BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > XHP Trans Tune - Experiences and reviews?
      10-10-2021, 01:19 PM   #177
Abzynthe
Abzynthe's Avatar
Drives: BMW 440i Gran Coupe LCI
Originally Posted by Rdurty2 View Post
Originally Posted by Abzynthe View Post
I've just flashed stage 3 on my gearbox. Anyone have any suggestions of tweaks over the OTS map?
Ive only driven about 10 miles and if I'm honest, it doesn't feel hugely different at the moment. Shifts are probably smoother in comfort and shift are marginally faster in sport.
The main reason I got it was because my car would try and sit at about 1k rpm and this would cause the car to chug when accelerating after cruising for a while. It now seems to sit at about 1100rpm, which is better, but I'd like it to go up another 100rpm or so.
As per directions you need to drive with no WOT for about 100 or so miles for the trans to adapt after the initial flash. During this time shifts can be a bit funky as everything adapts and sorts it self out. Changing settings and re flashing does not require this adaptation process.
After you put on that 100 miles driving slow put it in sport + and trans in sport. You will definitely feel the difference. It's pretty crazy when it shifts. Also try manual shifts as they are even faster.
What exactly are you looking to tweak? Most people just flash and are done and don't mess with it.
If you are dme tuned as well "start in 2nd gear" is popular to enable.
I didn't realise it was 100 miles. That will probably take me a month to do haha.
I've had a little play with it today and made it shift sooner in the low gears changes by a few % and raised the % on the change down on higher gears just to keep the revs over 1000.
The main problem I was having was that when cruising along at 30mph or 70mph it would be fine, but if I were to accelerate, but not enough to kick down, then the car would lug and judder until it got on boost. I want to eliminate the lugging. Everything else I'm fine with, and overall I'm quite happy with the new map.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3)
      10-10-2021, 01:58 PM   #178
Skyhigh
Skyhigh's Avatar
1103
Drives: BMW F36
I wonder…. You are installing a new gearbox (or engine) software! Potentially catastrophic effect if done wrongly! Do you guys not bother to at least read the "ReadMe" file a.k.a. Installation manual!?
Just me?
      10-11-2021, 11:28 AM   #179
Rdurty2
Drives: 2018 340i
I was wrong, 50-75 miles. You shouldn't be changing anything during this time.
Straight from XHP's FAQ:
Do I need to do a run-in-phase?
We do recommend around 50-75 miles of driving without wide open throttle, with varying speed, load scenarios and shifts, so the transmission can adapt to the new software as fast as possible.
This driving-in-phase is only recommended after the initial xHP flash and not needed for subsequent flashes, like map changes or different custom settings etc.
I just flashed my transmission, but the shifts are bad.
Your transmission may behave weird, right after flash, e.g. starting in 3rd. gear. This issue should clear within a few hundred meters of driving. The transmission has extensive adaption-algorithms, to keep shift quality in check over a full life time and even with heavily worn out clutches. The adaptions applied are very sensitive to abrupt changes, as they operate in a narrow window. Therefore, shift quality can suffer in the first few hundred miles, after doing an oil-change, replacing transmission hardware, or changing the TCU software, like with xHP. Donít overstress your transmission during this adaption phase. The best way to adapt your transmission, is just normal driving in D mode with lots of varying speeds and shifts. We DO NOT advise anybody to clear the adaption values to speed up the process. Depending on the current wear state of your transmission, this can lead to unwanted and permanent bad results.
Abzynthe900.00
      10-15-2021, 09:54 PM   #180
Glemm1970
Glemm1970's Avatar
Russia
235
Drives: BMW M140IX.
Xhp Drag Mod mode test. On the street + 15C. The road is simple asphalt. Target 28 psi. Tim 17. E35 / WMI Port. Start from 2nd gear 3000 rpm. The total weight of the car with a driver is 1720kg. X-Drive.
M140IX. Turbo VTT GС,Flash Wedge Steven+JB4.
xHP stage 3.Drag Mod. CSF. Dorch 2. E35+WMI Port. 1620kg. 0-100 2.83s 1/4ml 10.22s. 100/200 5.51s 0C.
      10-16-2021, 08:41 AM   #181
Jnat
DisplacementReplacement
Jnat's Avatar
Drives: 2017 M240XI
So a .3 improvement on 1/4 and (5kmph) negative on speed, am i seeing that correctly?
2017 M240XI Mineral Grey - MHD Stg2 95octmap/CTS Catted DP/ Small spacer 02#2/94201's gapped .026/AFE Dry flow/XHP Stg3 ***
      10-16-2021, 08:50 AM   #182
gameson
Drives: N20 BMW 320i
Originally Posted by Dreculah View Post
I'm going to wait a couple of years to see if the tune grenades the transmission.
