      09-24-2013, 12:40 PM   #4687
shawnsheridan
shawnsheridan's Avatar
Originally Posted by solitary View Post
Thank you! Have you information where I can dowload psdzdata 50.3?
I losted the link. Please, answer me to my e-mail: solitary86@mail.ru
No. What is you reason for wanting the older version though?
      09-24-2013, 08:29 PM   #4688
solitary
Drives: bmw f20
I have already installed e-sys 3.22.5.
      09-24-2013, 08:31 PM   #4689
shawnsheridan
So what? They are not married. You can use 50.4 PSdZData with E-Sys 3.22.5.
      09-24-2013, 09:03 PM   #4690
solitary
Drives: bmw f20
patch and a token is not necessary to buy new?
      09-24-2013, 09:05 PM   #4691
shawnsheridan
If you already have 3.22.5 with patch / token, then you need nothing more. You can use any PSdZData version with it.
      09-24-2013, 09:12 PM   #4692
solitary
Drives: bmw f20
Thank you very much
      09-24-2013, 09:40 PM   #4693
shawnsheridan
Thank you very much
Email sent.
      09-25-2013, 04:31 AM   #4694
SharksF31
Netherlands
Drives: BMW F31 2016(Nov)
Is there also a clean and update cheat sheet for the F30 available? The ones I can find are all a little outdated…
Thanks,
Sharks
      09-25-2013, 08:54 AM   #4695
ioschi2003
Drives: BMW X3 3.0
Hi Shawn,
Some days ago BMW service Made a FW upgrade on my F25.
How i can Check which FW version is installed to use the right pszdata ?
Regards
      09-25-2013, 01:39 PM   #4696
4.8 E70
Montenegro
24
Drives: Alpina B7
Yes, but remember, this CAFD is for FRM module, and F20 chassis has no FRM, so that is why this specific FDL Code it is not listed for F20.
The key is finding the equivalent FDL Code in FEM_BODY. It most likely exists, but its not obvious, and short of a lot of Trial and Error guessing, it wont be found.
Spent endless nights trying to figure this out but to no avail. If anyone somehow stumbles across in making the Angel Eyes on max brightness when the headlights are turned on, please share ! Thanks
      09-25-2013, 07:47 PM   #4697
shawnsheridan
Originally Posted by ioschi2003 View Post
Hi Shawn,
Regards
You need to read your I-Step Current with E-Sys VCM:
http://www.f30post.com/forums/showpo...postcount=1403
Then that can be cross referenced to the ISTA/P version.
Or just use the latest PSdZData, and you never have to worry about it.
      09-26-2013, 09:07 AM   #4698
ioschi2003
Drives: BMW X3 3.0
Thanks a lot
      09-27-2013, 09:09 PM   #4699
ioschi2003
Drives: BMW X3 3.0
Thanks Shawn,
could you pls send me the latest PSdZData (50.4 ?) ?
rgds
      09-27-2013, 09:31 PM   #4700
shawnsheridan
Thanks Shawn,
rgds
PM sent.
      09-28-2013, 08:00 AM   #4701
Mr.t
Mr.t's Avatar
Drives: 330d (coming)
Hi all,
Struggling to get to talk to fem body on August 2013 build 330.. HU NBT all good and Kombi.. Just won't speak to fem_body.. Any ideas.. Won't read coding data at all.
Mark
Black 330D M Sport 'Plus', Pro Nav.
Called it BOB.. Ballistic Oil Burner
      09-28-2013, 11:59 AM   #4702
Molly the Mad Spaniel
Drives: BMW f20 (120D) X-Drive Msport
Hi all... just joined and wanting to make some adjustments to the the settings ... so currently Looking for the Voucher and Download link for the latest Esys for my beloved f20x msport.. would anyone be able to pm the details to me please.
regards.
      09-28-2013, 12:35 PM   #4703
rmm0031
Drives: 2013 335i M-Sport
2013 BMW 335  [0.00]
I'm in the same boat. Using 50.4 PSdZData and E-Sys 3.23.4. I've been PMing Shawn but so far nothing has worked. I get the following error:
aTransaktions-Report: Aktion: Codierdaten lesen
cafd_00000794-007_029_101 Fehler:
CPS read from ECU "ECUId:FEM_BODY_0x40" failed! [C070]
openECUConnection for link FEM_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name FEM_BODY_40_ETHERNET doesn't map to an item [1694] - VEHICLE_ERROR
Is yours the same?
Originally Posted by Mr.t View Post
Hi all,
Mark
2013 335i M Sport - Estoril Blue II / Black Leather
      09-28-2013, 04:11 PM   #4704
shawnsheridan
regards.
You can't yet receive PM's. Post an email address or wait 24 hours until you can.
      09-28-2013, 04:15 PM   #4705
shawnsheridan
Hi all,
Mark
Is yours the same?
What are you selecting for your connection target? Does it have "_DIRECT" at the end of it?
Are you selecting "Connection via VIN"?
Is "Read parameters from VCM" checked?
      09-30-2013, 12:44 AM   #4706
R56
Drives: F34
coding for F34
hi, anyone knows that does the ESYS v50.4 should work fine for 2013 F34? I'm now thinking to buy the cable or not
      09-30-2013, 01:02 AM   #4707
shawnsheridan
E-Sys works with 50.4 PSdZData works on all on all Fxx Chassis.
      09-30-2013, 02:36 AM   #4708
R56
Drives: F34
Thanks a lot Shawn
