06-03-2020, 05:45 PM | #89 |
Rep 7,602
That's basically what i said if you read my post above lol. To reiterate what i said initially as well, ignore the numbers and look at the curves, particularly the difference between the curves.
oma3710194.50 ozymandias435142.50 |
06-03-2020, 06:57 PM | #90 | |
Rep 4,134
The biggest advantage they have is holding more boost efficiently towards redline. I’m going to assume it’s correct until I see something else showing otherwise. Last edited by AmuroRay; 06-03-2020 at 07:11 PM.. |
oma3710194.50 |
06-03-2020, 08:55 PM | #91 | |
Rep 2,357
https://www.n54tech.com/forums/showp...71&postcount=3
(A Dane in China) Last edited by harkes; 06-03-2020 at 09:04 PM.. |
AmuroRay2267.50 |
06-03-2020, 09:04 PM | #92 | |
Rep 1,282
BMW DIY Guy F32 435i build out thread https://f30.bimmerpost.com/forums/sh....php?t=1622618
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
06-03-2020, 09:16 PM | #93 |
Rep 4,134
06-03-2020, 09:19 PM | #94 |
Rep 1,282
I am running a Cary Jordan custom tune as well with E85. He got those numbers on oem turbo and no E85.
06-03-2020, 09:25 PM | #95 | |
Rep 2,357
PS: That 495whp was achieved with Pure Stage2 maxed out on methanol. My video from the dyno:
(A Dane in China) Last edited by harkes; 06-03-2020 at 09:33 PM.. |
06-03-2020, 09:31 PM | #96 | ||
Rep 1,282
06-03-2020, 10:02 PM | #97 | |
Rep 7,602
I'm not trying to be mean or bash on your build in any way I am just saying you will forever be disappointed if you just chase after some number. Use a better benchmark for your build - whether its acceleration numbers like harkes said, or wanting to beat your friends car, or getting a time at a dragstrip, or bettter yet just being fast enough for you to have fun. Measure your progress by comparison to where you were yesterday not where someone else is today. Or, forget everything i said, find a "high reading" dyno in your area, pay for a dyno session, and get a piece of paper that shows you made xxx HP so you can put in on your wall and show your friends. Anyways, rant over, I am still interested to see where your custom tune goes. I hope it gets you where you want to be, and I am happy to put new logs in Virtual Dyno when your tune is dialed in so we can see how much better it (hopefully) is. |
06-03-2020, 10:05 PM | #98 | ||
Rep 1,282
06-03-2020, 10:27 PM | #99 | |
Rep 4,134
This - Love his build, but majority of the power is unusable and will likely disappear if the car is pushed to any kind of aggressive driving or track duty. |
06-04-2020, 01:35 AM | #100 |
Rep 2,357
(A Dane in China) |
06-09-2020, 09:55 AM | #101 |
Rep 1,282
New logs...
https://www.bootmod3.net/log?id=5ede...729b350d6aa24e https://www.bootmod3.net/log?id=5ede...90c638fba0959f https://www.bootmod3.net/log?id=5ede...90c63864a088dc
06-09-2020, 03:06 PM | #103 |
Rep 1,282
I said f*** it to numbers. The car pulls a lot better than the oem turbo.
06-09-2020, 04:01 PM | #104 | |
Rep 7,602
I will still put it into VD to see how it compares to the previous revision though, as that is informative and should indicate if the tune revisions are making more power. |
06-09-2020, 07:25 PM | #105 | ||
Rep 1,282
06-09-2020, 08:01 PM | #106 | |
Rep 7,602
In all of them you have overboost from 3500-4500 or so, up to around 2psi, basically like BM3 OTS maps. Also, there is not throttle closure or other protective intervention during the overboost, also like BM3. It almost looks like this is intentional... i dont know why BM3 or tuners do this, probably because it "feels" fast when you get that massive torque shove at spool up, but for the sake of comparison a stock car and MHD-tuned car will not allow (nor intentionally) overboost beyond target like this, and if any overboost starts to occur, they feed in throttle closure to prevent it and get it under control. The other thing is that you MAP sensor looks to be maxed at 22.4psi - did you only put the 3.5bar MAP on the charge pipe? You are also dropping to 17.5 psi at redline and WGDC is int he mid 90s, so i dont think theres any way you are going to hold close to 20 psi to redline. In the 1st and 3rd log you also have this weird behavior up top where boost target drops suddenly along with a throttle closure, WGDC and timing... no idea what that is. Its at like 6800 rpm. Timing looks pretty good although Cyl 1 falls behind up top in 2 of the logs. If that's the front plug you could pull it and take a look/check gap. Its good though for ~100F IATs. I wish your MAF sensor read above 41.4, still no idea why some people's max there and others dont. |
06-09-2020, 08:22 PM | #107 | ||
Rep 1,282
06-09-2020, 10:51 PM | #108 | |
Rep 7,602
I dont think you necessarily need to be worried about anything if the tuner thinks its fine... just be aware you are overboosting and nearly maxing out the turbo trying to reach boost targets. Not necessarily ideal for longevity. |
06-10-2020, 12:01 AM | #109 |
Rep 7,602
FYI here is virtual dyno. Bottom 3 are the new logs. Doesnt show much. Are you logging on a bumpy road? The RPM in the logs is never smooth... for example you have spots where RPM decrease at the next logging interval compared to the previous one, which doesnt really make sense unless you a breaking traction (doesnt look like it since its just generally wavy) or hitting a bump. The RPM should really be a smooth continuously increasing curve if the road is smooth.
AmuroRay2267.50 |
06-10-2020, 06:24 AM | #110 | ||
Rep 1,282
