04-03-2015, 06:15 PM | #287 |
Don't care
117
Rep 224
Shawn,
Can you send me the link for I-Step 15-03-502 psdzdata and E-Sys version 3.24.3 or 3.25.3 ? I know it's trimmed, but my car was recently updated. Thanks! Last edited by TMD29; 04-03-2015 at 06:22 PM.. |
04-03-2015, 10:46 PM | #288 |
Rep 40,744
PM sent.
04-07-2015, 06:23 PM | #289 |
Rep 90
Aaaahhh... HELP
I was coding away happily, but at the last step somehow I managed to write all modules back into ECU, not just the one I was editing. Now I'm getting a "Drivetrain Malfunction" and "Fuel-line error" messages when I turn engine on I tried resetting, but the messages don't go away. Please help...
2015 435i GranCoupe F36 Xdrive PPK
Estoril Blue II Ivory/black |
04-07-2015, 08:51 PM | #290 | |
Rep 40,744
04-08-2015, 08:42 AM | #291 |
Rep 34
Hi Shawn, i have an f20 MY 2013 and in a few days i will retrofit the nbt system. Already bought the enet cable. Could you send me all the software needed for my car to start coding? Also a manual or tutorial with step by step guides on how the e-sys works would be nice, i am a complete noob. Thank you for your help and time you spend for all of us
04-08-2015, 09:14 AM | #292 | |
Rep 40,744
04-09-2015, 01:24 PM | #294 |
Rep 40,744
PM sent.
04-09-2015, 02:38 PM | #296 |
Rep 40,744
PM sent.
04-11-2015, 08:51 AM | #298 |
Rep 40,744
PM sent.
04-12-2015, 05:14 AM | #299 |
Rep 88
Another request...
Hi Shawn
My car is going in for its first service and I know they are going to update the NAV (have 02/14 F31) to the latest version. Would you please send me the links for the latest software downloads please. Thank you
F97 Brooklyn Grey X3M Comp /// In Transit...
"Rules are for the obedience of fools and for the guidance of wise men..." Douglas Bader |
04-12-2015, 05:16 AM | #300 |
Rep 40,744
PM sent.
04-12-2015, 05:47 AM | #301 |
Rep 88
04-12-2015, 02:13 PM | #302 |
Rep 241
Thanks Shawn for all the help!!
I just went on a 45 minute coding frenzy. Coded off day time running lights / led, coded foglights to turn on when unlocking, coded foglights to turn on when turning left or right, (directional), turned on keyfob to unlock windows and open windows when holding on unlock/lock. Coded mirrors to close when I lock the car and open when I unlock the car I'm loving this
Charlie Vu
2013 328iX Melb RED- JB4 - AFE 5R Intake - B14 Bilstein - Morimoto H1 Projectors and LED Angel eyes- Morimoto HD Elite 50w 5500k H.I.D. |
04-12-2015, 03:05 PM | #303 |
Rep 50
I'm getting this error when trying to read KOMBI. I have no problem reading any other ECUs.
Transaktions-Report: Aktion: Codierdaten lesen KOMBI [60] [F774093] readCPS o.k. CAFD_000009C8_006_000_030 Fehler: NCD read from ECU "ECUId:KOMBI_0x60" for CAF "cafd_000009c8-006_000_030" failed! [C069] Error processing XML data [1660] Can anyone please tell me what I'm doing wrong? |
04-12-2015, 07:17 PM | #304 | |
Rep 40,744
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on KOMBI ECU => Click on "Detect CAF for SWE" => Select cafd_000009c8.caf.006_000_031 from any I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE
04-12-2015, 08:25 PM | #305 | |
Rep 50
04-13-2015, 03:40 AM | #306 |
Rep 1
Hi Shawn,
My car's an F31 from Sept 2013. The car's software has been updated by the dealer early Jan 2015, but I'm not sure (yet) which data version they used. I ordered a cable which will arrive any moment. Can you please PM me the links to the E-Sys software and both the latest PSDZData (55.x) as well as the 54.1 data? Thanks! |
04-13-2015, 05:35 AM | #307 | |
Rep 40,744
04-13-2015, 07:19 AM | #308 |
Rep 1,035
I added (swapped) a new REM to my F30 and injected a new CAFD for it. I used the Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on REM ECU => Click on Detect CAF for SWE => Select the new CAFD from my I-Level => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE
I did it to get rid of a 'Trunk Open' warning on the dash that wouldn't go away. Everything worked, but I was curious about two things: 1) How does E-Sys know what the new hardware is? In the above procedure I had always thought that E-Sys is just reading generic VO option data from a config file and everything is just default data for a standard F30 with my original options. I mean, you even have to manually pick the CAFD file based on your I-Level. So at what point in that procedure does it determine (i.e. probe H/W or read the actual ECU) a new REM has been put in its place? 2) What does it mean when the ECU is colored blue/red below? I believe that showed up right after i selected the new CAFD for my I-Level but just before i clicked on CODE. |
