09-20-2021, 11:20 AM | #4467 |
Rep 5
Hi y'all.
What do you think about https://www.aliexpress.com/item/1005...c00IpZfMe&mp=1 Does it fit? Will it be 'too much'? Thanks |
09-20-2021, 10:04 PM | #4468 |
Rep 6
recommendations for what I need to upgrade my screen size and quality so i can stream movies (Netflix)? Wife said I can do whatever I want as long as she gets those 2 things.
2019 440ixdrive NBT evo id6. We both use iPhones and want the system to function as it does now. Thoughts on these? https://avinusa.com/12-30-multimedia...2-f83-f84.html https://autotecpro.com/product/bmw-4...gation-system/ |
09-21-2021, 02:58 AM | #4469 | |
Rep 353
12.3 is fine for F01, F10, F07, F25. I would recommend to purchase 10.25 for F30. It looks oem like and the size is optimal. |
09-21-2021, 09:05 PM | #4470 | |
Rep 22
With regards to the DAC, my experience has been that the Fiio e10k gives the best experience if you are looking for a plug and play solution. Other DAC will work but the problem you may encounter is that most of them are designed to drive 32ohm headphones while the Aux in port of the car has a much higher impedance. I have read various figures in different posts quoting impedance values of 500ohm upwards. This means that the DAC cannot provide sufficient power to give a satisfactory listening volume. Even my Fiio K3 couldn't drive my Aux In port. I have tried a couple more DACs too and all had the same issue. I am going to try plugging the output of the DAC to a portable headphone amplifier to see if that will provide sufficient power but that may lead to other issues later such as noise from the power supply etc. Only go down this path if you are a dedicated audiophile willing to spend time and money for some very subjective gain and have some basic electronic knowledge. Meanwhile the e10k works flawlessly. |
09-22-2021, 02:20 AM | #4471 |
Rep 5
Boys and Girls dont buy from this crap of shit buyur, they want noy help you when you ask files to give, they blok you from chat if you want the file. They dont answer you questions or late.
Dont buy from this buyur. Sz-kianda https://m.nl.aliexpress.com/store/v3/home.html?shopId=1899623&sellerId=225530983&pagePa th=index.htm |
09-22-2021, 03:29 AM | #4472 | ||
Rep 353
I have two amps in my car plus DSP and USB DAC Fiio K3 - all together this system sounds very good, power is more than enough. Quote:
F20_M135i100.50 |
09-22-2021, 04:38 AM | #4473 | |
Rep 22
09-22-2021, 03:09 PM | #4474 |
Rep 399
09-23-2021, 07:22 AM | #4476 |
Rep 353
09-23-2021, 09:43 AM | #4478 | ||
Rep 63
09-23-2021, 09:52 AM | #4479 |
Rep 5
We be a firmware uodate for bmw e90 screem 8.8 inch whit resulution 480p?
Firmware update 3.1.2 works great but the screen resulution 720p, this work not perfect can not selact the screen resultion to 480p. Last edited by Silahsor_66; 09-23-2021 at 09:58 AM.. |
09-23-2021, 12:54 PM | #4480 |
Rep 12
09-23-2021, 01:01 PM | #4481 |
Rep 12
There is one issue I notice; there is a delay of about 2-5 seconds during conversation. Not sure why this is, but I don't particularly care, it doesn't bother me because it's so amazing it's even working
09-24-2021, 12:49 AM | #4482 | |
Rep 10
unlook the phone Start HU, Start WLAN wait for WLan Connect if connected it seems to be a delay between phone an HU. I have a few USB LTE sticks so i can try, but I see no APN setting available. |
09-24-2021, 08:04 AM | #4483 |
Rep 6
Hi, i am thinking of buying a new screen for my 2016 F34.
Either The 10 or The 12 inch screen. Have not find any picture of The 12 inch ones yet if they are to big or not. But my question is related to the split screen posibilities. I do not have navigation in my car and that would be The main reason why i would like to buy a new screen. But i would like to be able to listen to radio/CD/bluetooth from The original radio in The same time. With the split screen, is it possible to have halv screen to navigation and halv for oem display? Can i still use ny steering wheel to change tracks and sound on my entrynav Hu or will they be mapped to the navigation instead? It is not clear for me if this will work or not. |
09-24-2021, 08:18 AM | #4484 | |
Rep 2,367
Drives: E63 645Ci
enough730.00 |
09-24-2021, 04:36 PM | #4485 |
Rep 5
Iam using v2.6.3 evry thing is work fine, i downgrade to v1.2.2 evry things screen work perfect when i upgrade to v3.1.2 or more than v2.6.3 the screen work not perfect and give me isseu . Who can help me about this problem. |
09-24-2021, 05:15 PM | #4486 | |
Rep 27
09-24-2021, 07:57 PM | #4487 |
Rep 2,367
Drives: E63 645Ci
But then if you press change audio source button, will that not automatically take you back to OEM? I never properly tested that as I wasn't interested in mixing these two systems in any shape or form.
09-24-2021, 10:27 PM | #4488 |
Rep 551
from my experience WAZE audio instruction when on the OEM BMW side is distorted and way too high popping your ears, it is not possible to endure this sound state
