BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Bouncing over speed bumps
European Auto Source (EAS)
      03-11-2019, 08:16 PM   #1
harperium
Stargate Command
142
Drives: 2017 340i xDrive MPPSK
Curious to what is normal and what indicates new dampers are needed. My car has 33K miles.
In my 340, I had the Eibach Pro Kit springs installed about 3 months ago. When going over speed bumps, I get a good 3 or 4 bounces on both the front and the rear.
I drove a loaner 330 GT recently and I recall that going over speed bumps at a normal speed (maybe 5 mph, not slow, not fast), both the front and rear seemed well damped and didn’t really bounce. It was a pronouced difference to my lowered 340i.
Anyway, just thought I’d ask to see what is considered normal.
If I have to get new dampers I would probably get Bilstein B8 as they are designed for lowering springs.
      03-12-2019, 09:54 AM   #2
deadserial
Drives: 2018 320ix
Has it done this since install or progressively gotten worse?
      03-12-2019, 12:18 PM   #3
cfm56d7b
Does your car still have OEM shocks? Stock xDrive shocks are too soft to effectively control the spring oscillations. This is typical behavior of stiffer springs combined with softer shocks.
anotheran265.50
      03-12-2019, 02:10 PM   #4
harperium
Stargate Command
142
The car does have OEM/stock dampers
it seems like the bouncing has gotten worse, but i don't have any hard data to back up the claim.
it was noticeable when driving the 330xi GT. over the same bumps, the GT bounced just once and was done, vs my car which does 3 or 4 bounces (each diminishing). But only over speed bumps at slow speed.
      03-12-2019, 02:40 PM   #5
anotheran
Sedan Driver
Drives: A nice car
maybe the heavy weight of the GT helped it stop bouncing but i think it's more so the above reason
Slapping on M Performance parts, ZHP, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK
BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug
      03-12-2019, 04:56 PM   #6
cfm56d7b
Your impressions are well founded.
That's why stiffer springs and OEM shocks do not usually lead to desired suspension behavior other than a lowered stance.
Coilovers would be a much better choice with additional tuning options: height, rebound and compression controls. Some coilovers offer independent rebound and compression controls for even more precise suspension tuning behavior.
      03-12-2019, 05:51 PM   #7
328dX
David
328dX's Avatar
Drives: 2015 328dX wagon
I want to say the struts are maybe blown? it can happen rather quickly with lowering springs + factory struts
      03-13-2019, 07:46 AM   #8
MacklinUSOB
Drives: f30 328i 6MT Sport
Even without lowering springs my OE 704 dampers would let the car bounce to the point of inducing nausea after 50k. Some people pretend that springs don't wear out the shock faster... :
Your inclination on them being spent is spot on.
Add 5 horsepower for every M logo
328i sDrive | Sportline | Coral Red on MW | 6MT | JB+ | MPE | GPlus FMIC | KW V2 | F80 LCA | APEX SM-10 | Michelin PS4S | EBC RedStuff | RBF600 |
Past: E36 328is & E38 740i
      03-13-2019, 08:43 AM   #9
harperium
Stargate Command
142
I don't think the dampers are completely worn out - obviously there's a spectrum. But it does feel like the dampers are half spent.
Time to start saving for Bilsteins...
      03-14-2019, 07:33 AM   #10
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
After I lowered mine with h&r sport springs the bounciness was embarrassing, to say the least. Installed b8's (inexpensive) in rear only and it transformed the ride. Eventually doing fronts, but very happy for now.
Stage 2 BM3
      03-14-2019, 01:48 PM   #11
cfm56d7b
Bilstein B6 shocks work well with OEM springs. With a shorter body, Bilstein B8 shocks are designed for lowering springs and feature stiffer dampening to compensate for shorter distance the shock has to travel.
B8 shocks and HR Sport Springs are a popular combination, although coilovers offer more suspension tuning options.
      03-15-2019, 09:40 AM   #12
Spielzeugauto
Spielzeugauto's Avatar
Drives: F31 Touring
Lowering springs will usually kill stock dampers at an increased rate. No surprise there.
B8s are a good choice
      03-15-2019, 10:21 AM   #13
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Springs don't kill shocks in 3 months. And blown shocks are usually stiff and bottom out. If it's still oscillating, it's just underdamped.
      03-15-2019, 01:54 PM   #14
harperium
Stargate Command
142
This is kind of what I'm thinking - that I am now realizing that while the lowering springs do give better handling and cornering in general, the overall suspension is a bit under-damped.
      03-15-2019, 02:48 PM   #15
cfm56d7b
The most practical way to under appreciate the combination of soft shocks and stiffer springs:
- Find a stretch of road with frequent bumps and imperfections
- Drive between 40 and 60 mph
- The bounce symptoms will magnify as the shock will fail to rebound in time
      03-15-2019, 09:43 PM   #16
328dX
David
328dX's Avatar
Dont agree. I've had it happen in 3 months or less. Also have a friend were it happened as well in about 2-3 months.
      03-15-2019, 10:38 PM   #17
harperium
Stargate Command
142
Yeah! I’ve noticed certain stretches of road that seem to magnify the bumps
I have the B8 dampers on order. Looking forward to have a “complete” sport suspension (I have the Eibach Pro Kit springs with OEM dampers now).
Edit: Bilstein B8's are still unavailable. Switching to Dinan springs + bumpstops and Koni Sport yellow dampers.
