07-11-2019, 06:46 AM | #1 |
Rep 8,492
CCTV / QNAP
I've read the previous CCTV threads but I couldn't see definitive votes for or against specific CCTV cameras working with QNAP NAS.
Personal experience is often more accurate than official NAS manufacturer compatibility certification, so perhaps someone here can help. I have a 6-bay QNAP NAS (TVS663) with plenty of clock speed, RAM and capacity. I am considering installing a single outdoor CCTV camera to monitor the driveway and the cars; thinking of the following specs/features : POE Dome (easier to keep clean than an exposed camera lens ?) PTZ if the price point isn't ridiculous Motion detection (preferably PIR as I don't want hedges etc triggering false recordings/alerts, and switchable) HD Night vision with IR cut filter Recoding distance would need to be about 10M If anyone has any direct experience (good or bad) then I'd be interested to hear about it.
07-11-2019, 07:25 AM | #2 |
Rep 3,486
I could understand you wanting to use a QNAP if you had a 16 camera set up recording everything in 4k, but for a single camera setup will a traditional DVR/NVR setup not do?
07-11-2019, 07:40 AM | #3 | |
Rep 8,492
What with the NAS, Amazon Fire TV, media streamers, and handheld devices I really don't need another box to have to manage ! All I need is a reliable, high def, compatible CCTV camera.
07-11-2019, 07:41 AM | #4 |
Rep 293
I'm running a QNap with 3 Lilin cameras here. Works very well for long-term storage but playback can be a bit of a faff.
I didn't bother with PTZ. Motion detection is excellent on the Lilins. You can define a zone for it to look at or have it use face detection. Make sure you get one that has decent FPS including in night mode. Feel free to ping me a PM if you want to talk specifics. |
07-11-2019, 07:55 AM | #5 |
Rep 1,303
I have a synology with 6 POE camera.
In terms of camera you havent specified where it will be... generally dome is used where reachable... if elevated out of reach turret is far better - domes need to be cleaned regularly if exposed to the elements. In terms of camera i have a mixture of Hikvision... if you plan to have your ip camera’s open to the internet make sure you consider security... i connected my camera to a separate vlan. |
07-12-2019, 04:31 PM | #6 |
Rep 364
We have 6 Poe's attached to a dedicated hikvision NVR, works well, simple, easy to administrate and just does the job
Does the qnap allow cloud backup at all? |
07-13-2019, 01:21 PM | #7 | |
Rep 8,492
07-13-2019, 01:22 PM | #8 | |
Rep 8,492
07-13-2019, 01:26 PM | #9 |
Rep 8,492
Yes, the QNAP does include option for external backup; Cloud and local external drive. As the CCTV would be set in continuous loop/overwrite mode I'll just dedicate a block of space in one of the RAID arrays.
07-13-2019, 03:27 PM | #10 |
Rep 1,642
I've got Synology NAS and Hikvision cameras. The 8mp Hikvision cameras are great you can nearly see the blades of grass in the lawn. A mix of domes and exposed lenses and I find the exposed lenses don't get as dirty as the domes and are better at night vision.
However i've never got motion detection to work properly at all on my Synology or Hikvision NVR that my parents have. It either records when you don't want it too or misses proper motion. To which I have resorted to leaving on 24/7 record and having a ring doorbell to detect motion which works really well. |
07-14-2019, 11:00 AM | #11 | |
Rep 8,492
07-14-2019, 04:07 PM | #12 |
Rep 1,642
My original ones are these;
https://www.hikvision.com/it/Prodott...P/DS-2CD1341-I The Dome 5mp are these; https://www.hikvision.com/en/Product...2CD2155FWD-I(S) And the 8mp dome is this; https://www.hikvision.com/europe/Pro...2CD2185FWD-I(S) After buying the 8mp after all the rest i'd of just bought them all in 8mp. Just ensure you've got the recording and processing power for the 8mp cameras on your NAS. I prefer my original ones to the domes, however we went with the domes as they are a smaller camera compared to the rest. The newer ones they've made the camera physical size bigger so they stand out a lot more. They're all good though, but for the higher res cameras you need the processing power to back them up. They've just done some new darkfighter ones which I did consider buying when purchasing the 8mp dome, however the night vision on all of the above is perfectly fine. |
Watsey6403.50 |
