BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Can someone help me decipher my Carly diagnostic report?
proTUNING Freaks
      08-04-2016, 11:42 AM   #1
badbread
not good, but bad
Drives: 2013 335i
Hi everyone,
I can't seem to find anything pertaining to the codes Carly spits out when performing a diagnostic. There are brief descriptions of the error code but I can't find any documentation explaining what the codes mean. Below is an example of what Carly spits out. I am unable to find any info on the "codes" shown below. Some are self explanatory but others like the "ABS + DSC" thing I can't figure out.
Am I missing something really obvious here?
Thanks!
Code:
Motor Control:
Engine / Motor
Throttle angle - intake manifold absolute pressure, Comparative pressure too low
Code: 101F01
ABS / DSC / Brake:
Dynamische Stabilitäts Control / DSC
ECU OK, no Fault Code
Heating / AC:
Air conditioning / Klimaanlage
ECU not present/no response from ECU
Immobilizer System:
Body Domain Controler
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Systems:
Infotainment
All function blocks Registered most nodes
Code: E1C447
Monitoring circuit reset was triggered
Code: E1C440
Chassis:
Steering /Lenkung
Electronic damper / Elektronische Daempfer
Body:
Automatisches Front Steering
Rear Electronics Module / Elektronik Modul hinten
Relay glue or fuse failure or short circuit to ground Fh Bfh, relay closing No output
voltage
Code: 030181
Integrated Chassis Management Quer/Längsdynamik
With greater uncertainty direction Vx 2 M/S- Sbs function
Code: 480134
Other:
Advanced Crash and Safety Management (ACSM)
Central Gateway / zentrales Gateway
:Synchronization failed
Code: CD0487
Fuel pump / Kraftstoffpumpe
Getriebesteuerung /Transmission
Tire pressure control / Reifendruck Kontrolle
Telephone
Hifi Amplifier / Verstaerker
ABS + DSC
:Sine: internal supply voltage
Code: 801A4C
:Temperature sensor 1 failure
Code: 801A56
Gear switch / Gangschalter
Instrument cluster / Kombiinstrument
:System time is set back
Code: B7F668
      10-23-2019, 04:11 PM   #2
Sippy
Drives: 2016 BMW 328d xDrive
Hmm, I was going to post a similar request. Given that this is 3 years old and doesn't seem to have any responses on it, perhaps I won't... :/
