01-01-2024, 04:56 AM | #1 |
Rep 121
new year, new issue?! Rough idle on start up
HNY all.
Having sorted one minor issue, I think I may have stumbled across another... The last couple of starts I've had a couple of rough grumbles - a little like a minor misfire or a fuel starvation. It's less than a second and seems to sort itself out pretty quickly. I haven't changed the fuel filter in 20k miles. I changed all other filters and oil about 8k miles / 6months ago. Im guessing I should change the fuel filter anyway, but is there anything else I should check for? no codes, no lights, no other warnings etc. Any ideas greatly appreciated 335d about 88k miles cheers |
01-01-2024, 05:59 AM | #2 |
Rep 391
I think it is normal for a diesel engine to crank a second in colder conditions, all the fluids are thicker.. If it is anything else then I couldn't pick it up from your description.
20k is too soon for a fuel filter change
1995 E34 525td auto • 2016 F30 320ed auto
01-02-2024, 07:29 AM | #4 |
Rep 121
it never rains...but it...
As lady luck would have it, my Jeep has developed a similar problem (but about 10x worse). I checked battery at the posts under the bonnet (not directly) and with interior lights off, it was reading 12.24. (BMW this is, no the jeep) That's a tad on the low side for me. I wonder if the glowplugs are getting enough juice. On the battery question - can I code in a new one with bimmercode or do i really need to get bimmerlink too? Cheers lads. |
