BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > HPFP New Option
      10-16-2019, 09:35 PM   #397
ZM2
Drives: 2017 LBB M2
Originally Posted by Phantom10R View Post
Same way they do in warmer weather
Can’t tell if this is serious or not.
E30 strains the HPFP. When it’s colder and IATs are lower more fuel is delivered, which strains the HPFP even more.
Hoping to see some logs with E30 in colder weather to see what these OEM replacement pumps are capable of, or if we still have to go with higher flowing aftermarket pumps.
      10-16-2019, 09:38 PM   #398
RSicks
Typical Car Guy
RSicks's Avatar
Drives: 2015 435i M-Sport
I run E30 on the stock HPFP year long and never had an single issue with crashing due to weather... not sure why this upgraded one would.
'15 435i ///M Sport
CTS Intake • VRSF CP/Race FMIC/DP/TIC • MST Inlet • xHP S3 • 3.5 TMAP • Dorch S1 HPFP • Wedge Tuned
      10-16-2019, 09:45 PM   #399
ZM2
Drives: 2017 LBB M2
This brings up a question that will pull the OP back in.
I have an M2 with a Dinan turbo and I cannot run E30 when ambient is below 60F, or it will crash the HPFP (E25-26 works). That’s at around 18psi for me, which may not be for you, and when the OP said the HDP5 evo pump didn’t work on E30 was it bc of higher than 18psi boost?
There’s a lot of factors to the HPFP crashing so just trying to draw some data points.
      10-16-2019, 11:19 PM   #400
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Your perception of cold weather probably isn't shared by 2/3 of the continent.
I can't run E30 below 45f, really needs mid 60s to be good.
ZM22809.00
      10-17-2019, 08:18 AM   #401
JaredG_F30
JaredG_F30's Avatar
1106
What tune are you running? I had this issue with the previous rev stage 2 E30 OTS map from bm3. The most recent tune implemented revised boost and fueling targets. I'm running E30 now, was 45F this morning and enjoyed a bit of spirited driving with now issues. I have also run many logs to redline with no crashing, whereas before crashes after 6k RPM were frequent. On a side note, I'm running meth now to give a little headroom on fueling.
SPI Films Blog/DIY Vids
ZM22809.00
      10-17-2019, 08:35 AM   #402
ZM2
Drives: 2017 LBB M2
I was running BM3 Stg 2H E30 5.5 & 5.7 maps from Halim and would have HPFP crash issues when ambient was below 60F.
I’m now running OTS Stg 2 E30 5.8 with E26 (E30 in summer), but now that we’re getting cooler weather I’ll try upping to E30 based on your feedback.
Thanks!
      10-18-2019, 07:14 AM   #403
T_H_O_M_A_S
Drives: M140i
with hdp5evo you can max out the stock turbo on a M2 n55 and Emix
if you go aftermarket turbos , you need a bigger one like the hdp6 or xdi or else
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
ZM22809.00
      10-18-2019, 10:57 AM   #404
ZM2
Drives: 2017 LBB M2
Got it.
Have you tried running a high Emix with your HDP6 to see how it holds up?
      10-18-2019, 04:13 PM   #405
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
Is someone gonna start selling the hdp6 modified for pnp on the n55?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      10-18-2019, 08:03 PM   #406
ZM2
Drives: 2017 LBB M2
Well, I tried E26 tonight while it was 54F ambient and was getting HPFP drop outs above 6k RPM. Lowered to E25 and no drops, but HPFP is going down to 1400psi.
I wasn’t watching boost levels, but MAF is hitting right below 44 lb/min so I’m just finding the limit of the stock HPFP.
Anyone finding the HPD6 pumps for <$500?
      10-18-2019, 08:50 PM   #407
Pray for Mojo
I snagged one for less than $500. I would search ebay.de it brings up more options for BMW parts.
ZM22809.00
      10-26-2019, 12:01 AM   #408
VAF30
VAF30's Avatar
Drives: 14' F30 335i
New video with B58 pump and BigBoost turbo kit
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
      10-26-2019, 04:38 AM   #409
T_H_O_M_A_S
Drives: M140i
first confirmation it works pretty good on N55
      10-26-2019, 11:49 AM   #410
52172
52172's Avatar
We need someone to sell these retrofitted for the n55. Is anyone talking of doing it?
      10-26-2019, 11:58 AM   #411
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Not sure it would be cost effective. After time and materials, margins would be too close to current/up coming options which provide higher flow rate
This is more for the DIY'r . 🍻
My Build Thread can be found HERE
      10-26-2019, 02:08 PM   #412
paul223
paul223's Avatar
Drives: F10
Lol, it is taking forever for new option of HPFP!
      10-26-2019, 05:32 PM   #413
T_H_O_M_A_S
Drives: M140i
the work done to it is actually pretty easy , the pictures speak for themselves .
just take your time for it , i'm gonna talk to nv from that you tube movie and ask them how they overcame the connector/intake prob , did they do the same approach or found something else
      10-29-2019, 05:38 PM   #414
beastwood
Drives: 135i
Can anyone tell me which b58 pump is this? The evo5 or 6?
      10-29-2019, 06:16 PM   #415
T_H_O_M_A_S
Drives: M140i
hdp5 evo has a dimple in its dome and is more hexagonal
hpd6 doenst but has a thicker baseplate .
upper picture is the 5 evo and oem , lower is the hdp6 mounted in my car
      10-29-2019, 06:22 PM   #416
beastwood
Drives: 135i
Evo5 I assume
      10-29-2019, 06:23 PM   #417
T_H_O_M_A_S
Drives: M140i
yes 100 percent
      11-15-2019, 05:18 PM   #418
beastwood
Drives: 135i
yes 100 percent
Would there be any reason why my car would be running rough after putting in the evo pump in? It's on stage 2 BM3. Ran fine on my n55 pump now it's running really rough. Any coding has to be done?
