01-18-2020, 10:40 AM | #2839 | |
Rep 1
01-24-2020, 05:16 PM | #2840 |
Rep 24
I think that the box needs only the two video signals coming from the two cameras. Then, when you put in reverse gear, the rear camera gets powered and the box switch to the rear camera because you can set the box to have a priority input (in this case the rear camera).
Then, when you put the first gear, the rear camera turns off, so the box switches to the front camera, which is powered by the 12v cigarette lighter current. I also want to buy a front camera and this box, I have a manual gearbox without front PDC, but I don't know the parameters to code with esys, because now, when I put to first gear after reverse, the PDC interface closes as soon as I move forward. |
01-25-2020, 02:26 AM | #2841 | |
Rep 56
02-06-2020, 02:46 AM | #2842 |
Rep 8
I have just installed my PX3 HU and when I switch tot he regular CCC Menu I get the NO SIGNAL screen, however after changing the settings back and forward (NTSC to PAL), I can barely see the CCC Menu but it fades and I get this moving lines... what is this about, any ideas?
02-06-2020, 08:05 AM | #2843 |
Rep 12
Sorry to burst your bubble, but mine did the same thing now and then till it broke down for good (a few months later). Now it won't even start anymore, just artifacts or black screen.
It seems that the CPU has died and I need a new PX3 board. Maybe reballing will get it fixed, but from previous experiences, it would be a miracle to last more than 3 months. Can anybody help me with a spare PX3 2GB RAM, 32GB ROM, Android 7.1.1 board? Also, an upgrade to PX6 would be nice. Thanks. L.E. Here's an old video with my faulty, but still functioning HU (to some degree): https://drive.google.com/file/d/1B9O...zUJr5n_wh/view Now it's completely dead. Last edited by fullrespect; 02-06-2020 at 08:17 AM.. |
02-06-2020, 09:39 AM | #2844 |
Rep 8
My error is different. The android part works flawless, it's only when I switch to CCC that I get the no signal screen, and if I stop the MCU from system settings, then I get this static for the CCC instead of the No Signal. If I switch back to android, everything works. I will make a video
02-06-2020, 12:50 PM | #2845 | |
Rep 7
Keliuss
E60 LCI N47
Android 7.1 PX3 |
02-08-2020, 10:24 AM | #2847 |
Rep 34
can anyone point me to the latest updated compatible MCU, Android and factory xml-file? My PX3 Unit is crashing some times and I hope this gets solved with an update. Here's a pic of the settings:
Thank you VERY much!! |
02-08-2020, 02:13 PM | #2848 | |
Rep 220
Drives: MINI Cooper, 2020 X1
02-09-2020, 04:31 PM | #2849 |
Rep 1
Someone can help me with the newest update for the MCU or Android? I will really appreciate https://ibb.co/QXK92h1 |
02-09-2020, 04:41 PM | #2850 | |
Rep 1,048
Latest Update for Android 8.1 PX6 Units is available here. Unfortunateley ALS MCU`s are not very common, i know no update there, maybe your seller can help you there. Kri |
02-09-2020, 04:53 PM | #2851 | |
Rep 34
Thanks a lot. I upgraded the MCU. I also got a PC3-Image from somewhere, but not sure if it's the latest one. Do you guys have any Android 7.1.2 image laying around? Is it worth the update to a newer one? |
02-10-2020, 05:30 PM | #2852 | |
Rep 7
Keliuss
E60 LCI N47
Android 7.1 PX3 |
02-12-2020, 02:51 PM | #2853 |
Rep 2
newcomer to android head unit
Hi everybody!
Have some issues i'm hoping to get help with. Anyone been able to change the phone/calling app? Would like to get contact sync and also the preinstalled one is just buggy and ugly. Also my idrive or steering wheel buttons don't work for 15 minutes from when I start the car. After that everything fine again. And lastly i'm unable to change the brightness om my device. Seems to be on max all the time that bothers the driving when its dark. With these in mind i would like to update my device and hope the issues get resolved or load a custom rom, Malaysk for example but cannot figure out MTC version (B/D) i have and what roms are compatible. Would like not brick it . My MCUVer is: 415144bLZH-CCC-HW8_180921 [B1280_170325] Framework: px3-userdebug 7.1.1 NMF26X From this i'm starting to thing that I nether have MTCB or MTCD but some other kind and custom rom is not an option. These forums have a link to the github where there is an MCU file for my exact unit but that one has an older date 180907 then the one I already have installed. Thanks in advance! |
02-19-2020, 03:17 PM | #2854 |
Rep 8
Guys, what vendor is LHZ? Does anybody know?
@inku79 could you please send me your MCU, I would like to try in on my unit. Also if you have 2GB Ram, you have the MTCD unit. Also I have found a new PX3 image with ID7 skin, picture bellow. http://s.go.ro/xri1tbsl Last edited by phatsua; 02-19-2020 at 04:09 PM.. |
Keliuss1.50 |
02-20-2020, 04:53 PM | #2855 | |
Rep 7
Keliuss
E60 LCI N47
Android 7.1 PX3 |
02-22-2020, 01:58 AM | #2856 | |
Rep 8
I want to buy a CarPlay adapter as I find the interface better than android tho. |
02-22-2020, 04:43 AM | #2857 | |
Rep 2
Also the idrive and steering wheel buttons sometimes work and sometimes don't. Have got use to it but would like to get it working. Tried to the MCU file from these forums with the lower version but get "MCU update file not found". FAT32 memory stick with the file in root. Will try out the image that you have uploaded. Just need to search forums on how to :-). Been a while since rooting and loading custom roms and Android head units seem to work differently. Any help or link to instructions would be appreciated. Where would I find the MCU file from my unit. Can share, no problem. Also the unit brand is Taffio and sold by realmediashop and also on German Amazon. Thats alla I know about it. Did e-mail realmediashop about an update but unsurprisingly no response from there. |
02-22-2020, 03:31 PM | #2858 | |
Rep 7
All the info and more are in that link. Taken from above site: Updating the firmware The procedure for updating the firmware is listed below: Format an USB drive (or SD card) as FAT32 with an MBR (not GUID!) partition table. Place the mcuupdate.bin file in the root of the drive or SD card. Navigate to settings -> system info on the unit. Press the Firmware Upgrade button. Click on the check mark to apply the firmware update. Wait for the firmware update to complete. It should count from 0 to 100%. It will automatically reboot the unit after the update is complete. Keliuss
E60 LCI N47
Android 7.1 PX3 |
