10-21-2019, 03:16 PM | #1 |
Rep 153
Audio Coding questions - S676A
Hi All,
This is my first time coding because I've upgraded from HiFi (S676A) to Harman Kardon (S674A). I successfully upgraded the VO by changing SALAPA element 676 to 674 then I changed FDL settings below : I guess I have successfully coding 1 - MultiChannel Active 2- Audio Variant hk_surrondsound (then changed to TopHifi) however I don't see any differences in the sound and no SurrondSound option has become available Navigation Unit has restarted while I've been recoding FDL to prove coding is updated. What else do I need to change in FDL or is that all ? there are more than 6 settings under Audio Variant and Werte was 06 first then has become 02 Many thanks for your answers! |
10-21-2019, 05:10 PM | #2 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Did you code HU_NBT after changing the VO? That should update whatever FDL values are required for the new hardware. I don't know if other ECUs would need to be coded.
10-22-2019, 02:15 PM | #4 |
E36fiend
285
Rep 637
It's my understanding that when modifying the VO such as adding or removing option codes, coding the ECU will automatically adopt whatever FDL changes are associated with that feature. Yes it will overwrite whatever FDL changes you've made but it should set them to the required settings. You can always save the original and compare it after coding the ECU.
