11-05-2019, 09:04 PM | #1 |
The New Guy
Rep 9
What Exhaust do I have?
Hey all!
I just purchased a slightly used (5k miles) 2018 340i from a BMW Dealership. The car has a few of the cosmetic M trim packages on it. My question is, does the stock exhaust have M's on the tips? I thought that was only for the MPE. Any idea what exhaust model this is? My packages: P337A S704A S710A S715A Thanks! |
11-05-2019, 11:52 PM | #5 |
The New Guy
Rep 9
Thanks! I appreciate it!
alohasurftoad3078.00 |
11-06-2019, 01:17 PM | #10 |
Rep 159
He means you're screen will have higher max numbers. For 335 n55 engines stock your sport display says 300 and 300 max after mppsk the sport screen shows 320 and 320 as your max numbers .
I'm not sure what the numbers are on a b58 motor though if I had to guess 320 stock and 340 with the mppsk If you're interested in the tune often times you can find a sticker in your engine bay that will confirm its installation and date |
11-07-2019, 08:34 AM | #17 |
Rep 248
11-07-2019, 08:52 AM | #18 |
Cheapskate
4447
Rep 4,993
It's the same for both. But on stock tune, the actual indicator only goes up to 320hp. On an MPPSK car, it'll go higher. You basically have to floor it and see what the peak value was.
11-07-2019, 12:22 PM | #19 | |
Rep 1,010
As far as I remember the max HP was raised after MPPSK but I guess you guys are right.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
11-15-2019, 08:54 AM | #20 |
Rep 205
Drives: 2015 BMW X5 50i
MPE vs. MPPSK
Hey guys, if the exhaust says 'M Performance' in black on it under the back bumper, then this is just the axel-back exhaust which is different from the exhaust that comes with the MPPSK. You can buy it for about $1,200 or so I believe. You will still have the muffler/ resonators on the exhaust.
The exhaust system that comes with the MPPSK is a full cat-back and is straight piped all the way back. It also has 'M Performance' stamped on the metal under the bumper instead of in black. The full MPPSK will also give you the small badge under the hood. Also, all 340i's show a max of 400 hp on the sport displays. Hope this helps!
2015 X5 50i - Current
2011 E92 M3 - Sold 2016 F30 340i - Sold |
NormanConquest4038.50 |
340i m performace |
