BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > 405m wheels on xDrive
      03-26-2021, 07:09 PM   #1
TheTektician
Drives: Looking for F3X
Does anyone know if 245/35/20 square setup tires fit onto the OEM 405 staggered setup wheels on a 2015 335i with xDrive without any fitment issues?
      05-25-2021, 05:50 AM   #2
J555
Drives: F31 LCI 340iX
Should be no problem; depends on the specific tire, maybe the fronts will rub a tiny bit the fender liner at partial, or full lock. To improve the appearance, you can add spacers (12mm front, 15mm rear).
      05-30-2021, 09:14 AM   #3
Jekapisk
in front will rub the wheel arch liner
      06-05-2021, 08:14 AM   #4
RedSectorA
Drives: 2017 340ix M Perf, 2019 M2 Cmp
As the wheel width is difference (8 in front and 8.5 in rear) I would recommend 245 30 front and 255 30 rear, within BMW specs and works very well. I currently have exactly that in PS4S with no rubbing issues, car is lowered by 1 in.
Resolved part of the understeer issues these cars are prone to.
Dan
      06-05-2021, 10:42 AM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If you're in NYC you might want to reconsider using 20 inch rims in the pothole capital of the world.
      06-06-2021, 07:16 PM   #6
RedSectorA
Haven't been in Montreal haven't you? Anyways I have 20' 405M on my car and no issues in the past 4 years. Imperative you keep the front pressure at 37 psi front and 41 psi rear minimum.
Dan
      06-07-2021, 10:15 AM   #7
Billfitz
Billfitz's Avatar
I go to Montreal and NYC every year. Have been since 1998, with the exception of last year due to Covid. Montreal doesn't have NYC level potholes. Not even close.
MTTH232.50
