.
http://f30.bimmerpost.com/forums/sho...5%2F19+sqwuare |
07-03-2018, 03:53 PM | #3 |
Rep 6,701
This is a great question! We do have a huge selection of fitments for the F30 chassis. To help sort out what would work best for you, we have worked hard to design an entire fitment guide that details every fitment on offer for the F30 chassis!
That guide can be found here: LINK HERE These guides will review every fitment we offer for this chassis, we would highly recommend taking a look at this guide as it should answer all of your questions. I hope this information was helpful. If you have any further questions, feel free to reach out to us via PM! Best, Max
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
07-06-2018, 11:57 PM | #4 | |
Rep 32
07-07-2018, 12:03 AM | #5 |
Rep 4,322
your x-drive has the base suspension which is 10mm higher than the 704(m-sport) suspension and thus you car will have a larger wheel gap. typically most clearance issues occur when lowering the car, so you will not have any issues.
07-08-2018, 06:07 PM | #6 |
Rep 3
Hi, I am a newbie to this forum (actually this is my first time ever using forum in my life). I apologize if I am using it wrong.
I am replying it here because I didn't want to create a new thread just to ask the same question of this thread creator. I am also buying my first wheel and tire set up and I am super nervous about it. I am driving a 2015 435 xdrive, and trying to go with a square set up with 245/40 R18 with 8.5 et38 wheel. A couple of days ago, I called BMW dealer service center asked about this set up for any rubbing. Unfortunately the guy wasn't really helpful, and was like "ehhh it might... I'm not sure, but stock set up is the best set up..." From the link you kindly provided, it says it is okay with this, but I am just worried if there's any interference with the struts? I roughly measured and its like 20mm from wheel to strut (currently), and offset calculator tells me 13mm closer to strut. if this is something I should start as a new thread I will, and apologize not knowing the forum rules here. |
07-09-2018, 11:18 AM | #8 | |||
Rep 2,650
As mentioned above, your sportline suspension will not cause any clearance issues with the fitments that have been outlined in the guide, unless otherwise stated. Your car does sit higher than the M sport cars, so clearance to the suspension will not be an issue. Quote:
Taco, First off, welcome to the board! There is a huge wealth of information here and we hope you enjoy combing through it all! Thank you for reaching out, per the recommendation of the guide above and the kind words from alohasurftoad, we can confirm that the square set up with 245/40-18 with on an 18x8.5 ET38 (or ET35) wheel will fit without issue on a stock 435i xDrive. Happy modding! - Max
07-09-2018, 04:18 PM | #9 | ||
Rep 3
Thank you so much!! I am now just starting to enjoy bimmer life |
07-09-2018, 05:48 PM | #10 |
Rep 4,322
@LetMeMakeYouTaco, you can even put 255/40/18 square on 18x8.5 +38. see @[Polo08816] 335i in the link
https://f30.bimmerpost.com/forums/sh....php?t=1227332 |
07-11-2018, 12:12 PM | #12 |
A family of bimmers
2745
Rep 7,741
it may work but its quite tall for the f30. thats more in line with f10 sizes and the tires are 26.7" tall. im running a 235/40/19 on an 19x8.5 and it is already .3 taller than the stock 26"
alohasurftoad3076.50 |
07-11-2018, 09:08 PM | #13 |
Rep 9
ah alright i thought that a 245/40/19 tire is the same height as a 235/40/19.
07-20-2018, 04:05 PM | #14 | |
Rep 120
Drives: 2015 BMW 428i
07-23-2018, 06:40 PM | #15 | |
Rep 3
What are your offset values for the 19x8.5? I’m swapping to a square set up from staggered following the dreaded juddering TC issues when changing to non RF all round. (I kept the same staggered OEM tyre size of 225/40/19 front and 255/35/19 rear so the rolling circumference is within 1% but still my xdrive says ) Still adamant on non RF so hoping that going square will make it run smoothly again. I got a good deal on another set of rims identical to the ones I have and now I have a choice of 4x 19x8 et36 on 225/40/19 Or 4x 19x8.5 et 47 on 255/35/19 Ideally, I’d like the wider rims all round but the offset calculator is making me worried that it will rub the inside - it’s lowered too. Will I need 12mm spacers on the 8.5 to take the offset to et35? Thanks in advance! |
07-23-2018, 07:31 PM | #16 | |
Rep 6,701
First off, welcome to the board! We would be more than happy to offer some guidance on this! We offer the 19x8.5" wheel with an offset of ET35. We recommend paring this square setup with a 235/40-19 tire, although you can also use a 245/35-19 tire to maintain similar overall diameter. The 19x8.5 ET47 wheels will need a spacer to avoid inner clearance issues on the suspension side. We have not tested out 19x8.5" ET35 fitment with a 255/35-19 tire but there is a good chance that this tire is a bit too wide and will cause issues with fender side clearance or rubbing. We would recommend sticking with our recommended 19" Square fitment: F/R: 19x8.5" ET35 - 235/40-19 or 245/35-19 I hope this information was helpful. If you have any further questions, feel free to reach out to us! - Max
07-24-2018, 11:46 AM | #18 | ||
Rep 3
Gutted about the 255/35/19 tyres as I already have 4 brand new ones fitted to the 19x8.5 rims... I may try them out just to see and it may save me some money. I would have thought that, if there is no rubbing, the 255/35 would be better for the speedo as it's closest to the rolling circumference of the OEM set up (exact on the back obviously). So basically need to keep the offset close to the stock 19x8 value of et36 to spread the extra width evenly either side of the hub. Think I'll go for the 12mm spacers to make et47 > et35. It may be a stupid question but do I need to do the same for the back wheels on a square set up so the offset is the same all round? |
07-24-2018, 02:32 PM | #19 | |
A family of bimmers
2745
Rep 7,741
07-25-2018, 05:23 PM | #20 |
Rep 1,487
Drives: 2108 X3 xDrive30i
07-25-2018, 06:14 PM | #21 | |
A family of bimmers
2745
Rep 7,741
07-27-2018, 10:17 PM | #22 |
Rep 3,622
Apex wheels are the real deal OP
BMW CCA Member #516012
