12-29-2014, 10:37 PM | #1 |
Rep 3,089
Coding ? - comfort access and folding mirrors
I was wondering what would happen if I coded the following:
Close windows/fold mirrors when holding lock on Key Fob: FEM_BODY/3053/KOMFORTSCHLIESSUNG_FB to aktiv Fold mirrors when holding lock on Key Fob or Comfort Access: FEM_BODY/3110/ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN to aktiv Will these two codes conflict with one another? What I definitely want to do is to have the mirrors fold when I press and hold the door handle in Comfort Access. My manual says this should happen by default but my car only locks and closes the windows. |
12-29-2014, 11:51 PM | #2 | |
Rep 1,892
You also need to code FEM_BODY / 3110 / ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN to aktiv to unfold the mirrors and windows via CA or the fob. |
12-30-2014, 11:03 AM | #3 | |
Rep 3,089
FEM_BODY 3053 KOMFORT_SCHLIESSEN |
12-30-2014, 11:15 AM | #4 | |
Rep 1,892
The KOMFORT_SCHLIESSEN value (werte=xx) is the amount of time you have to hold CA or the fob before the mirrors will fold. The default value is 0F (in hex) and the units are in 100ms (1/10 of a second). That's 15 in decimal, or 1.5 seconds. That's way too long for most people. I code this for people one of 2 ways: 1. If you want the mirrors to fold every time you lock the car (people use folded mirrors as the verification that the car is locked), then set the Werte value to 00 (no delay). 2. If you don't want them folded every time, but want a shorter delay, I usually set the value to 02 (200ms or about 1/4 second). A short touch/click will still lock the car, but holding it just a little bit longer will fold the mirrors. To roll the windows up or down (and the sunroof), you have to continuously press the fob button (probably a safety feature). There is no one-click windows up/down feature as far as I know. Last edited by Frogman; 01-01-2015 at 02:33 PM.. |
04-02-2016, 03:35 PM | #5 |
Rep 1
Hi,
I know this thread is quite old now, but I have been told that to get the auto folding mirrors using the keyfob you have to have the comfort access. By default I understood that with comfort access, this would be the case by default (without needing to code). So based on that, I dont believe you can code it unless you have the comfort access? I have in the past got someone to code the mirrors for me, but it never worked. Whether this is because I need comfort access or whether the code change just didn't apply properly I am not sure. I paid for what I thought would do this, but all I get is the button inside the car that I can press to fold/unfold, and therefore you actually need 2 options in order to have the auto folding mirrors :-( Now, I have also heard that for security reasons, they have disabled the auto folding part of it, so I am now not sure whether buying comfort access will actually allow the mirrors to fold/unfold with the keyfob...I am still trying to find that out, but to be honest, half the BMW staff don't seem to know either, so maybe the functionality is available with the comfort access pack, but you may still need to code it (to override it being turned off)? I am so confused with what actually is needed these days to get half of the features, and am going through a battle with BMW dealer at the moment because of half the things that they said was included and later established is part of a pack/option which I actually asked about in the first place. I think the problem is that they change so frequently that it is hard for the staff to know what things actually do....and then because of everybody suing for the slightest of reasons, this then explains why they turn everything off to save them from a law suit!! Sorry for the rambling, but just wanted to mention what I had been advised of regarding the comfort access. Not sure if this helps or makes things worst! lol |
04-02-2016, 11:48 PM | #6 | |
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
09-06-2016, 12:05 AM | #7 |
Rep 2
Endurance specification of motors in folding mirrors
Hi - I was thinking about coding my F32 to automatically fold/unfold the mirrors when I lock/unlock the doors, but I was curious if anybody knows how many fold/unfold cycles the mirror motors are rated for? I'd estimate that I'd incur ~2000 lock+unlock cycles per year, and as a reference point, I've had my E46 for 15 years and counting, so I'd want the motors to endure ~30,000 lock+unlock cycles during their lifetimes.
Thanks in advance for any insights! |
09-06-2016, 07:02 AM | #8 | |
Rep 40,756
Personally, I wouldn't worry about it. A car held that long will need mechanical repairs. If it is not the Mirrors, it will be something else.
