BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Who here torques the oil drain plug and filter housing?
      10-19-2019, 12:14 PM   #23
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's 8 Nm for the plastic plug/pan, 25 Nm for the metal plug/pan.
      10-20-2019, 02:14 PM   #24
IraHayes
Drives: 635csi
I’ve always tightened the cap until snug. Up until my last oil change I always used a torque wrench for the drain plug , but my “small” torque wrench is a dial type, so kind of hard to read when you’re on your back looking up, especially since the car is so low, even on ramps. I need to invest in a click type.
      11-18-2019, 09:07 PM   #25
leejak
Drives: E92 M3, F12 6401ED, F32 428i
I torque the oil filter, but not the plastic drain plug
      11-18-2019, 10:09 PM   #26
Billfitz
Billfitz's Avatar
It should be the other way around. Too little torque on the plug and it leaks, too much and it breaks. The way the O-ring seals the filter cap makes for a tight leak free fit even if it's not torqued down. I've seen reports of filter cap leaks but only when a new O-ring wasn't used.
      11-26-2019, 10:18 PM   #27
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
That new o-ring is key.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
https://www.facebook.com/newfinishcolumbia
http://www.instagram.com/newfinishcolumbia
