05-20-2021, 08:41 AM | #1 |
Rep 41
Need opinions on new EGR. Wahler vs. Metzger?
That's pretty much it. Replacement is not covered by warranty so I'll do it myself. Auto parts websites state both brands as OEM so probably BMW changed partners sometime in the past?..
What are your opinions? Cheers |
05-20-2021, 10:48 AM | #2 |
Dr Drei
71
Rep 245
I'm in the same boat. To buy some time, I gave the EGR valve a good cleaning. It seems to have done the trick for now.
There is quite a price difference between Wahler and the OE part. Knowing that Wahler makes many parts for German/Euro vehicles (from thermostats, water pumps, etc) I would think it is a quality replacement.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
SpilltheBimms8.50 |
05-20-2021, 12:06 PM | #3 |
Rep 41
Initially I also cleaned the valve body. But, in spite of the + 200000 km, it actually wasn't that dirty. I also checked for proper seating (no light shined through the valve when fully closed), installed a new o-ring, and lubricated (it still had some) the rail/roller bearing system on the actuator side.
Soon after, the error light came up again. After further investigation, I came to the conclusion that the valve stem has some "give/tolerance", enough for it to rotate 1 or 2 degrees around itself. From the valve side, that's not an issue as it is round and closes properly whichever the orientation of the valve stem. But, when the valve is fully open, this "give/tolerance" causes the small roller bearing on the other side, to misalign itself from the rail where it runs in, and momentarily get stuck, in spite of proper lubrication. Looking at ISTA+, I think that any (predetermined) deviation between value commanded and value read for more than 50 milliseconds, trips the error light on the instrument panel. And now, here I am... Also, I was under the impression that Wahler and Metzger were the OEM's, because when browsing the auto parts webpages they're advertised as such. However I was just informed by a fellow forum user, that it's actually Pierburg. P.S.: Just checked my F31. I have Wahler (bought the car used, so not sure it's the factory one - but according to my information, it should be). Looks like there are several OEM's. I wonder what BMW is using now, for the folks that were recalled... |
05-20-2021, 02:15 PM | #4 |
Rep 365
I am sure all of you in Europe get a slight variation in manufacturers for the same parts. However, our garage with 2017 X5 35d (N57) and 2018 328d (N47) both had Wahler EGR as original equipment. Mine started sticking, wife's started to let soot escape through, both were replaced through warranty with Wahler as well. Time will tell.
SpilltheBimms8.50 andreigbs71.00 |
05-20-2021, 04:48 PM | #5 | |
Rep 41
