11-12-2018, 10:38 AM | #177 |
Rep 395
Does this only work on iDrive 6? I've been reading the thread and cannot be 100%
I have all the BT extras on my 2017 330e with iDrive 5, wifi hotspot, wifi antenna, wireless charging, 6WA etc. Do I need to upgrade from iDrive 5 to 6 first? Is that software only or also hardware? Or I just need the FSC code to enable? Would also need video-in-motion to make it usable of course, can that be enabled the same way? Last edited by sd_dracula; 11-12-2018 at 10:45 AM.. |
11-13-2018, 02:34 AM | #179 | |
Rep 13
1. Is there any way of inspecting the file so that you know exactly what changes it is making? I would be extremely cautious about using a file bought on ebay that it able to make programming changes to the car as you have no way of knowing if the sellers intentions are honest? 2. Does coding from USB stick change and store a modified VO code? Again I'm cautious about this having had a problem at the dealers with a modified VO, I'm careful now not to save the modified VO back to the car 3. Is this method likely to overwrite other changes that have been made with Esys? I've coded a few bit such as EBT and wondered if I would have to recode again. |
11-13-2018, 02:58 AM | #180 | |
Rep 395
Looks like I have the wifi antenna and screen mirroring works on iDrive 5.0 also but need to get video in motion or it is useless on its own. |
11-13-2018, 03:09 AM | #181 |
Rep 2,598
WiFi antenna does not need to be coded.
I too wouldn’t buy a code from some random Ebay seller, hence using @wibbles who is trusted within the BMW community! |
11-13-2018, 03:19 AM | #182 | |||
Coding ECU's remotely
445
Rep 1,175
Some solutions have a way to unload the activation and put the car back to standard befor a dealer visit - not all solutions are equal - buying cheap is not always the best solution.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
11-13-2018, 05:37 AM | #183 | |
Rep 395
11-13-2018, 05:46 AM | #184 |
445
Rep 1,175
If they update the firmware on the idrive then no, you cannot currently re-apply the same files -this is something introduced into the latest firmware.
11-13-2018, 09:18 AM | #185 |
Rep 395
11-13-2018, 07:31 PM | #186 |
Rep 4
11-16-2018, 10:50 AM | #189 |
Rep 785
looks great!
Can you run BMW navigation in the 2/3 window and carplay media in the 1/3 window? I'd probably use carplay mainly for media playback as I'd want the BMW navigation so it displays on the digital dash. |
11-16-2018, 01:17 PM | #194 | |
Rep 145
Thanks! |
11-16-2018, 01:19 PM | #195 |
445
Rep 1,175
New files will be required once a workaround is found. At the moment once it's gone, it's gone unless the firmware is rolled back.
Marsey7610.00 |
11-16-2018, 01:21 PM | #196 | |
Rep 145
What about enabling fullscreen CarPlay? Do you happen to know the specifics surrounding enabling that? I already have CarPlay enabled at the moment. -- Thank you again. |
11-16-2018, 01:51 PM | #197 |
Rep 2,244
I assume wibbles has found the magic combination of FDL codes to make this work ?
Although I didn't think this was possible ios side due to the SDK's resolution requirements: https://developer.apple.com/design/h...design/layout/ |
11-17-2018, 04:16 AM | #198 |
Rep 4,451
Apple CarPlay Retrofit - Done! (Update:16/11/18...now also with full screen function)
+1 for full screen CarPlay How do we get this?
Once enabled, can you toggle between normal and full screen? |