09-09-2016, 03:34 PM | #9 |
Rep 2
Thanks for your comments, Shawn! I'll take your advice and cross my fingers. Assuming US-spec cars use the same mirror motors as their Euro-counterparts, I'll asume the motors were spec'ed appropriately.
09-11-2016, 01:36 PM | #10 |
Rep 309
I coded to have my key fob open/close windows unfold/fold mirrors and open/close sunroof. I can open them by holding the open button on the fob but closing does not work at all. It does work if I touch the comfort access close on the door handle. Can anyone help?
09-12-2016, 12:11 PM | #11 | |
Rep 1,892
1. A common mistake is to manually change the werte value when you change KOMFORTSCHLIESSUNG_FB to aktiv. Don't do it, just change the parameter to aktiv! This is one coding value that the werte value is opposite normal; aktiv is werte=00, nicht_aktiv is werte=01. If you also set it to 01, you reversed your change. 2. Another common mistake is to change KOMFORTOEFFNUNG_FB instead of KOMFORTSCHLIESSUNG_FB. 3. You changed all 3 variables, right? Did you set ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSUNG and ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSUNG to aktiv (werte=01) too? |
10-10-2016, 12:26 PM | #12 |
Rep 8
Hi ,
I have just seen this thread ( new member ) . My car has comfort access but the mirrors will only fold in by holding the lock button on the keyfob not with comfort access , however they do unfold when opening using CA. Annoying! So , just to confirm , when going in to change the settings I have to make sure that all four listed below are set to "aktiv" , is that correct? 3053 KOMFORTOEFFNUNG_FB 3053 KOMFORTSCHLIESSUNG_FB 3011 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN 3011 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN |
10-11-2016, 07:33 PM | #13 | |
Rep 8,364
int47.50 AriZoNaiCe0.00 |
10-22-2016, 01:13 AM | #17 |
Rep 133
Need some help here. The folding mirrors is the one thing that, no matter what I try, I can't get to work on my 2013 335XI. I followed all the instructions in this thread; I have coded all 7 values mentioned (in Almaretto's very helpful post, post #13 in this thread) to 'aktiv'
The one thing that stands out to me is that the FEM_BODY/3053/KOMFORT_SCHLIESSEN werte value of "00" may not be sticking? When I select "werte = 0F" and change it to "werte = 00", the box right under Ausgelesen (wert_01, which is typically the only option in that drop-down) changes to "UNKNOWN". I'm thinking this might be my problem? My understanding is that the "wert_01" must remain in the drop-down, but the "werte" under it needs to be 00 or 02 (or anything but 0F)? Can someone please confirm, and let me know why you think this might be happening"? The UNKNOWN appears when you click "BACK" on the FDL and go back into it-- but if you remain on that page, the box remains as "wert_01". Screenshot: http://www.trunkspace.ca/KOMFORT_SCHLIESSEN-WERTE.png |
10-22-2016, 01:19 AM | #18 | |
Rep 8,364
10-22-2016, 09:48 AM | #19 | ||
Rep 133
Does yours show "UNKNOWN" above (like in my screenshot) after changing the werte value? |
10-22-2016, 11:30 AM | #20 |
Rep 254
Drives: 2020 BMW M340i xDrive
This post was a huge help - I coded the mirrors a few times yesterday and couldn't get it to work - after reading this post I got it all working! My mistake was not setting KOMFORT_SCHLIESSEN to 00.
Interestingly though - on my car when locking the doors with comfort access, I still need to hold onto the handle for one extra moment to get the mirrors to fold in. If I hold the door handle until it beeps, the mirrors don't fold in - but if I hold it just 1 extra second it works. Using the Keyfob, it folds instantly. Unfolding is instant for both keyfob and comfort access. |
10-22-2016, 07:00 PM | #21 | |
Rep 133
10-22-2016, 08:51 PM | #22 | |
Rep 8,364
For me, because the keyFOB has a physical button, it is more difficult to separate the act of locking from movement compared to a quick firm press of CA ridges. But, either way, contact must be maintained anyways to fully close windows/ sunroof. Anytime you set a werte to something other than a value corresponding to a predetermined drop-down menu, UNKNOWN will appear above when reading said funktion; this is normal. |
