BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ***OFFICIAL Ignition Coil Packs Thread***
      09-19-2020, 05:59 AM   #23
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Originally Posted by Phantom10R View Post
I have the pr coils.
didn't notice a damn thing tbh. they have been on the car since March of this year.
Thanks for the info. I have long been thinking of these as I am out of octan and don't want to run the turbo any harder. Ignition system is the last place to gain engine performance. However, I have never really been able to understand how these should improve much unless you run really high boost and maybe even increased gap.
(A Dane in China)
      09-19-2020, 11:15 AM   #24
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
there really isn't any power to be gained. just more reliability depending on set up.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      09-19-2020, 08:45 PM   #25
MAKH 5
MAKH 5's Avatar
Drives: 2020 M340i RWD [Portimao Blue]
Im running Ignition Project Coils. They're pretty solid. Check em out.
      09-19-2020, 08:54 PM   #26
Pussiwillow
Drives: Alpine white 2014 335i msport
How many miles have you got on them
      09-19-2020, 08:58 PM   #27
MAKH 5
MAKH 5's Avatar
5,200 on them so far. BM3 Custom tune
Edit: OEM coil setting
      09-19-2020, 09:00 PM   #28
Pussiwillow
I'll look into them thanks
      09-19-2020, 09:01 PM   #29
MAKH 5
MAKH 5's Avatar
You got it.
      09-22-2020, 04:41 AM   #30
harkes
harkes's Avatar
China
1078
5300miles If they can last that long then definitely a solid product
(A Dane in China)
      09-22-2020, 07:20 AM   #31
MAKH 5
MAKH 5's Avatar
Uh. ok.
EDiT: Think you read into that a little too much buddy lol 👌🏾
harkes1078.00
      09-23-2020, 12:20 PM   #32
cmart
Drives: 2016 340i xDrive with MPPSK
$1000 for coils? What am I missing here? Are they made of gold?
      09-23-2020, 01:16 PM   #33
MAKH 5
MAKH 5's Avatar
Lol. There suppose to have a high powered amplifier built in and better/longer dwell time. The latter being confirmed by my tuner.
I just didn't want to deal with the precision raceworks install and wanted to try something new. Car felt better after changing over, fwiw.
$900*
      01-04-2021, 08:55 PM   #34
AstonKarim
Drives: 2022 Audi RS5 Sportback
So I replaced my Spark Plugs only at 75,000km and the lesson learnt at 79,500km is I should have done my coils too. Check Engine light came on and it was the P0306 Cylinder 6 Misfire, rough start up idle, and reduced acceleration.
Ended up going back to the OEM Delphi's and installed myself based on the videos here on the forum and YouTube. And what a difference! Much more responsive and even getting exhaust burbles in Comfort Mode.
SOLD 2013 BMW 335i M Sport Xdrive / MPPK / MPE / Alpine White / Black Dakota Leather / M Sport Brake / 19"Style 403m / M Perf Diffuser
      01-05-2021, 12:13 AM   #35
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Exhaust burbles in comfort mode is not necessarily a good thing unless you have that option flashed...
      01-06-2021, 10:05 PM   #36
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
$900*
Newer Bosch coils typically drive better compared to worn ones. Technical review on the IP coils here says it's basically a factory Bosch coil that has the IP aluminum logo stamped onto it.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      01-25-2021, 03:25 PM   #37
bigdog34uz
Drives: 2007 e90 335i
So i went to the link above but it says it does not fit my car. I have a 2012 f30 335i. Or they just dont show my car.
Thanks
13.01 @ 107.6mph Mods: OETuning........
13.00 @ 108.89 JB4 Times
      01-25-2021, 06:17 PM   #38
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
Thanks
I just installed these over the weekend on my 2015 f36. Work perfectly. You should be good.
      04-11-2021, 09:14 PM   #39
halcyon_waves
halcyon_waves's Avatar
Drives: 2013 F30 335i M Sport 6MT
Thanks
I'm having the same issue - apparently they don't fit my 2013 F30 335i, but they will fit 2014-2015 335i models. Would anyone happen to know why? I've been searching for Eldor coils that would fit my car but can't seem to find any.
      04-17-2021, 07:51 PM   #40
UsrNmeInvalid
Drives: F30 335i
Cars built up to 07/2013 have different fuel injectors and coils.
N55's up to 07/13 were PWG and after that they switched to EWG. I believe that's the reason they are different.
      04-27-2021, 11:18 PM   #41
halcyon_waves
I had suspected it had to do with PWG vs EWG, but does that really make a difference for which coils you run? After much research, it seems that a lot of folks with my particular model run the same coils just fine.
      04-28-2021, 09:34 AM   #42
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Check the Eldor here: https://www.oembimmerparts.com/BMW-F...57273f30-1.htm
part # 12138657273
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      06-07-2021, 09:55 PM   #43
alex0607
Drives: F30 & E60
Guys, my F30 320i after changing spark plug and did a timing chain replacement, is having a bit of a idle issue at cold start up. Its only for like a minute after that it seems to run fine. At one time I put the car in reverse right after starting and I can feel the car jerks a bit while reversing and this tells me its either the spark plugs or ignition coils are having issue. I am not sure how to correct this without changing either the spark plugs or the ignition coils. I guess the cheaper route is changing out the spark plugs first to see if they are the culprit.
Is there another way to find out? Will putting a code reader to the car produce some fault codes or something to indicate which bay is having the issue? It would have been easier if one of the bay is not firing up and testing out with one good coil or plug would do the trick, however, its only at cold start and goes away after a minute of warming up.
      06-07-2021, 10:10 PM   #44
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
first off, you need to ask the question in the forum for your car/engine as they will know more about it.
if the check engine light is on you will have codes so checking them with a scanner will help.
it could be a plug issue, may be a bad plug, could be a bad install.. who knows without checking it. who did the timing chain, can you confirm that it's done correctly?