Just curious to check if there is any failure in regards of this xhp tune
      10-16-2021, 09:14 AM   #183
Jnat
Jnat's Avatar
Drives: 2017 M240XI
Haven't read of any. I've ran it for many years on my M235xi and M240xi and drive hard, combined 40-50 thousand miles driven aggressively. I am curious about this new drag option as it sounds great, just would be concerned about how brutal it is on the transmission life span.
      10-16-2021, 09:52 AM   #184
gameson
Originally Posted by Jnat View Post
Haven't read of any. I've ran it for many years and drive hard, no problems.I am curious about this new drag option as it sounds great, just would be concerned about how brutal it is on the transmission life span.
how many years have you run xhp tune?
I assume all F3X series use the same transmission (all engine type)?
Thanks.
      10-16-2021, 11:18 AM   #185
Skyhigh
Skyhigh's Avatar
1103
Drives: BMW F36
Much more relevant - how many Kilometers?
I am pretty sure you can safely have any tune for 100 years if you leave the car in the garage
      10-16-2021, 11:22 AM   #186
Jnat
Jnat's Avatar
Drives: 2017 M240XI
Ok, M235xi and M240xi, driven hard, 40-50 thousand miles combined on XHP, performed normally...
Skyhigh1103.00
      10-16-2021, 02:24 PM   #187
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
47
Drives: 2019 F30 340i
Haven't really tested it like Glemm but you can really feel the lack of torque reduction, car jumps forward on upshifts during spirited driving. Haven't done any WOT upshifts yet.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800
      10-16-2021, 02:44 PM   #188
gameson
What is WOT? I only know one meaning of WOT and I don’t think that’s what you mean here ��
      10-16-2021, 02:45 PM   #189
Jnat
Jnat's Avatar
Drives: 2017 M240XI
Sounds like using this daily probably not the right idea for me.
i guess time will tell on the wear end of it...
      10-16-2021, 02:47 PM   #190
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
47
What is WOT? I only know one meaning of WOT and I don't think that's what you mean here ��
Wide open throttle
      10-16-2021, 05:20 PM   #191
Jnat
Jnat's Avatar
Drives: 2017 M240XI
I just tried it and wow, very impressive response in all aspects...
Great job XHP
But, i will not be using 24/7 as it's abrupt... which is good
      10-17-2021, 11:34 AM   #192
Abzynthe
Abzynthe's Avatar
I'm pretty safe then
      10-17-2021, 09:00 PM   #193
Glemm1970
Glemm1970's Avatar
Russia
235
Drives: BMW M140IX.
100-200 3/4/5 gear. Drag Mod Ok.
      10-19-2021, 01:03 AM   #194
WDE82
Drives: 2018 440iGC F36
I've decided I'm doing xhp before I even do MHD. The transmission has a much bigger impact on driver experience than a boost of 10-20% hp. This car so much faster than I can utilize in my DD patterns already that I think the extra 50-60 hp from Stage 1 will be largely wasted if I do it first.
My iPhone Ethernet adapter comes tomorrow
      10-19-2021, 03:15 AM   #195
Skyhigh
Skyhigh's Avatar
1103
Drives: BMW F36
Please share your immediate experience, as I am intending to do the same very soon.
WDE82509.00
      10-19-2021, 05:58 AM   #196
T_H_O_M_A_S
Drives: M135xi
you wont shave off 2 seconds from a 100 to 200 kph with only a trans tune
i like the take off in second gear and uplifted shift rpms in comfort ( ive raised them by 20 percent ) . i dont do 0-60 launches .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      10-20-2021, 12:44 AM   #197
WDE82
I had a 6 speed 128i for 5 years and the ZF in this car takes a little away from the enjoyment right now so if I can customize it to fit my driving style, it'll bring most of that back. I have not once felt like this car lacked power even on the interstate. It'll blow the doors off just about anything. So I can wait a little longer for power mods.
      10-20-2021, 03:12 PM   #198
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
47
I don't dare to run stage 3 anymore. At a certain point in time the downshifts were so harsh in S-mode and M-mode it was really like banging in the gears, especially from 5 to 4 it was really bad. You could even hear it.
So first went back to stage 2 but that didn't help much, so back to stage 1. Did that for a while and then tried stage 2 again. After another while tried stage 3 but then altered the throttle blips to try and make it a bit smoother. That seemed to help quite a bit however downshifts were still quite harsh.
Last week went back to stock and I will keep it that way for a while hoping for that the trans will re-adapt. Even now in stock the downshifts in m-mode are not smooth (upshifts are), but to be honest I don't remember if they ever were?
However I don't know how long I can live without the custom shift settings for comfort mode. The ridiculously low shiftpoints drive me crazy. I don't understand how people can drive like that...
