07-17-2018, 10:28 AM | #1 |
Rep 51
squared setup 15mm offset
any opinion on fitment and handling being affected for this square setup on 340i w/ track packge, and would a spacer make this work:
18x8.5" +15mm offset, Wheel Backspacing: 5.85 in thanks, Last edited by anh3; 07-17-2018 at 11:02 AM.. |
07-17-2018, 11:19 AM | #2 | |
Rep 4,325
with 18x8.5 +15, the outer lip of your front wheel will be 25mm further out from where it exists now and the rear will be 32mm further out from where it is now. the front will be poking out like a toy car. the rear will be slight poke. not sure why you'd want to put on a spacer and make it poke out even further. with +15, your front tire will likely contact the fenderwell liner and/or other parts within your fenderwell during turns, especially at full lock. Last edited by alohasurftoad; 07-17-2018 at 11:24 AM.. |
