08-21-2019, 09:01 AM | #1 |
Rep 833
Drives: BMW F36, E36, E93
Forgot drainage?
Why ist this happening and is in only on my car? I expected som dainage holes?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
08-21-2019, 10:51 AM | #2 |
Rep 16,076
Mine is the same way, they probably decided that it wasn't worth the bother when evaporation would do the same job. It's not like there's anything that will rust.
09-02-2019, 06:02 AM | #4 |
Rep 3,868
Has been discussed around here before. (If someone finds the link, please post it).
Bottomline: - Design is as is, as the same plastic molding is used both for LH and RH vehicles (reversed wipers) - No drain holes is a weird design decision, but a fact - Some users have drilled holes in there with no negative effect observed. I am inclined to do the latter, but would like to know what is underneath and whether the water has a safe path out...?
09-15-2019, 08:12 AM | #6 |
Rep 303
Yep, this is normal. There are no drain holes. Again, someone posted a pic with a hole drilled into the plastic to allow the water to drain. I just don’t know what’s underneath so not sure if that’s a safe option.
Every time I was my 2016 435i, after rinsing, I immediately open the hood and take an old towel and blot out the pooled water in those areas first. It’s not just become a habit to get that water out. |
09-25-2019, 05:00 AM | #7 | |
No 55mph
1621
Rep 8,476
Been that way for yrs, no harm done, there is nothing in the path of the water draining that will get damaged Just because BMW didn't put one there originally doesn't mean that putting a hole in is a bad thing - there is a TSB out for the very bottom drain vent that BMW DID put in that needs to be removed due to the fact that it clogs and water will NOT drain completely - so it's not like BMW engineering is foolproof
09-25-2019, 04:12 PM | #8 |
Rep 3,868
Could you provide a photo of your drainage?
10-17-2019, 07:22 PM | #9 | |
Rep 58
10-17-2019, 07:24 PM | #10 |
Rep 58
10-21-2019, 08:27 PM | #12 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
It is dirt. He is mistaking the reflection on the left side for rust.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
11-21-2019, 02:01 AM | #17 |
Rep 79
^^^^ interesting. Are the holes connected to anything underneath (such as a drain tube), or does it openly drain onto the "shelf" and wire harnesses before eventually draining onto the ground normally?
11-22-2019, 03:05 PM | #18 |
Rep 1,141
I'll have to check, but I think it just drains onto the "shelf" underneath. Certainly nothing like a drain tube connected to them.
