11-16-2019, 02:00 AM | #2817 | ||||
Rep 56
11-29-2019, 02:45 AM | #2818 |
Rep 24
Hi guys, I noticed that, since I mounted this Android 7 10.25" screen on my bmw f30 sport, I'm not able to change the ambient light brightness, I can only change the color from orange to white(classic/sport), but when i set a different brightness it's not change and remains always the same.. can you please try if someone have this problem?
12-10-2019, 08:17 AM | #2819 |
Rep 80
Hello, i have a problem with my android radio that i posted in another post call experience with 9.0.
My problem is that i cannot use the radio because it doesnt boot on android menu, only appears no signal. Where can i get a .img for an px6 9.0 to restore it with sd car boot tool? Thank you! |
12-28-2019, 12:54 PM | #2820 |
Rep 20
Hi. I purchased a screen. I purchased CIC version. It doesn't work. My screen looks CIC, Bimmertech told me I had CIC from vin number. I contacted seller and he said from lvds plug it looks like mine is NBT. Can you guys confirm for me from these pics? Thanks
01-04-2020, 11:27 PM | #2822 |
Rep 2
I have unit with android 9.0. Is there a way to put bluetooth active on the unit side so that it would search for bt devices and could connect to them? It would be great if so, then you could use Carly, bimmercode etc. from the device.
01-05-2020, 03:37 AM | #2824 | |
Rep 1,048
Kri Last edited by Kri; 01-05-2020 at 06:23 AM.. |
01-06-2020, 05:16 AM | #2825 |
Rep 46
Hello Guys,
Hope some one can help me out in here. I have bought the android 10 system and want to use the LTE function. Question 1: What kind of simcard can i use? Question 2: The simcard needs to be Nano, micro or normall size? It looks like micro or nano because the normall size does not fit but i also tried micro but looks like that does also not fit. Question 3: i have heard that not all provider simcards are working in the sytem. Does someone knows where to look at? I have will attache a image. It looks like the left slot is for SD card and the right slot i have removed the plastic from to try to put in the simcard. When i try to put in a nano simcard it goes really deep and it took me like 30 min to get it back out. Hope someone can help me out! Kind Regards, Marlon PS: i also try to use USB 3G dongle but then the problem is when i power on the system the system does not connect. I must start android system first then connect usb 3G dongle and then it connects. Thats the reason i want to use the build in 3G/4G. |
01-06-2020, 07:12 AM | #2826 | |
Rep 46
The problem i'm facing now is that the simcard is in and the system does not give any signal. They options in mobile network are grayed out so i cant edit or adjust any settings. Someone knows how to? |
01-06-2020, 10:16 AM | #2829 |
Rep 87
It would be more helpful if you provided link where you bought it from. You mentioned that its Android 10 unit, but last picture shows android version 9. It depends which SoC you have. Maybe you can install some kind of system info app and find out. Snapdragon units (and some Intel SoCs) have integrated 4G modem
01-06-2020, 10:52 AM | #2830 |
Rep 46
yes sorry its android 9 10.2 inch i made a mistake.
Do you know any system info app? Then im going to install it directly and see if i can find the info for you. |
01-07-2020, 05:45 AM | #2831 |
Rep 46
01-07-2020, 07:53 AM | #2832 |
Rep 26
Carlinkit Bluetooth dongle connected to android head unit BMW f30
Work's fine with CarPlay music until I try to search through albums etc using idrive then music stutters and music options have a mind of their own. Have all the latest updates, can anyone help please. |
01-08-2020, 06:26 AM | #2833 | |
Rep 207
Alex Hi,
I have similar setup. Android 7 (ugode) with front and rear aftermarket cameras installed and I am facing the same problem (I do not use the front camera at all because its too difficult to click the dvr option when I need it the most e.g. during parking). I have manual transmission. When putting 1st driving gear from reverse that rear camera it still showing until the BMW OEM thresholds you mentioned (15km/h, 10sec). I cannot understand how this device will capture the change of the gear to auto switch the camera feed in my case. Regards, Mike Quote:
01-14-2020, 11:54 AM | #2834 |
Rep 22
Backup camera not kicking in when car is put in reverse.
Hi guys,
I hope I could get some help. I have the UGODE 10.25 android 7.1 NBT system. I recently updated the MCU and firmware to the latest available found on Oni Zuka's Google drive link. At first I accidentally updated the system with an incorrect CIC MCU. I was able to update to the correct NBT MCU (NBT-MCU-20180717.zip) My issue is that ever since updating the MCU and software my backup camera does not kick on when I put the car in reverse. I have tried an MCU reset, downgrading the MCU and downgrading the software but nothing gets it to work. I have confirmed that the backup camera works by putting it into the DVR input and selecting DVR and the camera does show. I have played with the CAMBUS on/off setting but still no luck. Does anyone know if there is a setting I need to activate to get the backup camera to kick on when I put the car in reverse. Any help and/or suggestions would be greatly appreciated. Thanks! |
01-14-2020, 11:57 AM | #2835 | |
Rep 190
01-14-2020, 12:51 PM | #2836 |
Rep 22
Thank You!
I went into the camera settings and the camera 360 option was indeed selected and I have an after market camera. I set it to after market and now it kicks over when I put it in reverse. For the life of me I don't know why I never checked this section when it was a bit obvious. LOL! Thanks again. |
01-16-2020, 04:25 AM | #2837 | ||||
Rep 56
01-16-2020, 04:29 AM | #2838 |
Rep 207
