10-22-2019, 12:31 PM | #23 |
Rep 3,539
Yes I have the same K-MAC tension strut and wishbone bushings, however my ride height isn't much lower than OE. My hub to fender distance is about 14" in the front. IIRC my lowest front hub to fender distance was around 13.75".
10-23-2019, 08:42 AM | #24 |
Rep 1,286
Well, K-MAC said there shouldn’t be any problems even if your car is lowered so I don’t know if he understood what I was asking, but nevertheless, my shop said they’re going to look at the entire geometry of the suspension and arms after install and go from there with best adjustments.
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
10-23-2019, 09:04 AM | #25 |
Rep 3,947
You f'ed up by getting a 335i. You should have gone with a mid 2000s dually with a lift kit if you really want nimble handling.
10-23-2019, 11:02 AM | #26 | |
Rep 3,539
I did the beta testing for the tension strut and camber bushings for K-MAC. It was VERY obvious that they hadn't tried to put them on our xDrive cars when I got the parts. I went through three iterations of the tension strut bushings alone.
pkiledj46.00 |
10-23-2019, 12:04 PM | #27 | |
Rep 1,286
If not, I might just return these and call it a day. Why pay for these and risk damage for hardly any camber?
10-23-2019, 12:13 PM | #28 | |
Rep 3,539
You still need to do your homework too by taking a look at your suspension geometry with the current amount of lowering you have and seeing what your hub to fender measurements are.
10-23-2019, 12:18 PM | #29 | |
Rep 194
10-23-2019, 04:52 PM | #30 | |
Rep 1,286
10-23-2019, 07:16 PM | #32 |
Rep 681
I'm at 13.5" and I ran -1.1 no problem when I had camber bushings
2016 328ix F31 - SOLD!
2006 997.1 C4S |
10-24-2019, 02:26 PM | #33 |
Rep 194
10-24-2019, 05:38 PM | #34 |
Cheapskate
4447
Rep 4,993
In general. BMW puts more bias to the rear so the front has less traction and tends to understeer. You need to push more traction to the front end and stiffen up the rear to promote rotation and hide the car's weight.
Littlebear3509.50 |
10-25-2019, 08:32 AM | #35 |
Rep 1,286
The KMAC camber and caster adjustable bushing were a borderline useless upgrade. Hardly any difference outside of slightly better cornering due to the increased negative camber at -1.75. No change in steering feel or response.
And the shop didn’t think it was a very high quality product either. Waste of $1500!
10-25-2019, 09:52 AM | #36 | |
Rep 345
10-25-2019, 10:37 AM | #37 | |
Rep 3,539
There are a couple of reasons you may be feeling the way you do: 1) Alignment not set up to take advantage of parts, or out of cal alignment rack so you don't have what you think you have. 2) Other limiting factors on your car, so the headroom the bushings provide can't be reached. 3) You're just numb, and can't feel the difference, in which case no other bushings/monoballs will help you either. If you really think that a degree of camber change doesn't have much effect when the suspension is properly aligned, well there's plenty of evidence to the contrary...
10-25-2019, 05:34 PM | #38 | |
Rep 194
Or does that include the price of bushings, which are like $700-800 for all 4 right? Thanks for the feedback! I was skeptical about the improved steering from bushings. I think the issue with the steering in our cars is the servotronic more so than bushings. But that's just a guess, I'm by no means an expert. Man I miss my e46. So far I'm at $2500 in mods and still chasing the e46 feeling. Hmm... |
10-26-2019, 07:46 AM | #39 | |
Rep 61
The Rear bar made a huge difference to the feel of the car, really makes it more solid, As did the poly bushes in place of the hydro bushes, I can definitely feel more through the steering, only negative is that you can now feel the under steer!! The only issue i see with the poly bushes is that they do not allow any lateral pivoting which i presume a uniball bushing would, when you move the sterring through its full range with hydro bushes they pivot laterally, i am not sure stopping this is a good thing as the suspension maybe designed to pivot at that point, this maybe why some say poly bushes don't last. |
pkiledj46.00 |
10-26-2019, 12:54 PM | #40 | ||
Rep 194
10-27-2019, 07:35 AM | #41 |
Rep 61
X-drive, next up is springs, probably Eibach but i keep swaying between the 05 and 06 springs. I think the 05 are stiffer and lower at the front however i read that the rearwards rake of the 06 helps limit understeer by keeping more weight over the rear.
pkiledj46.00 |
10-27-2019, 10:59 AM | #42 | |
Rep 194
I have the Dinan springs/bump stops/ Shockware, definitely a huge improvement over stock but still way too soft and floaty in comfort mode. |
10-28-2019, 09:56 AM | #43 |
Cheapskate
4447
Rep 4,993
I should clarify that my mods were strictly for performance. The car will rotate easier, but it won't necessarily communicate better. Some mods will be worthwhile if you're timing laps, but may not net a huge difference in "feel."
You can tune the differences in feel through the steering wheel, but it won't match a hydraulic system. You just have to be more aware of where the car is. I enjoy the feel of hunkered down stability so I like my 4 series, but if you want a light, nimble go kart then it's not going to get you there. Primarily you need something with a shorter wheel base. |
10-28-2019, 12:19 PM | #44 | |||
Rep 205
Drives: 14 F30 335i xDrive
Also don't underestimate how much an alignment effects the tendencies of how the car rotates. Anything close to factory specs will make it not as responsive and tend to understeer. A little toe in at the rear with 0 toe or even toe out at the front, with as much camber as you can get away with (3.2 for track & 2 degrees for street is what I run at the front) will help make it feel more alive. Quote:
